Blower for shop-built air cleaner
Forum topic by justinwdemoss posted 03-19-2011 11:49 PM 6065 views 1 time favorited 17 replies Add to Favorites Watch
View justinwdemoss's profile
justinwdemoss
148 posts in 2863 days
03-19-2011 11:49 PM
Topic tags/keywords: blower air air-cleaner cleaner dust dust filtration filtration shop shop-built
I have been looking at several blogs and projects of other jocks and have decided I’m overdue to throw together a shop built air cleaner. I have seen that most folks use a blower from a furnace and I have a call in to a local guy who will get back to me on Monday. However, I did see one jock that used a small blower similar to an electric leaf blower. He had no posting as to how it worked over the long term. He stated that the blower was rated to move just over 200 cfm of air. I have an older 1 hp Paramount leaf blower that hasn’t sold in the last three garage sales. Does anyone have any thoughts on the pros or cons of using that blower? I am sure that that it will more far less air, but I have a small shop (1 bay in a two-car garage) and I am a only a hobbyist woodworker. My main interest in this idea is that I have this blower and using it will likely save me $20-50.
-- Justin in Loveland, OH
17 replies so far
View lew's profile
lew
12019 posts in 3723 days
#1 posted 03-20-2011 02:51 AM
Justin,
If you have a local Vocational School close by, call them and ask to speak to the HVAC instructor. Bet he would give you a furnace blower/motor in exchange for a bag of cookies for his students.
Lew
justinwdemoss
#2 posted 03-20-2011 02:54 AM
Not a bad idea, thanks Lew. I just found an older unit on craigslist. The squirrel cage is belt driven and comes with a 110v 1/3hp motor for $20. I may go that route, but still wonder if the leaf blower idea can work.
View Grandpa's profile
Grandpa
3259 posts in 2643 days
#3 posted 03-20-2011 03:00 AM
Pay the $20 and never look back. That will last forever
View hairy's profile
hairy
2661 posts in 3500 days
#4 posted 03-20-2011 03:31 AM
I have one left , if you can’t get one.
-- My reality check bounced...
TopamaxSurvivor
18249 posts in 3644 days
#5 posted 03-20-2011 03:32 AM
If it moves enough air, it should work.
View ChrisBunker's profile
ChrisBunker
15 posts in 2643 days
#6 posted 03-20-2011 05:17 PM
I would think the leaf blower would be very loud.
View sh2005's profile
sh2005
97 posts in 3205 days
#7 posted 03-20-2011 05:59 PM
I have been thinking about building a cleaner as well. One fan I have been considering is this one from HF . It’s pricey, especially if u compare it with a used one. But, it seems like it moves a lot of air. I am not sure whether this fan can be used, so I thought I bring it up.
View DIYaholic's profile (online now)
DIYaholic
19597 posts in 2643 days
#8 posted 03-20-2011 06:18 PM
You can get a used furnace blower/squirrel cage for less or even free, that will also have greater CFMs.
View Dusty56's profile
Dusty56
11819 posts in 3656 days
#9 posted 03-20-2011 06:53 PM
Go with the furnace set-up…..the leaf blower is all about creating high velocity wind versus moving a large volume of air quietly.
justinwdemoss
#10 posted 03-20-2011 11:28 PM
Thanks for all of the input. I the noise was my first concern with the leaf blower. I has a call in with the HVAC guy and hope to get something that way. Is there any trick to wiring a furnace blower up? I understand they can have multiple speeds.
DIYaholic
#11 posted 03-20-2011 11:34 PM
The one I have came with a variable speed switch. I would say, it depends upon the motor that comes with the blower (others should/do know better than I). Your HVAC guy may be able to answer that question. You should also consider wiring in a multi-hour timer. This way you can leave it on after you leave the shop.
justinwdemoss
#12 posted 03-21-2011 02:26 AM
Just got back from checking out the blower(s) from the CL post. Both are very dirty, but after a good cleaning should be perfect. They are both belt driven with 1/4 hp motors. The larger blower fan was setup with a newer motor that shut off after about 30 sec of run time. The seller said he wouldn’t sell something that he knew was broken, so he took $20 for the smaller one that ran great, and gave me the larger one with the “bad” motor. I plan to clean them up, replace the belts with link belts. I have a 1/4 hp motor from an old lathe. So now I have the makings for two running furnace blowers.
Anyone ever seen an air cleaner with two blowers? I will likely just use one and sell the other, but hey if you know of someone that used to blowers and thought a lot of it. I have a small shop so, one will likely be enough.
TopamaxSurvivor
#13 posted 03-21-2011 04:05 AM
Most air handling units in commercial buildings have a supply fan and a return fan. Not reason you couldn’t too ;-)) If you really want to clean the air, you could run 2 or 3 filters in series with the 2 fans separated by one or 2 of the filters.
View David "Lucky Dawg" Brown's profile
440 posts in 2960 days
#14 posted 03-21-2011 05:09 AM
go to my projects page and look at the air filter in there!
I paid about twenty five bucks and some scraps
Walmart-filter 4 something -box fan 14 something
Poor mans air filter it really works im in a 10’ x 16’ shed!
yes very cramped!!
-- dumpster diver delux
TopamaxSurvivor
#15 posted 03-21-2011 08:13 AM
Blower motors normally have a lead for each speed. You need to power them one at a time to select a speed.
