Through Mortise
Forum topic by pete79 posted 03-21-2011 03:38 PM 1182 views 0 times favorited 6 replies Add to Favorites Watch
View pete79's profile
pete79
154 posts in 3260 days
03-21-2011 03:38 PM
I’m about to embark on attaching a bench seat to the legs of a bench that I’m making for my parents and have a question about this step…
I’m thinking that a through mortise, leaving the tennon on the top of the legs slightly proud of the surface of the bench seat might be a nice touch. My tool choices for cutting the mortise are a plunge router, or hand chisels. I’m going through a 8/4 slab of red oak, and the tennons will be about 1” x 1”. I’ve never cut a mortise by hand before, but am thinking this is my best option?
My main issue is that I’m nervous about going all the way through my really nice 8/4 slab of oak, so I probably just need to get over that. But i’m looking for any words of wisdom, tips, tricks, etc. before I go for it.
Thoughts?
-- Life is a one lap race.
View chrisstef's profile
chrisstef
17634 posts in 3126 days
#1 posted 03-21-2011 03:52 PM
To give yourself a nice clean hole drill half way through then flip it over and rill the other half. It will prevent any blow out.
View Lee Barker's profile
Lee Barker
2170 posts in 2970 days
#2 posted 03-21-2011 04:25 PM
Agreed, chrisstef. Then cut from the top to square it up, but first chamfer the bottom edges slightly with your chisel so you don’t push out a splinter that would show on the end grain side.
Kindly,
View richgreer's profile
richgreer
4541 posts in 3194 days
#3 posted 03-21-2011 05:01 PM
I think I would start with a 1” drill bit and use a backer board to prevent tear out. A router and jig with a small (1/4”) straight bit can partially square the corners from each side. You can finish the job with a chisel.
View David Kirtley's profile
David Kirtley
1286 posts in 3117 days
#4 posted 03-21-2011 05:31 PM
You can also use a coping saw to remove the bulk of the waste after you drill out. Then it is just cleanup with the chisel.
View Loren's profile
10477 posts in 3767 days
#5 posted 03-21-2011 06:03 PM
Like David says. Drill and cope the hole. Then trim to square
with a chisel. Pretty easy to do it this way.
View stefang's profile
stefang
15881 posts in 3453 days
#6 posted 03-21-2011 06:55 PM
You might also drill through with a very small bit at the 4 corners with a backing board clamped to the outside to prevent any breakout. This will give you a perfect guide for the outline of your mortise so you can finish the chopping from the outside without breakout. For this technique to work, your holes have to be at an accurate 90 degree angle.
