Recommend a sharpening system
Forum topic by Chucknbob posted 01-07-2018 02:46 AM 917 views 0 times favorited 18 replies Add to Favorites Watch
View Chucknbob's profile
Chucknbob
3 posts in 498 days
01-07-2018 02:46 AM
So I need to upgrade my sharpening system for my chisels and plane, but I’m at a loss as to what to get. I know I want a stone, constantly buying sandpaper doesn’t sound good to me. Also, I’m looking for something simple, hopefully hit 2-3 stones and be back to cutting wood within 5-10 minutes.
There’s just so much out where, water stones, oil stones, and new diamond stuff. Plus there’s 50 different grit options for each.
Can someone please point me towards a type of stone and what grits I should look for? Many thanks.
18 replies so far
View diverlloyd's profile
diverlloyd
3234 posts in 2062 days
#1 posted 01-07-2018 03:26 AM
Depends on what you want to spend. I use diamond plates and then finish sharpening with a black hard Arkansas stone. Paul Sellers has a good set up if you watch his videos. This is if you want to do it by hand if you wanted to go the machine route then I’m not of much help but I’m sure someone will chime in on a good machine.
View Aj2's profile
Aj2
1885 posts in 2003 days
#2 posted 01-07-2018 03:30 AM
Chuck if you can put together a grinder with a proper wheel that doesn’t over heat your steel you can limit your stones to a finer grit. I hollow grind my plane blades and so straight to my Shapton finishing stone.
I have good variety of sharpening mediums I think my shapton stone are the best.
This road can get expensive so go slow you don’t want to spend money on stuff not needed.
-- Aj
Chucknbob
3 posts in 498 days
#3 posted 01-07-2018 03:37 AM
Depends on what you want to spend. I use diamond plates and then finish sharpening with a black hard Arkansas stone. Paul Sellers has a good set up if you watch his videos. This is if you want to do it by hand if you wanted to go the machine route then I m not of much help but I m sure someone will chime in on a good machine.
- diverlloyd
I’ve watched Paul’s videos, but other than saying he sprays windex on the stones (which I assume means water stone) he says nothing else about grits, types, etc.
I would like to keep it under $50, but if it takes more to get a system that will last the next 10 years than so be it.
View Smirak's profile
Smirak
76 posts in 723 days
#4 posted 01-07-2018 05:15 AM
Trend diamond plate in 300/1000, shaptons from there…I have a 6000 and a 16000…I free hand and can be back to the bench in less than a minute unless the edge is beat up…
View Ripper70's profile
Ripper70
1165 posts in 1113 days
#5 posted 01-07-2018 07:04 AM
I ve watched Paul’s videos, but other than saying he sprays windex on the stones (which I assume means water stone) he says nothing else about grits, types, etc.
- Chucknbob
Watch this Sellers video to get the specifics on the stones he uses. I think, using a setup like this, you’d be hard pressed to keep the costs below $250 dollars, let alone $50.
You could consider the “Scary Sharp” method which uses plate glass and wet sandpaper. It has low start up costs but will be a more expensive approach to sharpening over the long haul. Plenty of YouTube videos and online information is available detailing the Scary Sharp method.
-- "You know, I'm such a great driver, it's incomprehensible that they took my license away." --Vince Ricardo
View HorizontalMike's profile
HorizontalMike
7770 posts in 3119 days
#6 posted 01-07-2018 01:09 PM
I pretty much gave up on stones after going with a cheap belt sharpener. After +4yr, I am on my 2nd or 3rd 180-grit belt. And I can sharpen any tool being used, in less than a minute.
http://lumberjocks.com/reviews/3179
View Tennessee's profile
Tennessee
2893 posts in 2719 days
#7 posted 01-07-2018 01:25 PM
I finally got tired of dull chisels and bought the Grizz machine that is a Tormek knock-off. To be honest, it does a really nice job on flat blades of all types. The leather hone, turns out that the substance they have you put on it is the same as TurtleWax white rubbing compound, so after sharpening, I hone on the leather with that compound, and it will definitely give me a shave, if I want. Takes about two minutes to resharpen, once I hit the switch. I don’t do any lathe tools on it, use a Wolverine set on a slow speed grinder with CBN wheels for that.
