Radial Arm Drill Press
Forum topic by TooTall posted 03-22-2011 02:41 AM 2250 views 0 times favorited 3 replies Add to Favorites Watch
View TooTall's profile
TooTall
6 posts in 2645 days
03-22-2011 02:41 AM
I am in need of a radial arm drill press for 6” hole cutting. I coould use some input from anyone with experience with these drill presses. The ones that I am looking at are Grizzly 9969 and Rikon. There aren’t a lot of these to choose from.
-- Bob P, Wisconsin, http://www.ups4bobp@hotmail.com
3 replies so far
View tenontim's profile
tenontim
2131 posts in 3745 days
#1 posted 03-22-2011 01:47 PM
Depending on what you are using for cutting the hole, I wouldn’t get a drill with less than 1 hp. The Grizzly meets that requirement. I the smaller Grizzly radial drill, with the 1/2 hp motor, and it won’t drill over a 2” hole with a forstner bit. I can go up to a 4” with a hole saw, but have to take it slow.
TooTall
#2 posted 03-23-2011 03:27 AM
Well if I can’t get the 20” delta/Porter Cable I am going to get the Grizzly bench top.
View Camper's profile
Camper
232 posts in 2857 days
#3 posted 03-23-2011 04:05 AM
I have a radial arm drill press. I am not sure why you would need a radial arm to cut a 6” diameter hole…I would say any old drill press could do that. If you do not already have one, they are sort of neat.
-- Tampa-FL
