Promax router table plate leveling screws loosen with vibration
Forum topic by Sawdust2012 posted 01-06-2018 10:31 PM 1027 views 0 times favorited 10 replies Add to Favorites Watch
View Sawdust2012's profile
Sawdust2012
123 posts in 1710 days
01-06-2018 10:31 PM
Topic tags/keywords: router table leveling screws router plate bench dog router
Hello,
Before I turn any more maple into smoking blocks for the grill, I need advice. Has anyone else had trouble with router plate leveling screws loosening with the vibration of using the router? It’s not a gradual thing. They drop 1/16” or more with each use! I’m hoping this is just something I have done incorrectly in setup. If not, would it work to set the plate, remove it and shoot a little CA glue onto the screws?
Thanks for the help!
10 replies so far
View LesB's profile
LesB
1726 posts in 3441 days
#1 posted 01-06-2018 10:36 PM
Try some Loctite before you CA glue.
-- Les B, Oregon
View John Smith's profile (online now)
John Smith
891 posts in 161 days
#2 posted 01-06-2018 11:19 PM
+2 on LOCTITE® THREADLOCKER BLUE 242®
Red is permanent (non-removable) – Blue is temporary (removable).
Edit: I’m not familiar with your machine, but, if the Loctite doesn’t fix the issue,
is it possible to get longer screws and put a jam-nut on them somehow ??
how old is your router? is it possible the threads are stripped or worn?
CA glue hardens like glass – once it hardens then breaks free, it no longer does its job.
-- Graduated Valedictorian from the University of HardKnocks --
View Luthierman's profile
Luthierman
221 posts in 1085 days
#3 posted 01-06-2018 11:29 PM
Just by the way, there is super-unglue too. It is basically acetone. I only post this for the future when somebody says help! I super glued my adjustment screws and need to remove them. Re: the loctite, the only way you can remove the red is with heat. I am not aware of a solvent that breaks it down. Well, any that I would want to put on my lift.
-- Jesse, West Lafayette, Indiana
View Rich's profile (online now)
Rich
2820 posts in 587 days
#4 posted 01-07-2018 12:51 AM
Does your plate have hold-down screws, and are they tight? When I first got my JessEm I figured I didn’t need them since the weight of the lift and router was going to keep it in place. My adjustment screws were changing all the time. One day it dawned on me to put in the screws that hold it down and that keeps the adjustment
screws tight and they don’t move a bit unless I loosen the hold-downs.
View FirehouseWoodworking's profile
706 posts in 3271 days
#5 posted 01-07-2018 02:24 AM
If the Locktite doesn’t work for you, you may want to try a wrap or two of teflon tape (the kind used on threaded plumbing fixtures). That should snug up the threads well enough. Good luck!
Cheers!
-- Dave; Lansing, Kansas
View wichman3's profile
wichman3
63 posts in 619 days
#6 posted 01-07-2018 02:56 AM
There is an anti vibration version of thread lock available, it is orange (and removable).
You might also try crushing the threads with a pair of vice grips (use needle nose and only a VERY small amount of crushing force).
View TheFridge's profile
TheFridge
9463 posts in 1484 days
#7 posted 01-07-2018 04:40 AM
Don’t not crush. Especially if the female threads are aluminum. It’s asking for trouble. Other instances I might agree.
wichman3
#8 posted 01-07-2018 05:52 AM
Sawdust2012
#9 posted 01-07-2018 03:54 PM
Thanks for all the suggestions! As I was about to go to get thread locker, I remembered seeing a bunch of little hex nuts in the parts bag. Turns out there are as many of those as there are leveling screws, and coincidentally, they are the same size! Shazam!
wichman3
#10 posted 01-07-2018 04:09 PM
- Sawdust2012
Family saying: “When all else fails, read the instructions” :)
