Vacuum controlled by saw switch
Forum topic by MalcolmLaurel posted 01-14-2018 02:08 AM 962 views 1 time favorited 15 replies Add to Favorites Watch
View MalcolmLaurel's profile
MalcolmLaurel
300 posts in 1819 days
01-14-2018 02:08 AM
Topic tags/keywords: question
I’m picturing a device I want and wondering if it exists.
My shop vac sits next to my radial arm saw, and pulls dust from a collector behind the saw through a Thien separator into the vac. Works fine, but I have to turn on and off both the saw and the vacuum every time.
What I want is a way to turn on both the saw and vacuum with one switch. I could put a switch in a box and have two outlets, but I’d rather use the switch’s existing switch, which is conveniently located on the front of the arm. I could splice into the saw’s wiring to add an outlet for the vac, which is what I’ll probably do if I can’t find what I want, but what would be really nifty is a device I could plug into the wall with an outlet for the saw and the vac, which would sense the current draw from the saw and automatically turn on the vacuum. I could design such a device and it would be more elegant than cutting into the saw wiring, but I have enough projects as it is… surely I’m not the first person to think of this so one would think it’s available somewhere?
Anybody heard of and know where to get such a thing?
-- Malcolm Laurel - http://MalcolmLaurel.com
15 replies so far
View jdh122's profile
jdh122
1052 posts in 3014 days
#1 posted 01-14-2018 02:13 AM
Like this?
http://www.grizzly.com/products/i-Socket-Autoswitch-15A-110V/T25759
-- Jeremy, in the Acadian forests
View Rayne's profile
Rayne
1104 posts in 1736 days
#2 posted 01-14-2018 02:14 AM
This should do it. I have one to use on sanders.
DGC PRODUCTS i-Socket Autoswitch
MalcolmLaurel
#3 posted 01-14-2018 02:16 AM
Perfect! Exactly what I was looking for, I knew it had to be out there somewhere but didn’t know what to search for.
View Psavage1's profile
Psavage1
3 posts in 330 days
#4 posted 01-14-2018 02:17 AM
This will do what you are looking for.
View wuddoc's profile
wuddoc
319 posts in 3914 days
#5 posted 01-14-2018 02:23 AM
Look at this website.
http://dgcproducts.com/
Grizzly and Amazon sell this unit and most likely other vendors.
-- Wuddoc
MalcolmLaurel
#6 posted 01-14-2018 02:52 AM
Just ordered the DGC switch from Amazon.
View toolie's profile
toolie
2148 posts in 2825 days
#7 posted 01-14-2018 03:42 PM
- MalcolmLaurel
When that switch ceases to deliver the desired performance, the Ivac will be the first, and last, switch of that type you will need. Great products from a great company.
View TheFridge's profile
TheFridge
10689 posts in 1682 days
#8 posted 01-14-2018 05:30 PM
I use a current switch to power a contactor for my dust collector. As long as you have the basic function there are many ways to expand it.
View SweetTea's profile
SweetTea
371 posts in 856 days
#9 posted 01-15-2018 11:28 AM
Would the dust collector and the table saw not have to be on the same circuit for this device to work since it just plugs into one outlet? My concern would be tripping the breaker with both the dust collector and the table saw on the same circuit.
I have to keep my table saw and dust collector on different circuits because if I try and run both at the same time on one receptical the breaker trips about 40% of the time, and not on startup. This circuit only has one receptical and the wire is 12/2 with a 15a receptical.
My Craftsman 351.221160 cabinet saw is a 110v 15a machine, as is my Harbor Freight dust collector that I use with it. I am sure that if these were 220v machines I might not have this issue as I could then run a 20amp breaker. Does anyone know if my Craftsman 351.221160 cabinet saw and my HF dust collector can be required for 220?
MalcolmLaurel
#10 posted 01-15-2018 11:37 AM
Would the dust collector and the table saw not have to be on the same circuit for this device to work since it just plugs into one outlet? My concern would be tripping the breaker with both the dust collector and the table saw on the same circuit. I have to keep my table saw and dust collector on different circuits because if I try and run both at the same time on one receptical the breaker trips about 40% of the time, and not on startup. This circuit only has one receptical and the wire is 12/2 with a 15a receptical.
As supplied they would have to be on the same circuit. However, it would be fairly simple to use the device to operate a relay instead of operating the dust collector directly, with the relay switching a separate circuit. Or upgrade the receptacles on the circuit to 20A and put in a 20A breaker (12GA wire is good for 20A).
View Kazooman's profile
Kazooman
1236 posts in 2149 days
#11 posted 01-15-2018 02:09 PM
I usually let the dust collector run a while after making a cut and turning the saw off. There is still dust to be had in the cabinet and ductwork. I don’t want to keep the saw running for safety reasons. Locating a separate switch for the dust collector near the saw switch is an alternative you might consider.
Rayne
#12 posted 01-15-2018 02:29 PM
- SweetTea
Mu understanding of the DGC autoswitch is that it staggers the shop vac to allow your primary tool to run first and then turn on the shop vac so it wouldn’t trip the breaker. He’s not using a full size DC for this operation on the radial arm saw.
The autoswitch also stays on for a few more seconds to clear out the line.
MalcolmLaurel
#13 posted 01-16-2018 12:04 AM
Got the DGC switch this morning, used it this evening. Works just fine, exactly what I needed. And yes, not a full size DC, just a shop vac sucking through a homemade separator.
toolie
#14 posted 01-19-2018 03:01 PM
Would the dust collector and the table saw not have to be on the same circuit for this device to work since it just plugs into one outlet? My concern would be tripping the breaker with both the dust collector and the table saw on the same circuit…...
One of the advantages if the Ivac switch is that the activating appliance (tool) and the dust collector can be on separate circuits.
View MinnesotaSteve's profile
MinnesotaSteve
54 posts in 1088 days
#15 posted 01-19-2018 03:48 PM
I bought one of the IVac switches some 6 years back, and I love it. The other nice thing about it is you can flip the switch to just turn on the vacuum by itself.
Also it leaves the vacuum running for a few seconds after you shut off the saw, to insure the hose is cleared of dust.
