How to reduce the size of a template or pattern
Forum topic by AlaskaGuy posted 01-08-2018 11:42 PM 810 views 0 times favorited 22 replies Add to Favorites Watch
View AlaskaGuy's profile
AlaskaGuy
4820 posts in 2515 days
01-08-2018 11:42 PM
In the drawing below you see a pattern I made some years ago for feet on a dresser. I now would like to use the same pattern for a Pennsylvania Spice Box. I need to reduce this patter to approximately 2 & 5/8 tall and 4to 41/2 inches wide (in proportion to the reduction in height.
22 replies so far
View tomsteve's profile
tomsteve
880 posts in 1425 days
#1 posted 01-08-2018 11:45 PM
personally id take it to the local copy shop, slap it in their scanner,copier, make a copy, then use the copy to dink with the size on the copier- they usually have the ability to enlarge or shrink by percentage
View MrUnix's profile
MrUnix
7053 posts in 2404 days
#2 posted 01-09-2018 12:14 AM
What graphics abilities do you have? Should be able to make a pattern from the photo in most of the better ones. If you have a vector based package, you can scale it seamlessly to any size you want. If you have a bitmap based system, you can re-size, but extremes may inject some pixelization.
View Rayne's profile
Rayne
1109 posts in 1745 days
#3 posted 01-09-2018 12:24 AM
Would the continuous use of a rabbeting bit be able to create that pattern smaller and smaller till it meets your size requirement?
View LesB's profile
LesB
1869 posts in 3648 days
#4 posted 01-09-2018 12:55 AM
Most computer picture programs have features that allow you to adjust the size of the image. So if you can scan it and open the image with a photo retouching program you can reduce or enlarge the size. Then print it out…..as long and it doesn’t exceed the size of a legal piece of paper.
The alternative is to use a pentograph…..available from multiple sources.
-- Les B, Oregon
View Gilley23's profile
Gilley23
489 posts in 587 days
#5 posted 01-09-2018 12:57 AM
Take it to a copy place and reduce the size to several different %’s, then take it home and use whichever works best for you. It’ll cost you maybe $3.
View waho6o9's profile
waho6o9
8525 posts in 2782 days
#6 posted 01-09-2018 01:00 AM
Not sure how they work but proportional dividers might get it done.
However, I go to the local print shop and it’s done….
View eflanders's profile
eflanders
318 posts in 2056 days
#7 posted 01-09-2018 01:07 AM
Cutout the pattern out of board. Place a flat washer inside the cut out. Place a pencil inside the i.d. of the flat washer and trace the pattern. Different size washers will yield different size patterns.
View Grandpa's profile
Grandpa
3261 posts in 2881 days
#8 posted 01-09-2018 01:36 AM
If you are using a windows based computer, put this into WORD. Select the part and right clisk on it. You can adjust the size there.
View BobAnderton's profile
BobAnderton
283 posts in 2996 days
#9 posted 01-09-2018 02:01 AM
Are you familiar with Matthias Wandel’s Bigprint program? If you follow the link I put in you’ll see he sells it for $22, but you could use the free eval version too I think for what you’re doing. You import the picture and then define any feature or dimension you want and tell it what the size of that feature or dimension is. It will then allow you to print it out in the defined size with alignment lines to match the pages up if it spans multiple pages.
It comes in handy in a lot of instances, even though for any one job it may seem hard to justify the expense. If you’ve got a picture of anything, you can print it out scaled to any size you want.
-- Bob Anderton - Austin, TX - Nova 3000 lathe, Alaskan Mark III mill, Husqavarna Saw
View Knockonit's profile
Knockonit
479 posts in 407 days
#10 posted 01-09-2018 02:19 AM
use a template, light behind it, move light one direction or next to create shadow,size will depend on light location and distance
Rj
LOL, sorry i see shrink it, my bad.
make a copy on copier and decrease it thru the setting, my copier will make them smaller
View jerryminer's profile
jerryminer
944 posts in 1647 days
#11 posted 01-09-2018 02:22 AM
Put the template in a copy machine and reduce to 58% (2-5/8 / 4-1/2 = .5833)
View Loren's profile
10477 posts in 3853 days
#12 posted 01-09-2018 02:26 AM
Crop the shape in a drawing program and
resize the image to the dimension you want.
View EarlS's profile
EarlS
1957 posts in 2553 days
#13 posted 01-09-2018 02:46 AM
Throw it in the washer on hot and dry it on hot cycle too. Should shrink a couple of sizes. M wife does that all the time with clothes.
Barring that, if you can get it into SketchUp you can scale it. BTW – SketchUp is free.
AlaskaGuy
#14 posted 01-09-2018 04:08 AM
- jerryminer
May I can do that with my all in one printer, it’s scans, copies, and prints.
Thanks.
View Notw's profile
Notw
672 posts in 1959 days
#15 posted 01-09-2018 03:33 PM
if the all in one printer doesn’t work for you send me the scan and i will redraw it for you
