Plane Treatment Good or Bad
Forum topic by DaddyZ posted 03-22-2011 05:53 PM 1569 views 0 times favorited 24 replies Add to Favorites Watch
View DaddyZ's profile
DaddyZ
2475 posts in 3039 days
03-22-2011 05:53 PM
Topic tags/keywords: planes plane refurbishing sharpening question tip
I just have to ask, When ever I see a plane in someone’s photo background is is always sitting on the sole. I would have thought planes should be turned on the side, so you don’t damage the Blade.
Am I right or is there some other reason to lay a plane on its sole?
Just Wondering ;)
24 replies so far
View HorizontalMike's profile
HorizontalMike
7757 posts in 2913 days
#1 posted 03-22-2011 05:58 PM
Vanity! LOL!
Having run a knuckle across an exposed blade from a plane on its side, I would imagine that you could add that as another reason as well…
View Bertha's profile
Bertha
13528 posts in 2692 days
#2 posted 03-22-2011 05:58 PM
If you see one in my pictures, it’s laziness. I know well not to place a plane on the sole but I do it anyway. I usually have a little piece of square 1/4” dowel that I prop the toe on but I’m not perfect!
16274 posts in 4217 days
#3 posted 03-22-2011 05:58 PM
Well, I suppose one could retract the blade out of harms way between uses, and then it would be okay to rest it on its sole. I would also suppose that if you carefully rested the plane on a wood surface when it wasn’t in use you would not harm the blade. But otherwise, I’d have to think you are right.
HorizontalMike
#4 posted 03-22-2011 06:17 PM
I like Al’s idea of using a scrap of wood/dowel to prop the plane up. I guess, in my situation, I could just lay them across my new fancy dancy tool trays in the center of my new workbench and accomplish the same thing. 8-)
But DaddyZ, you are correct in that we all need to pay more attention to this.
Bertha
#5 posted 03-22-2011 06:25 PM
^LOL with Horizontal. Owners of fancy new workbenches are allowed this vanity. :)
DaddyZ
#6 posted 03-22-2011 06:48 PM
Sorry Mike Accidents Happen;)
Charlie – In a perfect world
LOL!!!
At least I’m Crazy but not to much !!!
View whitewulf's profile
whitewulf
454 posts in 2935 days
#7 posted 03-26-2011 09:21 PM
I read somewhere???? that laying iron plane on side could possibly knock blade out of square!
I use a block(or small board) with felt impregnated with beeswax or oil to lay plane on depending whether wooden plane or iron.
-- "ButI'mMuchBetterNow"
View NBeener's profile
NBeener
4816 posts in 3173 days
#8 posted 03-26-2011 09:36 PM
Charlie wrote:
”Well, I suppose one could retract the blade out of harms way between uses, and then it would be okay to rest it on its sole.”
Ayup. That’s MY practice. I just pull the blade back after use.
I also don’t set it on anything that is harder than the sole. So … on my bench is okay. On my DP table is okay. On my cast iron jointer tables … not so much.
Building a “proper parking place” FOR a plane sounds like a pretty easy and effective fix. I’ll add it to my “Round Tuit” list—the one that … just gets longer and longer all the time :-)
-- -- Neil
View canadianchips's profile
canadianchips
2600 posts in 2996 days
#9 posted 03-26-2011 10:02 PM
I think gently resting a plane on its sole, sitting on any wooden shelf is okay. Keep it waxed and keep it dry.
View Grandpa's profile
Grandpa
3259 posts in 2674 days
#10 posted 03-26-2011 11:03 PM
When I had Industrial Arts class in the 9th grade before many of the readers here were born, we were taught to lay the plane on its side. NEVER lay a pane on its sole or you risk the rath of the instructor. I always lay mine on its left side with the sharp edge away from me. I am right handed. If I were left handed I would do the opposite. This keeps the delicate edge from being damaged requiring sharpening and re-honing. Just the way we were taught. Might be like the mother teaching her daughter the proper way to bake a ham. The first thing you do is cut about 6 inches off the small end of the ham. The daughter asked why. The mother said because that is the way I was taught. Your grandmother always did it that way. The granddaughter thought about it and went to see the grandmother to ask why. When she asked, the grandmother said I always did it this way because my roaster pan was too short. I am not sure why your mother does it that way!!!!!
View Chelios's profile
Chelios
568 posts in 3065 days
#11 posted 03-26-2011 11:47 PM
I don’t see how anything could happen to the blade if you lay it on top of a wood surface like your workbench. I always do that, never had an issue. I think it is safer for both me and my planes. Remember you actually have to put some pressure and alignment for a plane to make a cut so unless the set up of the blade is way out of the sole, which in my case it never is then I don’t see a problem.
best
View Luke's profile
Luke
545 posts in 3292 days
#12 posted 03-26-2011 11:55 PM
ditto Chelios. Don’t put it on a metal or concrete surface obviously but wood, no problem. I’d be more worried about the wood surface you’re putting it on than the plane blade.
-- LAS, http://www.abettersign.com
View littlecope's profile
littlecope
3071 posts in 3501 days
#13 posted 03-27-2011 12:11 AM
I’ve always laid them on their side and, like DaddyZ, I wondered why others didn’t too…
View Paul C.'s profile
Paul C.
154 posts in 3244 days
#14 posted 03-27-2011 01:01 AM
I figure if it can stand the stress of my big body pushing it into hardwood, it can handle being placed on my workbench, sole down.
On my jointer, not so much…..
View poopiekat's profile
poopiekat
4355 posts in 3733 days
#15 posted 03-27-2011 02:45 AM
Well I guess it’s up to me to ponder what Stanley’s instructions might have been, if asked about the care and storage of a #10 Rabbet. The blade protrudes on 2 sides as well as the sole. By habit I retract the cutters and store my planes upright on either wood or particle board surfaces.
