Method of securing table top to legs/base question
Forum topic by BoilerUp21 posted 01-08-2018 12:41 PM 1241 views 0 times favorited 8 replies Add to Favorites Watch
View BoilerUp21's profile
BoilerUp21
97 posts in 882 days
01-08-2018 12:41 PM
I am working on a 4 person dining table and had planned to leave the legs (4 corners of each leg) about 1/2” long and cut matching shallow 1/2” mortises into the table top for them to seat into. I do not want to glue this so it can be taken apart easily, but I need to secure the top to the legs/apron.
Does anyone have suggestions on how to fasten this? I can always use pocket holes and secure the top to the apron, but I like the idea of not having any mechanical fasteners.
Thanks in advance for any advice!
8 replies so far
View ArtMann's profile (online now)
ArtMann
1041 posts in 931 days
#1 posted 01-08-2018 12:53 PM
I would be afraid that the friction fit would wear or get loose due to humidity changes and the table would get wobbly after a while. That is a clever idea and I would sure like to hear how it works out though.
BoilerUp21
#2 posted 01-08-2018 01:09 PM
That is exactly my fear as well.
- ArtMann
View bondogaposis's profile
bondogaposis
4925 posts in 2467 days
#3 posted 01-08-2018 01:28 PM
Use buttons, they are held in place with a screw and easily removable and also allow for wood movement.
-- Bondo Gaposis
View Reinan's profile
Reinan
80 posts in 335 days
#4 posted 01-08-2018 01:40 PM
I used a very similar leg to apron interface on a coffee table I built a month or two ago. The housed cross lap works well and makes for a very sturdy and nearly perfectly square base design.
If you are intending to be able to disassemble the base, I would think adding a pin on each end of the top apron would limit upward movement until you wanted to take it apart.
As to attaching to top to the base, I used shop made buttons out of walnut which were fit to the notches I cut into the inside of the apron with a rabbeting bit and a router. I don’t have a picture of the underside of the table but they are a simple and common attachment method.
-- -Russ
BoilerUp21
#5 posted 01-08-2018 01:43 PM
Russ that looks great and nearly identical to the look/function I am trying to achieve. I agree that buttons are a good method.
!https://s3.amazonaws.com/vs-lumberjocks.com/p28og5w.jpg!
- Reinan
View Rick  Dennington's profile (online now)
Rick Dennington
6081 posts in 3310 days
#6 posted 01-08-2018 04:02 PM
When I build a table, I use mortise and tenon joinery to secure the aprons to the legs (short and long aprons).....Then after the top is built and ready to assemble to the base, I use “figure 8 ” fasteners…
-- " It's a rat race out there, and the rats are winning....!!"
View bandit571's profile
bandit571
21031 posts in 2799 days
#7 posted 01-08-2018 04:07 PM
Hmmm
Corner blocks?
Glued and screwed to the aprons. Slotted hole for a screw into the top.
The usual way I attach a top to a table’s base….
This one needed a kicker for a drawer..
Hmmm..
View Woodknack's profile
Woodknack
12329 posts in 2495 days
#8 posted 01-08-2018 07:21 PM
I’ve seen those cross lapped table joints on smaller tables, consoles, coffee tables, etc.; It would be interesting to know how well it works on a dining table after 10 years or so.
