Diablo saw blades
Forum topic by RJweb posted 01-11-2018 01:07 AM 1256 views 1 time favorited 24 replies Add to Favorites Watch
View RJweb's profile
RJweb
124 posts in 2834 days
01-11-2018 01:07 AM
Topic tags/keywords: tablesaw
Has anyone purchased the diablo brand of table saw blade from Home Depot, if so were you happy with the performance, thx RJ
-- Life Begins @ 190 MPH
24 replies so far
View John Smith's profile
John Smith
1482 posts in 364 days
#1 posted 01-11-2018 02:06 AM
it was a toss up – but I bought the twin pack of Avanti when they were
on sale and am very satisfied with it overall.
-- I started out with nothing in life ~ and still have most of it left.
View jonah's profile
jonah
1925 posts in 3500 days
#2 posted 01-11-2018 02:08 AM
They’re adequate blades. Not near the best, but not the worst either. There are definitely some better deals out there for blades, depending on the size.
View Knockonit's profile
Knockonit
477 posts in 404 days
#3 posted 01-11-2018 02:09 AM
I purchased the avanti twin pack also, and well, its ok, not as fine a cut in hardwood as i’d expected.
i do have a couple diablos, while i have not used any on TS, i do have on my 8-1/4 hitachi sliding compound that i cut all stuff with, am happy, and after what seems like an eon, it is still sharp, cut a lot of walnut, oak, maple, sapele, some alder, but mostly the hardwoods.
I find some of the major blade manuf. quality control sometimes falls off the wagon, i’ve had upper end blades be awesome and then its replacement of same quality and name, be a dog.
just the luck of the draw. i believe
good luck, fella can’ thave too many dust makers around.
Rj
ON another note, i did buy into a HF 50 tooth, and by golly was pleasantly surprised, i only cut a few pieces, but consistant cut, fairly smooth, i pulled it and stashed it for when i need a quick fix, wanna say it was on sale for like 23 bucks or so. I think it will go far.
Rj
View alittleoff's profile
alittleoff
541 posts in 1478 days
#4 posted 01-11-2018 03:09 AM
Just bought a 1040x and a 1080x. I’m using them both right now. The 1040 I really haven’t had time to really tell how it’s doing, but the 1080 is a real good blade.
Gerald
View TheFridge's profile
TheFridge
10739 posts in 1688 days
#5 posted 01-11-2018 03:14 AM
They’re good for the money and easily accessible.
View JADobson's profile
JADobson
1287 posts in 2313 days
#6 posted 01-11-2018 03:29 AM
I have a diablo blade in my circular saw. It’s framed my basement and still going. For $17 cad I’m happy.
-- No craft is very far from the line beyond which is magic. -- Lord Dunsany — Instagram @grailwoodworks
View AlaskaGuy's profile
AlaskaGuy
4793 posts in 2511 days
#7 posted 01-11-2018 04:03 AM
Go for the Diablo good blade for the money. When I worked for the school district I had to use them sometimes. The make a good cut but will dull a bit faster that the Frued. They also have less carbide for less sharpening.
For what it’s worth.
Here is a responce provided by a Freud tech guy a number of years ago.
All Freud blades come from the same machines in the same manufacturing plant. We make our own micrograin carbide in numerous formulations that represent various degrees of hardness. The carbide is selected depending on the intended application (the hardest is used for laminates the softest for ripping) as are the tooth angles and tooth quantity. The steel for the blade plates is all the same grade. The brazing is all the same. The key differences between the 3 main lines of Freud blades are:
The LU/LM Industrial blades have the thickest tips for the most resharpenings and are generally full kerf. We also offer the most selection of specialty blades in this line. These have the most appeal to professionals who need to get a lot of sharpenings out of a blade and to artisans who need specialty blades for their projects.
The TK and Diablo lines are very similar. Both are thin kerf blades and the tip thickness is the same. The key difference is in the way we market these blades. The Diablo line has blades intended for purposes like framing, siding, decking and general home improvement and is packaged and promoted in ways that appeal to contractors and DIYers. The TK line has blades for similar purposes (as well as laminate blades) but is sold with different or no coating and different packaging and POP material to appeal more to woodworkers.
Do professional woodworkers shop for blades at Home Depot? Probably some do and they can get excellent performance from a Diablo blade for a lot of their uses but with a shorter overall life (and lower cost) due to the tip thickness. Same with the TK blades at Lowe’s.
Why not compare a TK or Diablo blade to Forrest? Consider this analogy: Toyota cars and Lexus cars share a lot of the same components and are made by the same company. Would you compare a Camry with a BMW?