View Knockonit's profile
Knockonit
477 posts in 407 days
#8 posted 01-07-2018 02:15 PM
I did the griz unit, still trying to master it, had a couple jigs come with it, then stumbled onto a work sharp at a garage/estate sale, missing paper, ect. but for 10 bucks wth, anyway, boy howdy, what an easy way to sharpen chisels, so i have a nice little sharpening station on a counter at back of shop.
I’m still struggling with the grizz and planer blades, but eventually i’ll finger it out, just need to take the time
View johnstoneb's profile
johnstoneb
3063 posts in 2377 days
#9 posted 01-07-2018 02:35 PM
Worksharp
-- Bruce, Boise, ID
View onoitsmatt's profile
onoitsmatt
395 posts in 1381 days
#10 posted 01-07-2018 04:45 PM
Chris schwarz has a good blog series on sharpening. One of the posts is specifically about grits. It’s a good read:
blog.lostartpress.com/2017/07/10/sharpen-this-part-1/
-- Matt - Phoenix, AZ
5177 posts in 2698 days
#11 posted 01-08-2018 12:42 PM
I think $50 pretty much limits you to the sandpaper/glass (Scary Sharp) system, and even then you would need shop built fixtures to hold the blades. But you might be surprised at how effective that system is.
View Ron Aylor's profile
Ron Aylor
2649 posts in 852 days
#12 posted 01-08-2018 12:57 PM
My sharpening system cost me just about $20. I use this system for chisels and plane irons … both get a lot of use as I’m unplugged hand tools only. This system hasn’t failed me yet.
... consists of Harbor Freight diamond impregnated plates (course, medium, and fine), 1000 grit wet/dry sandpaper on glass, and a leather strop charged with chromium oxide. I use a honing guide to insure a constant angle while I work my way from left to right across the station, starting with the course diamond plate and ending up with the leather strop.
View bbasiaga's profile
bbasiaga
1240 posts in 2200 days
#13 posted 01-08-2018 01:21 PM
If we’re starting today, is get a LN Ohishi 1k/8k combo stone and a coarse diamond plate. The coarse diamond plage could be jsed to flatten the stone when needed and for heavy regrindimg if needed. It could be replaced with sandpaper on glass.
The Above would require no soaking, just a water bottle. More than $50 though.
Sandpaper gets expensive over time, so you’ll need to figure out how you want to spend…up front or over time.
I also recall a video on the YouTube channel ‘burrfection’ about a $40 400/1k stone that did a fair job. He was comparing them to the 320 and 1k s haptons. It was a soaking water stone, but combined with a cheap strop should do it for you.
Brian
View OSU55's profile
OSU55
1976 posts in 2194 days
#14 posted 01-08-2018 01:33 PM
A simple switch to a more durable abrasive will take care of it. For primary bevel creation, a machine is really needed whether a bench grinder, belt sander, worksharp. Takes a LOT of sandpaper and time to create a new bevel.
However, for honing, get some polishing film. Its the scary sharp system with abrasive that lasts a long time.
Here is my method.
View gtrgeo's profile
gtrgeo
9 posts in 635 days
#15 posted 01-10-2018 10:47 PM
When I started years ago, water stones were the way to go. Went down to my local Woodcraft and had them set me up with the necessary supplies to get going. I got sharp tools but the work involved was more than I cared for and very messy. For years I struggled because quite frankly the thought of breaking out the wet stones and the amount of work necessary, the flattening of stones, the mess involved, and the varying results kept all of the sharpening equipment in a drawer.
I contemplated the sandpaper route for a while but didn’t want to deal with the paper.
About a year ago I picked up the Worksharp and have been pleased. There is still some mess involved but I can quickly clean up with the shop vac. There is a little learning curve and the system does have its limitations but I tend to keep my tools sharp now as it is quick to touch them up during a project.
The one tool I am still struggling with is the cabinet scraper. Any help would be appreciated.
George
