Mortise Chisels and Worksharp 3000
« back to Hand Tools forum
Forum topic by ScottKaye posted 01-12-2018 12:42 AM 451 views 0 times favorited 1 reply Add to Favorites Watch
View ScottKaye's profile
ScottKaye
715 posts in 2188 days
01-12-2018 12:42 AM
I picked up a very gently (as in slightly) used Worksharp 3000 off of craigslist today for a hundred bucks. Haven’t even had time to look through the manual yet so perhaps the answer lies there. Anyway, I’m fairly certain it is possible to sharpen a Mortise Chisel on the Worksharp 3000 via the chisel guide below the disc. I’m just looking for confirmation. Am I correct in my assumption? Also, anything I need to look out for that’s different from sharpening a regular chisel?
Scott
-- "Nothing happens until you build it"
1 reply so far
View gmc's profile
gmc
59 posts in 2392 days
#1 posted 01-12-2018 11:51 AM
Yes you can sharpen up to 21/2” wide chisels or plane blades on it. I have had one for several years and find it will sharpen almost anything. Check out Stumpy Nubs web site for a homemade attachment that will make it sharpen wider blades The plan is 10 bucks and once made you are able to sharpen almost all woodworking tools. I love mine I can sharpen a tool in a couple minutes. It also shows you how to get away from using their glass platters and sandpaper.
-- Gary, Central Illinois
