Box joint tear out
Forum topic by otis501 posted 03-23-2011 10:05 PM 4825 views 0 times favorited 11 replies Add to Favorites Watch
View otis501's profile
otis501
28 posts in 2521 days
03-23-2011 10:05 PM
I get tear out on the back side of my box joint on the table saw even when I have a backer board.
I have a Freud dado blade and cutting ½ in oak.
What am I doing wrong or is this typical.
11 replies so far
View tenontim's profile
tenontim
2131 posts in 3617 days
#1 posted 03-23-2011 10:08 PM
I scribe the top of the cut, like laying out dovetails.
View TheDane's profile
TheDane
5348 posts in 3535 days
#2 posted 03-23-2011 11:44 PM
Do you clamp the backer board and the workpiece to the jig?
—Gerry
View Gerry's profile
Gerry
263 posts in 3113 days
#3 posted 03-24-2011 12:09 AM
+1 With the Dane! For sure, the backer board should solve the issue. Scribing the board is a good idea too!
-- -Gerry, Hereford, AZ ” A really good woodworker knows how the hide his / her mistakes.”
View juniorjock's profile
juniorjock
1930 posts in 3638 days
#4 posted 03-24-2011 12:21 AM
I’ve used clear tape on the back of boards and had pretty good cuts. This may be dangerous and I just don’t know it….. (but I’m sure someone will tell me if it is). One thing for sure…. never but tape on a piece that is going to be a cut-off. Unless you want a piece of wood hitting you between the eyes….
- JJ
View Jim Finn's profile
Jim Finn
2592 posts in 2794 days
#5 posted 03-24-2011 03:46 AM
Do you think the backer board has to be as hard as the board that the box joint is being cut into?
View gfadvm's profile
gfadvm
14940 posts in 2562 days
#6 posted 03-24-2011 05:42 AM
You must keep your workpiece tight against the backer board or youll get tear out.I usually use eighth inch ply for a backer board.I use the Freud box joint blades and have no tearout in half inch oak.If your blades are dull or dirty this might be your problem.Hope this helps.
TopamaxSurvivor
18162 posts in 3548 days
#7 posted 03-24-2011 07:46 AM
Does the Freud box joint blades cut 1/4 slots?
TheDane
#8 posted 03-24-2011 02:11 PM
Topa—If he has the same set I have, the Freud cuts both 1/4” and 3/8” slots.
—Gerry
TopamaxSurvivor
#9 posted 03-24-2011 03:04 PM
Thx Gerry, I remember that set now ;-)
View wb8nbs's profile
wb8nbs
164 posts in 2565 days
#10 posted 03-24-2011 03:35 PM
I have good luck using 1/4 inch masonite as backer (cheap). I wet the shiny side with water and a little detergent, let that soak in a couple minutes so it’s not so slippery. Have the Freud 8 inch stack dado set and because of the design of my box joint jig, I can hard clamp the the work and backer together.
http://www.flickr.com/photos/27392624@N00/sets/72157622846581829/
-- The only difference between men and boys is the price of their toys.
otis501
#11 posted 03-24-2011 04:05 PM
Thanks guys, I use a 3/4 in backer board screwed to a board monted onto my miter gage to cut 1/4 slot. I tried the scribe and that made a big difference but still a little tear out, I will try the scribe and add 1/4 inch masonite to the backer board and give them both a try.
Thanks to all Otis
