Finishing a piece with a tenon
Forum topic by cowboyup3371 posted 01-13-2018 05:08 PM 406 views 0 times favorited 4 replies Add to Favorites Watch
View cowboyup3371's profile
cowboyup3371
59 posts in 225 days
01-13-2018 05:08 PM
Topic tags/keywords: finishing joining
I’m building out the interior pieces of a jewelry box first and then will make the actual carcass soon. This is being done for space, to allow for the same lacquer finish but slightly different stains, and to ensure everything sits the way I want them to before glue-ups. One of the pieces will be attached to the carcass with a mortise and tenon joint. Should I plan the mortise to be wide enough to fit a lacquer finished tenon or should the tenon remain unfinished?
Other projects I have done with mortise and tenon joints were finished after they were actually put together.
-- Cowboy Up or Quit - If you are going to quit than get out of my way
View Loren's profile
10476 posts in 3675 days
#1 posted 01-13-2018 05:32 PM
Glue won’t stick to a lacquered tenon.
View jerryminer's profile
jerryminer
928 posts in 1468 days
#2 posted 01-13-2018 08:07 PM
Glue won t stick to a lacquered tenon.
- Loren
+1. Mask off the tenon when you lacquer
runswithscissors
2767 posts in 2052 days
#3 posted 01-15-2018 12:45 AM
Or make a pinned tenon, with a wedge shaped pin.
cowboyup3371
#4 posted 01-15-2018 01:30 AM
Thank you all
