Removing/loosening titebond 2
Forum topic by CovenantCreations posted 788 days ago 1478 views 0 times favorited 12 replies Add to Favorites Watch
View CovenantCreations's profile
CovenantCreations
127 posts in 1068 days
788 days ago
Anyway to do it? Got a project I need to redo that i glued up with tbII.
12 replies so far
View gfadvm's profile
gfadvm
6600 posts in 855 days
#1 posted 788 days ago
A heat gun set to high heat will allow you to separate this glue joint.Take your time as you need to get it pretty hot and heat must penetrate to the glue joint.
View wildbill001's profile
wildbill001
99 posts in 807 days
#2 posted 788 days ago
Heat or saw has been the only things that worked for me in the past. Some may suggest vinegar but all that did for me was make the wood swell and me hungry for a greek salad.
Bill
-- "You can tell the pioneers by the arrows in their back" -- Unknown
View Gary's profile
Gary
3529 posts in 1598 days
#3 posted 788 days ago
I use stuff called “deglue goo” ,,,,even helps to get all the glue cleaned out once the joint is seperated
View Bernie's profile
Bernie
381 posts in 1002 days
#4 posted 788 days ago
Depending on the size and nature of the joint, for simple butt joints, I have literally clamped the piece to a flat surface, placed a board on the glued up piece and slammed it sharply with a mallet. This did split the joint and I cleaned up both edges with a scrapper. This was done after an overnight set up when I discovered I had glued the piece upside down. I’ll keep the previous posts in mind next time and my eyes are open for new suggestions. Thanks for the good question creations.
-- Bernie: It never gets hot or cold in New Hampshire, just seasonal!
View Sawdust4Blood's profile
Sawdust4Blood
321 posts in 1186 days
#5 posted 788 days ago
depends on the kind of joint. I’ve successfully separated butt joints and even biscuits using a heat gun. If it’s mortise and tenon, you’re screwed.
-- Greg, Severn MD
CovenantCreations
#6 posted 788 days ago
Just a butt joint. I dont have a heat gun in my arsenal, will my wifes hair dryer get it hot enough?
View richgreer's profile
richgreer
4474 posts in 1239 days
#7 posted 788 days ago
If you did a good job of gluing, your only option is a saw.
View tenontim's profile
tenontim
2129 posts in 1909 days
#8 posted 787 days ago
Usually you can call most companies that make glue to get info about it. In the case of Titebond, years ago I gave them a call and was told to use acetone to dissolve the glue. Once you get the joint separated, you will have to use acetone and a wire brush to get as much of the glue out of the grain as possible, if you plan to re-glue. Glue will not provide a strong bond if glued to itself.
-- Tim-- http://www.tmuli.com
View brtech's profile
brtech
467 posts in 1087 days
#9 posted 787 days ago
No, a hairdryer won’t get hot enough to break the bond. However, an HF $10 cheapie is fine. No need for a $50 heat gun. Of course you CAN char the wood if you get it too hot.
If acetone will break the bond, great, but you may need a needle to get it into the joint. Use full strength acetone from the Borg; nail polish remover hasn’t got enough concentration.
CovenantCreations
#10 posted 787 days ago
Well I’ll give a few of these ideas a shot, if not I guess Im stuck sawing and sanding.
86885 posts in 1742 days
#11 posted 787 days ago
Here’s some more takes on the subject.
http://lumberjocks.com/topics/24233
CovenantCreations
#12 posted 786 days ago
UPDATE
I tried this last night. I was a smallish project and able to fit in my oven. I didn’t want to wait to get the heat gun. I put it in a 300 for a little while popped it out and pulled the joints right apart. Worked well except a couple pieces warped a little due to the heat, oh well it was kind of a trial run anyways, but i mainly wanted to get my nice mahogany handles off without damaging them and that turned out well.
