The most accurate square I have.
« back to Hand Tools forum
Forum topic by Carloz posted 01-10-2018 03:02 PM 1195 views 0 times favorited 8 replies Add to Favorites Watch
View Carloz's profile
Carloz
1147 posts in 614 days
01-10-2018 03:02 PM
I kept buying all kind of square tools from big box stores, Sears and so on, like combination square, speed square etc etc. None of them was actually square and would deviate a millimeter or so at the end.
The one that I hope finally stopped my buying streak is this one. I tested it with a feeler gauge and could not insert the smallest blade at any of the ends both at 90 and 45 degrees. It saved me some money by not letting me buy some super expensive stuff and paid for itself on the first use, when trying to make mitered panel doors where exact 45 cut is crucial.
8 replies so far
View LittleShaver's profile
LittleShaver
326 posts in 642 days
#1 posted 01-10-2018 05:03 PM
Another good buy from HF.
I also use drafting squares and have found them very reliable.
After watching a Woodwright Shop, I started making my own. Fun project to use up some scraps and they make neat gifts.
With the exception of dial indicators, Wixie gauges and feeler gauges, I’ve found that I can make most of my marking and layout tools.
For most of my projects, I prefer a story stick rather than a scale or tape.
-- Sawdust Maker
View Andybb's profile
Andybb
1015 posts in 626 days
#2 posted 01-10-2018 05:08 PM
-- Andy - Seattle USA
View Gene Howe's profile
Gene Howe
10521 posts in 3451 days
#3 posted 01-10-2018 05:21 PM
- Andybb
View Holt's profile
Holt
257 posts in 2651 days
#4 posted 01-11-2018 02:55 PM
I usually buy those plastic drafting triangles, they always seem to be dead on. I use them to validate and correct the squares with which I work.
-- ...Specialization is for insects.
View John_H's profile
John_H
175 posts in 1728 days
#5 posted 01-11-2018 10:00 PM
I have a Woodpecker 26” x 16” precision framing square that cost around $200 and I have a $25 Irwin Framing square that is just as accurate
http://www.acmetools.com/shop/tools/irwin-1794447
The easiest way to check is to just draw a line, flip it over and draw another line. You can ‘tweak’ a framing square if it is out of square, no reason to buy another one:
https://www.youtube.com/watch?v=z2BFuDpM29w
View Ron Aylor's profile
Ron Aylor
2633 posts in 670 days
#6 posted 01-11-2018 10:17 PM
Now take you new square and tune up the rest!
-- Ron in Lilburn, Georgia.  https://ronaylor.wordpress.com
View MrRon's profile
MrRon
4793 posts in 3266 days
#7 posted 01-12-2018 09:10 PM
- Carloz
How could you tell if the square was 90° or 45° with a feeler gauge? All the feeler gauge would tell you would be if the edge was straight or not. To check for a 90°, you have to check it against something that is in fact 90°, like a precision combination square; the same for 45°.
View cabmaker's profile
cabmaker
1735 posts in 2831 days
#8 posted 01-12-2018 09:36 PM
sorry….. no plastic squares on my job
