Slab leveling with a router
Forum topic by Andrew714 posted 01-11-2018 09:13 PM 528 views 0 times favorited 4 replies Add to Favorites Watch
View Andrew714's profile
Andrew714
36 posts in 1517 days
01-11-2018 09:13 PM
Topic tags/keywords: router slab leveling
Hello,
I am working on leveling a maple slab with a router, and I have a question on which bit to use. Currently, I am using a 1.25” diameter bottom clearing bit, but I am really only able to cut approximately 1/16” depth at the full width of the bit without slowing the router motor down too much (I’m using a Bosch 1618).
My question is, would I be better off using a 2” bit, but only making half-width passes, or will that not make much of a difference? I have close to 2” of depth to remove in some areas as well, so to speed things up, I made a sled for my circular saw, and I’m making full depth cuts approximately every 1/4” or 3/8”, as that should lighten the load on the router a little more.
Thanks in advance!
View John Smith's profile
John Smith
1555 posts in 404 days
#1 posted 01-11-2018 09:27 PM
(a) use a smaller diameter bit
(b) don’t bite off more than the router can chew
(c) find a router with more horse power
you said: “I’m making full depth cuts approximately every 1/4” or 3/8”,
as that should lighten the load on the router a little more”.
are you breaking out the chips with a hammer and chisel after the saw cuts ???
that alone will reduce the sludge that the router has to cut out.
no matter how big that elephant is – you can eat it all if you take small bites.
-- I started out with nothing in life ~ and still have most of it left.
View bigblockyeti's profile
bigblockyeti
5324 posts in 1962 days
#2 posted 01-11-2018 09:33 PM
I would stick with the bit you have, a 2” bit will have higher edge speed but will require more torque to spin while plowing off the same amount of wood. The circular saw is a good idea if you can mount two blades side by side you can generate a double wide kerf but you probably shouldn’t do that because it would be dangerous.
Andrew714
#3 posted 01-11-2018 09:52 PM
(b) don t bite off more than the router can chew
- John Smith
I don’t know why, but a hammer and chisel hadn’t occurred to me yet. That’ll be even quicker than routering the whole depth.
I would stick with the bit you have, a 2” bit will have higher edge speed but will require more torque to spin while plowing off the same amount of wood. The circular saw is a good idea if you can mount two blades side by side you can generate a double wide kerf but you probably shouldn t do that because it would be dangerous.
- bigblockyeti
That’s a good point, I’ll stick with the same bit.
Thanks for the responses, I think this will save me some time.
runswithscissors
2928 posts in 2267 days
#4 posted 01-15-2018 01:05 AM
Your bottom cleaning bit should work best, in that it won’t leave grooves or ridges. The slow cutting your are experiencing may be due to trying to cut the full 1 1/4” in one pass. If you make each pass take off only half the width of the router bit (5/8” or a bit less), you may get better results.
