Built In Shelving - Will not fit Stereo Reciever
Forum topic by Chuck1818 posted 01-08-2018 01:47 PM 2235 views 0 times favorited 41 replies Add to Favorites Watch
View Chuck1818's profile
Chuck1818
5 posts in 315 days
01-08-2018 01:47 PM
Bad measurement in design (width of the receiver was not accounted for in trim). The width of the opening is large enough for the receiver but the trim pieces make the opening 3/8” too small to fit receiver (right side). Looking for suggestions to fix this without tearing entire thing apart. All trim is glued and screwed with pocket holes from the backside.
41 replies so far
View mayday3374's profile
mayday3374
21 posts in 427 days
#1 posted 01-08-2018 01:58 PM
Oopsie… can u drop a shelf and make room some to tip stereo into place? Can the shelf be pulled out and stereo installed from back? Just double checking these options. You could maybe run a router along the sides with a flush trim bit, cutting back the 3/8 from the face frame. Clean corners with chisel, sand and touch up with paint. U could rip new 3/8 strips, pin back in place, paint to match, if u need to keep the trim the same to match up with rest of cabinet. See what others suggest.. good luck
View splintergroup's profile
splintergroup
2341 posts in 1396 days
#2 posted 01-08-2018 02:06 PM
I had a similar problem long ago, about the same size mismatch (it was a rental apartment)
Ended up unscrewing the top of the receiver and lifting it off the main unit. I could then tilt the receiver into place and slide the lid back on.
Royal PITA, but it worked 8^)
View Firewood's profile
Firewood
487 posts in 1808 days
#3 posted 01-08-2018 02:09 PM
DOH! I hate it when that happens. How is the back attached? Can you remove it and slide it in and then reattach? It looks like you plugged the pocket holes, so that would make it even more difficult to remove the trim.
Worst case is you cut a hole in the back or buy a smaller receiver.
-- Mike - Waukesha, WI
View Lazyman's profile
Lazyman
2559 posts in 1561 days
#4 posted 01-08-2018 02:15 PM
And it won’t fit through the opening diagonally? Can you simply cut that strip on the right side off, slide the receiver in and then attach a new one (for aesthetics) with some brads or screws?
Chuck1818
5 posts in 315 days
#5 posted 01-08-2018 02:22 PM
Here is a better photo of the shelving as a whole. The unit was built separately then set into a recess in the concrete wall. All of the pocket holes are on the backside.
View tomsteve's profile
tomsteve
844 posts in 1393 days
#6 posted 01-08-2018 03:01 PM
can ya tilt the receiver to get it through the trim and set it inside?
Chuck1818
5 posts in 315 days
#7 posted 01-08-2018 08:20 PM
No it is too tight of a fit to tilt it.
View Loren's profile
10477 posts in 3822 days
#8 posted 01-08-2018 09:38 PM
Cut out the trim. I might use a hand saw
and a chisel to get most of it out and then
finish it off flush with a router using a
flush trim bit.
View pintodeluxe's profile
pintodeluxe
5783 posts in 2987 days
#9 posted 01-08-2018 09:46 PM
I’d be shopping for a new receiver.
Smitty_Cabinetshop
15649 posts in 2792 days
#10 posted 01-08-2018 09:52 PM
Remove this piece?
And cut the divider behind it too, of course. Not sure what that does to the integrity of the remaining shelf piece, but it may not be an issue. If it is, retain some portion of the divider? Or even remove face trim piece circled, then cut divider and slide it over (left) one inch. insert receiver, replace face trim with screws to divider. Not the ultimate fix, but better than tearing out?
View BenjaminNY's profile
BenjaminNY
131 posts in 1576 days
#11 posted 01-08-2018 09:53 PM
I feel like I’m not understanding something, the opening is large enough but there’s a small piece of 3/8 trim you have to get past to make it fit? It would seem like putting it in diaganol should do the trick…?
If not, flush rout off the trim and then make a new piece of trim
View Mike_in_STL's profile
Mike_in_STL
708 posts in 708 days
#12 posted 01-08-2018 10:13 PM
Shopping for a new receiver likely won’t work. If it’s a quality home theater receiver, there is an industry pseudo-standard size. Having worked in the home theater industry, we always told the carpenters about minimum clearances needed first.
I want to know, can the unit be pulled out of the recess to gain access from the back panel? That would be the way we would have addressed the issue when I was doing installs. Otherwise, the face frame has to be wrecked.
-- Sawdust makes me whole --Mike in STL
View AlaskaGuy's profile
AlaskaGuy
4633 posts in 2483 days
#13 posted 01-08-2018 10:20 PM
flush trim bit.
- Loren
This , use a router for most of it, finish with saw, chisel, or multi tool works well.
View Kazooman's profile
Kazooman
1214 posts in 2126 days
#14 posted 01-08-2018 11:07 PM
Lots of good suggestions, but I think this could get pretty ugly. Any solution that lets you get the receiver in place and restore the trim is just setting you up for another round of this trouble down the road. I know that I need access to the back of my AV equipment on occasion as technology advances and new gear is acquired. For example, swapping out the DVD player for a Blue-Ray unit required swapping a lot of cables to keep all of the components happy with each other. I have stood on my head with a mirror and flashlight in hand to know where this all leads.
As tough as it may seem, I recommend going with one of the suggested fixes that will allow you easy access to the back of the receiver in the future. Unfortunately, “simply” removing the trim around that one opening is probably not going to be to your liking since I assume that the other openings also have the trim. You may have to remove the trim on the right side, and take out the center divider, shelf and trim on the left and then install a new divider and shelf to bring everything back into a common theme.
Or….. Put the receiver on the shelf above the intended opening and use the original space for another purpose.
View knotscott's profile
knotscott
8140 posts in 3549 days
#15 posted 01-08-2018 11:28 PM
The easiest solution is to put the receiver on the shelf above.
Or you could sell the receiver and replace it with an amp or integrated amp that will fit. Amazon actually has some Asian tube amps that will fit that are affordable and sound a whole lot better than most solid state receivers.
showing 1 through 15 of 41 replies
