Compound Angles??
Forum topic by greg48 posted 03-24-2011 01:49 AM 1485 views 0 times favorited 3 replies Add to Favorites Watch
View greg48's profile
greg48
593 posts in 2660 days
03-24-2011 01:49 AM
Topic tags/keywords: question compound miters
Fellow LJ ‘ers, I have a small problem for a small project. I have taken on a request from a friend to build a four legged tower to support a 1 1/2” glass globe. The tower will only stand ~3” tall with a 2” square platform on the top. The legs will splay outward from the platform 10 deg. in both directions. I’m trying to calculate the compound angle of intersection of the legs to the platform and the angle at the top and bottom of the legs for a level surface/footing. I will be using a radial arm saw and/or coping saw. Any advice or direction you could send me would be greatly appreciated.
P.S. By the use of “Fellow” in the salutation, I do not wish to offend or dismiss any of our female contributors, I merely did not know of a non-gender specific friendly opening to use.
-- Greg, No. Cal. - "Gaudete in Domino Semper"
3 replies so far
View gfadvm's profile
gfadvm
14940 posts in 2593 days
#1 posted 03-24-2011 05:47 AM
A compound miter saw would be the best option if available.Set both angles at 10 degrees,cut some scrap,and check your fit.
View dakremer's profile
dakremer
2661 posts in 2994 days
#2 posted 03-24-2011 06:59 AM
if you give me til tomorrow night I can draw up a google sketchup model for you with dimensions, etc. Just private message me the dimensions and angles of everything and i’ll get to it tomorrow!
-- Hey you dang woodchucks, quit chucking my wood!!!!
View wb8nbs's profile
wb8nbs
164 posts in 2595 days
#3 posted 03-24-2011 03:43 PM
If you google “compound miter calcualtor” you will find a few web pages that can do the job.
I have used http://www.pdxtex.com/canoe/compound.htm to calculate the angles for a compound box joint project. He has both miter and butt joint calculations on that page. It sounds like your project needs butt joint figures.
-- The only difference between men and boys is the price of their toys.
