SawStop PCS measurement
Forum topic by optimusprimer92 posted 01-08-2018 09:59 PM 795 views 0 times favorited 17 replies Add to Favorites Watch
View optimusprimer92's profile
optimusprimer92
39 posts in 766 days
01-08-2018 09:59 PM
Looking at a SawStop PCS but need to know what the height from floor to TOP of table is. Anyone who has one know the actual measurement?
17 replies so far
View Kazooman's profile (online now)
Kazooman
1240 posts in 2156 days
#1 posted 01-08-2018 10:02 PM
34” as per the owner’s manual and confirmed with my tape measure.
Note that is for the saw without any base or the PCS mobile base that allows the saw to sit directly on the floor. I do not have the ICS base that can be adapted to fit the PCS saw, but I believe that it may add a little height.
optimusprimer92
#2 posted 01-08-2018 10:17 PM
Thank you Kazooman. I wasn’t sure if the height was accurate per the website. I have a Delta and the website says 35” but it is actually 37. Go figure.
View BrettLuna's profile
BrettLuna
57 posts in 766 days
#3 posted 01-08-2018 10:26 PM
I recently assembled my PCS with the ICS base. I’ll tray to remember to measure it when I get home…unless someone beats me to it.
-- Brett — Peters Creek, Alaska
Kazooman
#4 posted 01-08-2018 10:30 PM
Thank you Kazooman. I wasn t sure if the height was accurate per the website. I have a Delta and the website says 35” but it is actually 37. Go figure.
- optimusprimer92
Glad to help. I used to swear by Delta machines and then I learned to swear at them. Once they sold out I got burned several times on the lack of replacement parts.
View buckbuster31's profile
buckbuster31
254 posts in 719 days
#5 posted 01-08-2018 10:49 PM
I just went from a delta 36-725 to a sawstop pcs with ics base. It definitely sits a couple inches lower than my delta did, but not noticeable. I just know that my outfeed table no longer works, which isn’t a big deal. I will build a new or cut the legs down.
optimusprimer92
#6 posted 01-08-2018 10:52 PM
I just went from a delta 36-725 to a sawstop pcs with ics base. It definitely sits a couple inches lower than my delta did, but not noticeable. I just know that my outfeed table no longer works, which isn t a big deal. I will build a new or cut the legs down.
- buckbuster31
Funny you say that because that is the EXACT reason I asked this question. My outfeed is set up for the Delta so I will have to figure something out. The problem is that my outfeed is a Paulk style workbench, so it’s heavy. What are your feelings on going from the Delta to the SS?
View jonah's profile
jonah
1927 posts in 3502 days
#7 posted 01-08-2018 11:02 PM
You can always assemble the Sawstop on a platform (a couple of pieces of plywood, really) if you need it higher.
Kazooman
#8 posted 01-08-2018 11:10 PM
- jonah
I was thinking along those lines as well, but then there is the problem of moving the saw when needed. If the desired additional height is not too great, I can imagine using the ICS base with appropriate spacers to bring the saw up to the desired height. Probably already been discussed on the forum.
jonah
#9 posted 01-08-2018 11:30 PM
I don’t know what the base of the Sawstop measures at, but it might fit perfectly on the Delta mobile base. It isn’t as nice as the PCS/ICS mobile bases, but it’s perfectly usable.
BrettLuna
#10 posted 01-09-2018 01:02 AM
I just went from a delta 36-725 to a sawstop pcs with ics base. [...]
- buckbuster31
You and me both! Same old saw, same new saw and base. The Delta gave me 3½ years of faithful service. Now, it belongs to one my coworkers who came over to help me unload the Sawstoop.
View Rayne's profile
Rayne
1109 posts in 1743 days
#11 posted 01-09-2018 01:07 AM
- buckbuster31
- BrettLuna
We should create a Delta 36-725—> SawStop PCS club. lol. I did the same thing recently. The SawStop PCS with ICS Base is 34-3/8” tall. Definitely lower than my workbench now, so I had to move it altogether. I couldn’t cut enough of the base to make this a viable solution. I have to build a new outfeed eventually.
buckbuster31
#12 posted 01-09-2018 03:12 AM
- buckbuster31
Funny you say that because that is the EXACT reason I asked this question. My outfeed is set up for the Delta so I will have to figure something out. The problem is that my outfeed is a Paulk style workbench, so it s heavy. What are your feelings on going from the Delta to the SS?
- optimusprimer92
34” as per the owner s manual and confirmed with my tape measure.
- Kazooman
- Kazooman
- buckbuster31
- optimusprimer92
There is absolutely no comparison. The delta was ok at best. I made a lot of money with it, but it was very underpowered. I bought high dollar saw blade after another to try to make it cut better…. I no longer worry. This sawstop is a beast
buckbuster31
#13 posted 01-09-2018 03:13 AM
- buckbuster31
- BrettLuna
We should create a Delta 36-725—> SawStop PCS club. lol. I did the same thing recently. The SawStop PCS with ICS Base is 34-3/8” tall. Definitely lower than my workbench now, so I had to move it altogether. I couldn t cut enough of the base to make this a viable solution. I have to build a new outfeed eventually.
- Rayne
Apparently a common theme here! We were all suckers for the biggest saw lowes sold! Lol
Rayne
#14 posted 01-09-2018 03:25 AM
- buckbuster31
- BrettLuna
- Rayne
- buckbuster31
Can’t say sucker as it was a great workhorse. Great value for the money at the time and it seems we all bought it around the same time and moved on around the same time. lol. Now we’re all facing the same issues. haha.
buckbuster31
#15 posted 01-09-2018 03:58 AM
- buckbuster31
- BrettLuna
- Rayne
- buckbuster31
Can t say sucker as it was a great workhorse. Great value for the money at the time and it seems we all bought it around the same time and moved on around the same time. lol. Now we re all facing the same issues. haha.
- Rayne
I agree. I loved the delta when I got it… but I didn’t realize how little power it actually had until I got a 3hp
