Small parts storage—what’s your solution? I need help
Forum topic by Sark posted 01-05-2018 09:16 PM 4089 views 0 times favorited 29 replies Add to Favorites Watch
View Sark's profile
Sark
61 posts in 268 days
01-05-2018 09:16 PM
Topic tags/keywords: part storage storage box containers
Here’s a couple of photos from my shop in the corner where I store screws, nails and other small parts. You will notice that this is a candid photo, and I didn’t spend time cleaning up or asking the shop to smile. What works great: Most all items are labeled. I have a lot more that needs to be sorted and made accessible. Interested in pictures from your shop, and any ideas for storing lots of small parts and being able to find them when needed. Thanks.
Note: I worked as a cabinet maker and a general contractor, and I sure have a lot of items to keep track of. These plastic storage containers are easy to grab when I go out on the road.
29 replies so far
View Knockonit's profile
Knockonit
301 posts in 110 days
#1 posted 01-05-2018 09:29 PM
I tracked down some of the bins that the Ace hardware uses for screws, bolts ect. Found a whole gaggle of them for cheap on craigslist, relabeled them and walla, awesome organizers, I made the labels large enough i can see without me glasses.
or make some bins, I like the hardware bins, as i can pull the whole bin/drawer and take to the work area with a selection of sizes.
good luck, no matter how much i seem to get organized, something else is out of wack
View John Smith's profile
John Smith
455 posts in 70 days
#2 posted 01-05-2018 09:40 PM
I don’t have a lot of fasteners, per se, but I do have a LOT of drywall screws
and nails of different sizes scattered all over the place.
one of my 2018 projects will be the boxed fastener organizer mounted to the wall
with French Cleats with a handle on top so you can grab it and take it to the
job site. It will accommodate the standard one pound boxes of nails and screws.
then when I have empty boxes, they can be relabeled for the common fasteners
found on the home renovation job sites.
116906 posts in 3485 days
#3 posted 01-05-2018 09:48 PM
What I use may be the same thing that Knockonit uses ,I have these bins all over the shop in different sizes from large bids that can hold 6” lag bolts to small ones that you can hold screws that would go into a watch, it’s easy to get either a part at a time or the whole bin, being made out clear plastic you can easily see whats inside.I don’t use this brand but here’s a link for the type of bins I use.
https://www.amazon.com/Deflecto-20604OPU-Six-bin-horizontal-storage/dp/B000J0C8TM
View Rich's profile
Rich
2295 posts in 497 days
#4 posted 01-06-2018 12:58 AM
I don t have a lot of fasteners, per se, but I do have a LOT of drywall screws
- John Smith
So the photo isn’t of something you built, but something you plan to build?
-- No matter how much you push the envelope, it'll still be stationery.
View Sark's profile
Sark
#5 posted 01-06-2018 01:28 AM
I’m planning to add more storage in the same space by attaching the bins to a pice of plywood and then attach the plywood to the cabinet with some sort of hinge. This will allow me to double up on the number of parts stored in the same space, with the most used fasteners in front, and the least used parts on the back side of the plywood. Over the years, it amazes me how hard it is to keep things organized.
View mtnwalton's profile
mtnwalton
28 posts in 934 days
#6 posted 01-06-2018 04:47 AM
Here’s a hardware cabinet i built a couple years ago that holds organizers i got on Amazon
I didn’t include any other hardware than bolt, nuts and wood screws but it has been a major step saver so far.
View Rich's profile
Rich
#7 posted 01-06-2018 05:53 AM
Here s a hardware cabinet i built a couple years ago that holds organizers i got on Amazon
- mtnwalton
That’s a great cabinet. I like how the boxes are on slides.
View alittleoff's profile
alittleoff
534 posts in 1184 days
#8 posted 01-06-2018 07:27 AM
Mine is so junked up I’d be ashamed to show it. I’m not good at organizing my fastener, or anything else. I do have the harbor frieght rolling stand with bins on both sides.
Gerald
View Rick's profile
Rick
8912 posts in 2940 days
#9 posted 01-06-2018 01:22 PM
This is a part of my Scrambled Parts Section. I even have a bunch of ….”I’m gonna keep this (these). I might use it (them) for something one of these days.”
I’m probably the ONLY Guy on here that does that! ...lol… Did somebody just say something?
Rick
-- Real MEN! Measure Once! Cut Once! Then head back to the Lumberyard. (Rick, Ontario, Canada)
Knockonit
#10 posted 01-06-2018 01:25 PM
lol, i have my daughter coming over to show me how to post pics today or tomorrow and i’ll get some pics up.
essentially what i found was bins that the ace hardware stores use for their bolts and nuts ect. they have 4 drawers per unit unit is metal approximate 16×16x16, four bins, with dividers, nice big label area, i bought a hundred of the bins, have about 12 in shop, in different locations, still doesn’t help with my clutter, i’m a slob, got stuff every where, i just can’t seem to keep putting stuff where it belongs, until i need a spot to assemble or work on something, then its clean up time organize time, which takes away from project time, jeebus, sure wished i’d do it as i finish one project up.
good luck, organizing and keeping the jt neat is embarrasing for me. lol
rj in az
View Lazyman's profile
Lazyman
1715 posts in 1295 days
#11 posted 01-06-2018 02:28 PM
My first real project when I started setting up my shop when I retired was to make a pair of octagon storage bins inspired by antique hardware store bins that spin on a lazy susan. I initially planned to make a single tower but decided part way through to divide it into 2 shorter ones that I can put on a shelf instead of being free standing. I also made 2 of the drawers double width to accommodate some larger items so instead of 88 bins there are only 86. The triangular bins are handy to take over to my work bench and overall this makes for fairly compact way of storing screws, nuts and bolts. This was a blast to design and build.
John Smith
#12 posted 01-06-2018 03:08 PM
Rich – yes, this is in my bucket list – “one of my 2018 projects will be the boxed fastener organizer”
I found the photo and plans on Pinterest…..of course you can make any size you want
to suit your needs – even a double sided one. or, find a lot of tupperware boxes the size
you like with an airtight lid to keep the moisture out and prevent rusting.
here are the plans for it. http://www.instructables.com/id/The-1lb-Boxed-Screw-Storage-Rack/
or make a double or triple unit if you so desire.
I don’t know why the original fabricator didn’t route the edges for that nice finished look.
also – hardwood sides would give a much neater appearance. (this project is limited only to your imagination).
I found some of the metal hardware store bins on C/L with trays but they wanted $1200.00 per unit
and that is way out of my “needs” bracket.
View JackDuren's profile
JackDuren
388 posts in 867 days
#13 posted 01-06-2018 03:57 PM
I learned awhile back if you keep every screw,bolt or nail you will have little room for anything else…
I hunted Pinterest for the most practical ideals and bought cases and then realized I was spending too much time and space to collect hardware that isn’t going to be used…
I now keep one for exterior screws and one large one for most cabinet making hardware..
This was the direction I was headed…
View Blindhog's profile
Blindhog
30 posts in 956 days
#14 posted 01-06-2018 09:26 PM
Got the rotating bins from an auction and the clear plastic small parts bins from eBay. I like to be able to see what I’ve got before starting looking.
View oldnovice's profile
oldnovice
6554 posts in 3275 days
#15 posted 01-06-2018 09:43 PM
I have been using small containers from Schaller Corporation because they have so many different sizes available for storing almost any parts from very small to larger parts and are fairly inexpensive.
Below is a sample of some of the sizes.
Different depths are also available and can also be purchased on Amazon and eBay.
showing 1 through 15 of 29 replies
