Finish suggestions for a dining room tabletop
Forum topic by HeirloomWoodworking posted 214 days ago 567 views 1 time favorited 11 replies Add to Favorites
View HeirloomWoodworking's profile
HeirloomWoodworking
19 posts in 224 days
214 days ago
Topic tags/keywords: tip question oak finishing
I wonder if I could get some feedback from my fellow wood crafters regarding the proper and correct finishing product (clear coat over stain to match the cabinetry) to use on my next project.
Currently making plans and gathering materials for a double pedestal dining room table in red oak. The base top will be 1” x 42” x 60” with 3 – 12” leaves, making the completely extended top 42” x 96”.
The queen and I are still in the kid raising business so I want to give the top a quality finish that will wear well. (Ok it is probably not the kids that are hard on the table…I am mostly to blame).
Lately I have been finishing most of my furniture with General Finishes Arm-R-Seal, and I have really grown to like how it applies and finishes. I am unsure if it is the right product to use on a everyday table top. I will call their tech support for their suggestions, but I was wondering what you other crafters prefer to use on this type of application.
Thanks in advance for your input.
Trevor Premer
Heirloom Woodworking
-- Trevor Premer Head Termite and Servant to the Queen - Heirloom Woodworking
View lechevaldebois's profile
lechevaldebois
54 posts in 240 days
214 days ago
On table tops, I like using tung oil as a base then 8 to 10 thin coats of Minwax wipe-on varnish, scuff-sanding (320 grit) every 2 coats. Then polish with natural beeswax.
View ND2ELK's profile
ND2ELK
2479 posts in 258 days
214 days ago
Hi Trev
Laminate with wood trim is the best kid proof top. I have always used 2 coats of poly urethane and wax on my solid tops. You can sand and refinish after there older. Then theres the grand kids!
Tom
-- Mc Bridge Cabinets, Iowa
View GaryK's profile
GaryK
8483 posts in 473 days
214 days ago
Polyurethane. It’s water proof and as Tom said, it’s easy to sand and add another coat later.
You can repair it at any time.
If you want a satin finish just put that on last. Use a couple of coats high gloss under it because it’s
tougher.
9077 posts in 306 days
214 days ago
I prefer to use poly for table tops like this. It is going to take a beating and liquid spills on it. Poly stands to a lot of abuse and is easy to repair.
HeirloomWoodworking
214 days ago
Thanks for the advice men.
I should not be as hard on the new table as I was on the old one. Now that I have heat in my shop, I won’t have to clean fish, grind venison or use the Queens table as a woodworking bench. Voice from the family room…”Can you please only bang on that %$#& chisel during commercials”.
Trev
View Thos. Angle's profile
Thos. Angle
3236 posts in 447 days
214 days ago
Trev, I use wipe on Poly that I mix 75% gloss and 15% mineral spirits. I usually seal with a coat of Bullseye shellac and then scuff sand between coats. Use lots of coats and then you can control the gloss with buffing and wax. I use the gloss because you do not need to stir it which raises bubbles.
View Greg3G's profile
Greg3G
641 posts in 570 days
214 days ago
Trev, I have done a few tables in the recent past and I find that by using a wipe on poly I can buld up the finsih pretty quickly. I lay on very thin coats and they only take about 15 minutes to dry. I then run my hand over the surface to check for dust nibs and if there only a few, I lay on another coat. When I do feel more, I will quickly knock them down with 400 grit. Once I get the finish built up enough, I will then rub it out with 600 up to 1200 wet sanding. That will take care of the rest of dust nibbs and will remove any ridges in the finish. When that is done, I move to my buffer, with a quick run of automotive rubbing compound followed by a couple of very thin coats of wax. That will leave me with a very high gloss finish. If i want a satin finish, I skip the rubbing compound and hand apply the wax. It doesn’t take as long as it sounds. I can ususally finish a table top in about 3 or 4 eveings.
-- Greg - Charles Town, WV
View Dadoo's profile
Dadoo
1536 posts in 475 days
214 days ago
I use Poly. It was designed for wooden flooring so it’s designed to be tough. Let each coat dry hard (at least 24 hours) then power sand with 220 grit to remove the “nubs”. Your topcoat won’t get sanded of course and it will be as smooth as glass. I usually go just two coats but more will protect more. Satin seems to look best and hides minor scratches, but gloss will make your project glow in the dark! And like Gary said, “It’s easy to repair.”
View tenontim's profile
tenontim
915 posts in 229 days
214 days ago
When my kid was home, I made tables with a plexiglass table cover ;]
-- Tim -- http://tmuli.com
View Don Niermann  's profile
Don Niermann
134 posts in 457 days
213 days ago
General Finishec Arm.R .seal
-- WOOD/DON (...one has the right to ones opinion but not the right to ones own facts...)
View rikkor's profile
rikkor
7632 posts in 359 days
213 days ago
I’d suggest the polyurethane, as well. Best water protection.
-- Maplewood, MN
Bookmark And Share This Page
