finger joints
Forum topic by JohnAjluni posted 03-21-2011 09:22 AM 4425 views 1 time favorited 11 replies Add to Favorites Watch
View JohnAjluni's profile
JohnAjluni
102 posts in 2604 days
03-21-2011 09:22 AM
Topic tags/keywords: jig resource question tablesaw
So i want to make a simple box but I want to use something other than butt joints. So just wondering is there a way to cut finger joints on a table saw without a dado blade? Is there any jigs I could make?
-- John
11 replies so far
View wseand's profile
wseand
2796 posts in 3011 days
#1 posted 03-21-2011 10:41 AM
If you do a search for finger or box joint jig you can find some on this site. You might have to modify them so you can make several passes rather then one with a dado blade.
View chrisstef's profile
chrisstef
17312 posts in 2976 days
#2 posted 03-21-2011 03:09 PM
You could always do miter joints with splines to dress it up.
View richgreer's profile
richgreer
4541 posts in 3044 days
#3 posted 03-21-2011 05:05 PM
If you have a router, router table and straight bit, it’s not hard to make a jig. Use a backer board because the router will give you more tear out than a dado stack.
View Nollie's profile
Nollie
146 posts in 2756 days
#4 posted 03-21-2011 05:24 PM
You can go on You Tube for video on making Greene & Greene style finger joints with a router. The video is “Greene & Greene style finger joints ” by David Wade. Very interesting and very easy. It is also a very fast and very accurate way of doing it.
-- Leon . leonnolte@gmail.com
View Greedo's profile
Greedo
473 posts in 2930 days
#5 posted 03-21-2011 05:26 PM
before i built my router table i tried making finger joint jigs for my tablesaw (without dado blade, because thats illegal in europe) but i couldn’t get good results.
wich is weird because it’s the exact same principle as router table jigs!
now that i have a router table i made 2 finger joint jigs for it, easy to make, rapid to operate and clean cuts!
View stefang's profile
stefang
15881 posts in 3304 days
#6 posted 03-21-2011 07:02 PM
You can also saw these by hand pretty quickly and just chisel out at the ends. It doesn’t really take much time, but you need to mark it out and saw it accurately. Maybe not the best idea if you haven’t got much experience with hand sawing and chiseling. A scroll saw also works well if you have one.
View Steve Maskery's profile
Steve Maskery
48 posts in 3354 days
#7 posted 03-22-2011 09:17 PM
Can I point you in the direction of this thread?
http://lumberjocks.com/topics/14531
regards
Steve
-- The Complete Tablesaw - http://www.workshopessentials.com
View abie's profile
abie
874 posts in 3740 days
#8 posted 01-08-2016 01:41 AM
Thanks Steve for the interesting jig
I am also making one like yours.
I am thinking of making three slinding key plates rather than one.
Each attached to the sled with screw rods w/ knobs into the back plate where you made the screw holes.
each key plate will accomidate a different size key to be able to make several sizes with the same sled.
Since this is your idea I would appreciate your comments..
Thanks
Fellow Lumberjack. Bruce aka Abie
-- Bruce. a mind is like a book it is only useful when open.
View Knothead62's profile
Knothead62
2584 posts in 2930 days
#9 posted 01-08-2016 11:20 AM
Greedo, are you saying that dado blades are illegal in Europe? Why? Curious.
View SirIrb's profile
SirIrb
1239 posts in 1200 days
#10 posted 01-08-2016 12:07 PM
Dado blades are illegal in Europe?
No offence but Europe has some of the weirdest laws I have heard of. Does it have something to do with having to remove the overarm guard to make your Box Joint passes?
before i built my router table i tried making finger joint jigs for my tablesaw (without dado blade, because thats illegal in europe) but i couldn t get good results.
wich is weird because it s the exact same principle as router table jigs!
- Greedo
View MrFid's profile
MrFid
874 posts in 1874 days
#11 posted 01-08-2016 03:32 PM
Here’s mine. Works great as long as you take the time to set up the jig properly each time.
http://lumberjocks.com/projects/88037
There’s also the information to the book where I found the pattern. Enjoy!
-- Bailey F - Eastern Mass.
