Can my 110v Jobsite Table Saw be Rewired for 220v?
Forum topic by GraceAndDrew posted 01-08-2018 10:15 PM 1368 views 0 times favorited 16 replies Add to Favorites Watch
View GraceAndDrew's profile
GraceAndDrew
34 posts in 244 days
01-08-2018 10:15 PM
Topic tags/keywords: tablesaw
I have a Delta jobsite table saw which I use in my garage shop only. I would like to change it to 220v if possible and I have 220 in my garage.
If it is possible, what is the wiring configuration?
Thanks!
-- Grace & Drew Woodworking, http://graceanddrew.com
16 replies so far
View MrUnix's profile
MrUnix
6766 posts in 2224 days
#1 posted 01-08-2018 10:40 PM
Should indicate how to wire it on the motor data plate. Will be marked as “low voltage” (120v) and “high voltage” (240v). Switch the wires as indicated, and replace the plug on your supply wiring. If your data plate only indicates a single voltage, then it’s not possible.
View AlaskaGuy's profile
AlaskaGuy
4205 posts in 2334 days
#2 posted 01-08-2018 10:48 PM
Providing a model number would help.
Curiosity, If I’m right that a 15 AMP saw. What would the advantage be to switch to 240
View crank49's profile
crank49
4032 posts in 2996 days
#3 posted 01-08-2018 10:51 PM
Depends on what job site saw you have.
If you mean a portable job site saw, where the blade mounts directly on the motor shaft, the answer is “Probably Not”
GraceAndDrew
#4 posted 01-08-2018 11:01 PM
The advantage would be lower amps, especially on start up. The amps spike at start up and trip the breaker. It’s not a big deal but I have a 220 outlet so I would like to use it if possible.
MrUnix
#5 posted 01-08-2018 11:05 PM
Depending on what model you have – you may just have one of those magic Delta motors that are 1.5hp@120v, and 2hp@240v. Check the motor data plate – the dual hp motor looks like:
Notice two different horsepowers listed, and the FLA for 240v is more than half that for 120v. Dual voltage wiring diagram is on the bottom.
View WhyMe's profile
WhyMe
1025 posts in 1586 days
#6 posted 01-08-2018 11:14 PM
In most cases it not worth changing a saw that is running on 120V over to run on 240V. What is your reason for wanting to do the change to 240V?
View knotscott's profile
knotscott
8057 posts in 3401 days
#7 posted 01-08-2018 11:37 PM
Most jobsite saws have a universal motor. If your Delta has a universal motor, won’t it spin at twice the RPM if you switch to 240v (aka 220v)?
View jonah's profile
jonah
1727 posts in 3324 days
#8 posted 01-09-2018 12:11 AM
Most jobsite saws have a universal motor. If your Delta has a universal motor, won t it spin at twice the RPM if you switch to 240v (aka 220v)?
- knotscott
No. Everything depends on the design of the motor. There are plenty of universal motor designs that operate in both the US (120V/60Hz) and Europe (mainly 220V/50Hz). I don’t know how common such things are in tools, but they’re all over the place.
AlaskaGuy
#9 posted 01-09-2018 12:17 AM
- WhyMe
He answered that above. I going to take another guess. His 120 outlet are 15 AMP circuits.
WhyMe
#10 posted 01-09-2018 12:51 AM
- WhyMe
- AlaskaGuy
Somehow I overlooked his comment about the startup tripping the breaker.
GraceAndDrew
#11 posted 01-09-2018 03:53 AM
Thanks everyone. I couldn’t check today but will tomorrow.
I have a 20 amp breaker but there is too much on it including a shop vac and more. The table saw trips it often. But, I have an empty 220 circuit…good problem to have I guess.
View Holt's profile
Holt
258 posts in 2654 days
#12 posted 01-09-2018 01:51 PM
If the 240 volt outlet has four connectors (and they are all wired) then you could break out a 120 volt circuit.
Thanks everyone. I couldn t check today but will tomorrow.
- GraceAndDrew
-- ...Specialization is for insects.
View Siv's profile
Siv
61 posts in 595 days
#13 posted 01-09-2018 03:22 PM
How about using a stepdown transformer? I see 2000W stepdown transformers for sale for around $70.
jonah
#14 posted 01-09-2018 04:12 PM
You can always replace the 240V breaker and receptacle with a 120V one. If you’ve never replaced a breaker before, do it with the main power off (either by flipping the main breaker or by pulling the meter outside), but once you have experience with it, you can do it quite easily and safely with the main breaker on.
In fact, I would go that route before I messed around with the saw, since it’s likely not designed for use on 240V. None of my routers or circular saws are capable of operating on 240V.
View ArtMann's profile
ArtMann
950 posts in 841 days
#15 posted 01-09-2018 07:28 PM
A step down transformer will not supply the required neutral. It is extremely unsafe to run load current through a safety ground wire.
- Siv