We make a fourth line of blades (F400 Premier series) that is very similar to the WWII and is priced similarly. The difference between ours and Forrest’s is that ours is made by computer controlled, super modern equipment and theirs is made by hand. Both methods have advantages and disadvantages but I leave the final verdict to the consumer.
Charles M
Freud, Inc.
I’m sure many of you remember when Charles M used to frequent the online woodworking forums a few years back.
woodbutcherbynight
5709 posts in 2611 days
#8 posted 01-11-2018 04:11 AM
I have them in use with my circular saw. Great for framing, rough cutting ply down to size for the TS and such. For the price not bad. I have cut aluminum diamondplate with them and to my surprise they did very well.
View Ripper70's profile
Ripper70
1164 posts in 1110 days
#9 posted 01-11-2018 04:28 AM
+1 on the circular saw blades. Mine have served me well and, I believe, are a good value.
-- "You know, I'm such a great driver, it's incomprehensible that they took my license away." --Vince Ricardo
View mel52's profile (online now)
mel52
587 posts in 466 days
#10 posted 01-11-2018 04:47 AM
I have them on just about all cutting tools in my shop from skill saws, 2 different miter saws ( one being a 12” ), and on my table saw. I also have a lot of different tooth counts. My go to blade on my table saw is a 10 inch 50 tooth combo blade. I have noticed that they don’t seem to pick up any crap on the blades do to the red coating on them. I have never had a problem with any of them for any reason. The 50 tooth combo cuts both rip and crosscut very smoothly. If I have a lot of ripping, I do change to a ripping blade for quicker cutting. I have a 90 tooth blade that cuts plywood flawlessly. I am sure there are better blades out there, but for the money and how well they work I will stick with them.
-- MEL, Kansas
View Walker's profile
Walker
150 posts in 674 days
#11 posted 01-11-2018 06:10 AM
I also use the diablo combo cross/rip cut on my 10” table saw. My budget is always small, so I’ve never tried any of the $100+ blades. I also have a cheap contractors TS, and the diablo makes the saw 100x better. I suspect if you have a very expensive table saw, then a very expensive blade will make a difference. But with a cheap table saw, an expensive blade won’t overcome the issues as much as you’d want it to, a cheap blade will amplify the issues, but a medium blade (like the diablo) hits the sweet spot of improving performance enough without breaking the bank.
I also use a diablo blade in my circular saw, but I don’t use that too much. It’s definitely better than the OEM blade.
-- ~Walker
View knotscott's profile
knotscott
8148 posts in 3577 days
#12 posted 01-11-2018 11:53 AM
At one time the Diablo blades were made in Italy from the same materials, on the same machines, and to the same standards as the Freud Industrial line….they just had less carbide and offered fewer choices. Not sure if that’s still true, as I’ve heard some claims that at least some of the Diablo line is now made in China.
The Irwin Marples, CMT ITK Plus, Tenryu Rapid Cut, and DeWalt Precision Trim series are all decent value for performance and price. I would not recommend the Avanti or Avanti Pro blades for fine woodworking…just not enough better than a stock OEM blade to bother with.
AlaskaGuy
#13 posted 01-11-2018 07:18 PM
At one time the Diablo blades were made in Italy from the same materials, on the same machines, and to the same standards as the Freud Industrial line….they just had less carbide and offered fewer choices. Not sure if that s still true, as I ve heard some claims that at least some of the Diablo line is now made in China.
- knotscott
I don’t know how updated Freud keep their web site but they still calm they are made in Italy Switzerland.
http://www.freudtools.com/index.php/faq#55
I emailed Freud back in Dec of 2017 about where there router bit were made. This is what freud said then
To r_mccomas@yahoo.com
CC Customer Service (PTNF/LOG)
12/04/17 at 9:57 AM
This message contains blocked images.
McCracken Charles (PTNF/LOG2) <cmccracken>
All Freud router bits are produced in our factory in Udine, Italy.
Please let me know if I can be of further assistance.
Best regards,
Charles McCracken
Operations Technical Manager
Freud America, Inc
218 Feld Ave
High Point, NC 27263
To: Customer Service (PTNF/LOG) <customerservice>
Subject: Frued made in china
According to this web page the Freud Lock Miter bit is made in China. Is that true? Is that a misprint?
I don’t believe any of their saw blades are made in China either. To say that they are and not know for sure could damage their reputation. Not good IMO.
knotscott
#14 posted 01-11-2018 07:26 PM
Charles M’s info has been very reliable IME…we just dont’ hear from him much anymore due to other work priorities, but 12/04/17 is pretty recent info.
RJweb
#15 posted 01-11-2018 07:32 PM
I want to thank everyone with this information, I am going to go get the Diablo, thx again, RJ
