| Forum topic by Ed | posted 788 days ago | 1377 views | 2 times favorited | 8 replies | ![]() |
788 days ago |
Have any of you people used any design software that really works and is user friendly.If you have or know anything about this subject I could use some suggestions and information. Thanks. Ed Pa. -- Ed Pa. |
8 replies so far
#1 posted 788 days ago |
A free program is Google’s Sketchup. However, it does have a learning curve. If you are interested in trying it, I have a bunch of links to tutorials. Lew -- Lew- Time traveler. Purveyor of the world's finest custom rolling pins! |
#2 posted 788 days ago |
Ed, I will second Lew’s suggestion on using Sketchup for design purposes. But it will not produce a materials list. I use Cutlist (Silver edition) to generate materials and cut lists. It is primarily designed for sheet goods but it will also handle rough/dimensioned lumber as well. With a plugin you can take a project designed in Sketchup and produce a materials and cut list in Cutlist. -- Challenges are what make life interesting; overcoming them is what makes life meaningful- Joshua Marine |
#3 posted 788 days ago |
I tried Sketch-it but it seemed to be more floor plans and landsccaping lay out. If you have those links to Google’s Sketchup tutorials I would like to look at them before I try to download program I still have phone lines and you known how slow that is. Thankyou. -- Ed Pa. |
#4 posted 788 days ago |
Ed, Here is a link for an eight part series that Chiefwoodworker produced. It is well worth viewing. Basically it is nearly an eight hour series that Joe takes the viewer through the commands and processes necessary to design a shaker table. I am not sure how it will work with dial up though. Good luck. -- Challenges are what make life interesting; overcoming them is what makes life meaningful- Joshua Marine |
#5 posted 788 days ago |
All CAD software has a learning curve, some steeper than others. But with the right tutorials it gets a lot easier. I thought SketchUp was for everyone but woodworker’s until I stumbled upon http://sketchupforwoodworkers.com/. There are some great tutorials tied to a bookcase project that allow you to see the cool things sketchup can do. There are many more out there, including FWW’s Design. Click. Build. Blog. These should give you a good idea of the capabilities of SketchUp. Another LJ, daltxguy, has created a CutList plugin and is providing it for free at http://lumberjocks.com/daltxguy/blog/5143. These may not be everything you need for designing new projects, but they’re a good start. And how can you beat the price?! -- Tim from MA -- "Well done is better than well said." - Benjamin Franlin |
#6 posted 788 days ago |
I hear SketchUp seems to be a good software. -- CJIII Future cabinetmaker |
#7 posted 788 days ago |
I want to thank everybody for all the information and I’m going to check it all out. -- Ed Pa. |
#8 posted 785 days ago |
Ed – Sketchup + Cutlist ( my plugin) will give you everything you probably need. -- If you can't joint it, bead it! |
| Forum | Topics |
Woodworking Skill Share
8781 |
Woodturning
219 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
77 |
Finishing
1521 |
3542 |
15752 |
Hand Tools
2028 |
Jigs & Fixtures
494 |
Wood & Lumber
2832 |
808 |
Focus on the Workspace
899 |
766 |
Woodworking Trade & Swap
2736 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6148 |
