scoring cuts in veneered material, like melamine
Forum topic by toolie posted 01-14-2018 03:01 PM 383 views 0 times favorited 8 replies Add to Favorites Watch
View toolie's profile
toolie
2134 posts in 2656 days
01-14-2018 03:01 PM
I needed to rip pieces of melamine coated material for a project. I made scoring rips using a ZCI on each side of the material (with almost no chip out) but still got more than anticipated chip out on the underside of the material (the side of the material resting on the table saw top) when making the thru cut.
I happened onto this video @ Woodgears:
https://woodgears.ca/shop-tricks/tearout.html
I’m wondering if a scoring rip cut pushed the length of a 48” piece of material from the rear of the saw towards the operator’s position would cause the material to be thrown in the direction of the spinning blade as the minimal depth scoring cut should not, according to Mathias, provide enough grip to hurl the work piece from the hand of the operator.
I dismissed the idea of tape and scoring with a drywall knife. Tape probably isn’t substantial enough to really help and a drywall knife only provides a thin scoring line while the blade, @ 1/8” wide, has two scoring edges.
Just wondering what the group thinks about this or if there are any other fool proof methods of ripping veneered material while avoiding chip out.
8 replies so far
View Jim Finn's profile
Jim Finn
2658 posts in 2949 days
#1 posted 01-14-2018 03:45 PM
Have you tried applying tape, before cutting, top and bottom, on the cut line?
-- Website is No PHD just a DD214 and a GED https://craftingcouple.com/
View Ripper70's profile
Ripper70
1025 posts in 936 days
#2 posted 01-14-2018 03:51 PM
If you’re thinking of trying this with a full sheet of 3/4” material and only making a 1/16” or 1/32” scoring cut, the weight of the wood will probably heavy enough to offer adequate control of the cut. I think it could work. Having a second set of hands on the operator’s side of the table might be safer since you probably will need some outfeed support.
-- "You know, I'm such a great driver, it's incomprehensible that they took my license away." --Vince Ricardo
View waho6o9's profile
waho6o9
8207 posts in 2604 days
#3 posted 01-14-2018 06:17 PM
How about using a blade designed for melamine?
View Loren's profile
10476 posts in 3675 days
#4 posted 01-14-2018 06:26 PM
There was some discussion recently on the
Festool Owners Group of this topic. Various
methods were mentioned to reduce chipout
but there was a general agreement that
melamine got from commercial suppliers was
far less prone to it compared with big box
suppliers.
View BurlyBob's profile
BurlyBob
5555 posts in 2293 days
#5 posted 01-14-2018 06:31 PM
I’ve found that a very shallow cut on either side will reduce chipping to virtually nothing. Also when I make the final cut I never let the saw teeth extend past the surface of the material. I’m using a WW 2 thin kerf.
View AlaskaGuy's profile
AlaskaGuy
4211 posts in 2336 days
#6 posted 01-14-2018 06:54 PM
suppliers.
- Loren
+1 not all melamine is created equal.
toolie
#7 posted 01-19-2018 03:09 PM
- waho6o9
I cant believe I overlooked something so obvious. I might even have that blade already! Thanks!
View jbay's profile (online now)
jbay
2342 posts in 926 days
#8 posted 01-19-2018 09:19 PM
Typically, Melamine blades have a -5 degree (negative) hook.
They also need to be sharp or your losing the battle.
It’s all about the angle the teeth hit the surface.
I have cut miles of melamine and if the blade is to low it will chip out the top, too high and more chipping on the bottom. You need to find the happy medium.
When all else fails raise the blade about 1/16” and score the bottom first and raise the blade to about 3/4” above the surface to make the final cut. Your mileage may very, because as they have said above, different melamines have different qualities.
(Please don’t run your material backwards through the saw.)
