Wood Lockers
« back to Joinery forum
Forum topic by bwad40 posted 01-11-2018 05:13 PM 487 views 0 times favorited 5 replies Add to Favorites Watch
View bwad40's profile
bwad40
18 posts in 1187 days
01-11-2018 05:13 PM
Hello,
I am a woodworking teacher and since I don’t get much in my budget to maintain my classroom and my current lockers are currently as old as dirt, I would like to replace them with ones my students build in class. This way we can slowly replace my lockers for much cheaper than buying some. My question is on the joinery for the shelves. I am thinking of building these out of 3/4” birch ply and doing 1/4” dados for the shelves. I am just concerned with the strength of this. I have attached a photo of my idea.
I am open to any suggestions or ideas. I think this would be great project for my high school students to do for an end of year project.
Thanks for any input.
5 replies so far
View sras's profile
sras
4969 posts in 3365 days
#1 posted 01-11-2018 05:21 PM
I was going to suggest a face frame on the front, but I am seeing it right, it looks like you already have one.
If I were to design one, it would look like yours. 3/4 inch plywood is pretty tough.
View Loren's profile
10477 posts in 3884 days
#2 posted 01-11-2018 05:25 PM
I might make two cases and stack them.
Simple to do it that way and it allows more
material for the door overlays.
If you’re doing face frames… well, I guess
students might learn more from that. I think
frameless is easier and cheaper if the work
is screwed to a wall.
View bigblockyeti's profile
bigblockyeti
5314 posts in 1957 days
#3 posted 01-11-2018 06:17 PM
Are you planning on the dados being 1/4” wide or deep? I would personally have them 3/16” deep and the width of the shelf lumber, less depth gives more residual strength in the vertical partitions.
View LesB's profile
LesB
1916 posts in 3679 days
#4 posted 01-11-2018 06:54 PM
If I understand the drawing correctly you may have problems with hinges on the doors. You are on a budget and concealed (Blum type) hinges are going to be expensive. Without that type of hinge you will have clearance problems when opening the doors. I think you will need face frames so you can mount the doors with less expensive hinges.
While dadoed fixed shelves will add stability to the cabinet I like to use floating adjustable shelves supported by shelf pins. If you are using more than one shelf in each space you could do a combination of the two.
I agree with Loren about making two units and stacking them. This would allow students to split the project into two groups.
-- Les B, Oregon
View MrRon's profile
MrRon
5261 posts in 3479 days
#5 posted 01-12-2018 09:45 PM
I think I would rather have individual lockers instead of a single unit with 8 doors. That way, each student will have the experience of making all cuts needed for a complete project, not just a part of a community cabinet. If the extra cost of plywood is excessive, you could use MDF for the box. Maybe a local lumberyard could be tapped to donate the material.
A 1/4” deep dado is standard. If you make each locker separate, you can use cheap hinges.
