Brainstorming An Out Feed Table
Forum topic by Maveric777 posted 03-18-2011 02:37 PM 2798 views 2 times favorited 37 replies Add to Favorites Watch
View Maveric777's profile
Maveric777
2693 posts in 3076 days
03-18-2011 02:37 PM
Topic tags/keywords: question resource assembly table outfeed table
I am in the beginning process of designing an outfeed table for my shop. I currently have a 72”x27” simple thrown together work bench pushed up to my table saw now. My plan is remove the wheels on it, build a super beefy top, and move it away from the table saw to be used for hand tools primarily. So this leaves me with wonderful fun dilemma of building something to work as an actual outfeed table. Of course as my bride states on a regular basis “I cant do anything simple”.... So in that theme… I want to make it “A Jack Of All Trades”
I am in a small 20’ by 20’ garage shop so utilizing space is very imperitive. Also add the fact I hate clutter I plan on adding a bunch of bell and whistles on this hopeful jewel. Well, before I got to far into the design I figured I would ask my Lumber Jock friends what things would you like to see in a “Swiss Army Knife” version of an outfeed table? I know this is going to be a big and slightly costly build so I would hate to have an idea after the fact sort of thing.
Here are a few things I have in mind I want to incorporate….
1) Built in router table
2) Tons of storage and cabinets.
3) Special cabinet for pancake air compressor so I can cut down noise.
4) Wired up so I can plug in what ever I need right there at the station.
5) A small down draft box that either is built into the top (with a removable cover) or as a drawer that can be pulled out and secured to the top… Then simply slid into its spot when not in use (out of the way)
6) A benchtop bench that will lock down to the top (for small detailed work) and can slid into the unit when not in use.
7)The top will be covered in some sort of material so that glue will not stick to so I can use as an assembly table as well.
8) Few key dog holes for movable jigs that hold things like a drafters lamp.
9) Storage spot for my Super Sled
For now that is all I can think of at the moment….. That’s why I am hitting yall up. What other “Neat” little features would you want in something like this? I know I am missing some stuff that later I would kick myself for not thinking of….
Ohhh I also got to thank ShopDogs for getting me to thinking a while back when he posted his Assembly Table. That project has been on my mind since I first seen it…
Thanks for any input and let the brainstorming begin…..lol
-- Dan ~ Texarkana, Tx.
37 replies so far
View brtech's profile
brtech
1029 posts in 2921 days
#1 posted 03-18-2011 03:51 PM
Have a look at the Woodwhisper’s assembly table.
http://thewoodwhisperer.com/episode-18-assembly-table-torsion-box/
http://thewoodwhisperer.com/episode-19-assembly-table-stand/
That has a lot of what you wanted, and I suspect could be modified to have all of it.
Maveric777
#2 posted 03-18-2011 04:33 PM
Thanks so much for the heads up on that! Will definitely check it out….
View Cozmo35's profile
Cozmo35
2200 posts in 3035 days
#3 posted 03-18-2011 05:13 PM
Dan, that is a tall order to fill. It seems as though you forgot the beer holder.
-- If you don't work, you don't eat!.....Garland, TX
View Joe Lyddon's profile
Joe Lyddon
10100 posts in 4051 days
#4 posted 03-18-2011 05:58 PM
If that were my list of what I wanted to do (which sounds great), I would say I was dreaming… and haven’t woken up yet… I would need a pinch to get me back…. LOL :)
I would like to see pictures of what you’re talking about… Before… Proposed…
Sounds like a nice job to do…
View jonasramus's profile
jonasramus
24 posts in 2975 days
#5 posted 03-18-2011 08:15 PM
I have similar aspirations. I’m also in a garage shop and looking to create a triple duty assembly table, router station, and outfeed table.
My design concept includes the following:
- 4’ x 4’ torsion box top made of MDF, topped with a laminate (for durability, mositure resistance, glue resistance, and decreased friction)
- Within the torsion box top, eletrical will be run to provide 110V power outlets on 3 of the four sides. I will also include a switch to power an outlet for the router and for my dust collector (aka shop-vac).
- The base will be made of two cabinets, each about 20 inches deep, and tall enough to make the surface flush with my table saw, and as wide as possible while still leaving clearance for my outboard motor of my contractors saw.
- The two bases will leave a 6-8” cavity between them, which permits me to run dust collection tubes into the back of the cabinet that will house the router and will permit me to run a long hose out of the cavity and back to the router fence.
- The base will be set back from the face of the torsion box by about 1.5 inches around the outside to give me the ability to clamp wood easily to the table top.
- One drawer in the base on the router table side will be large and wide enough to allow me to store my router fence.
- The box where the router goes will be flanked on both sides by small drawers for router bit storage.
- The base will have leveling feet to fine-tune the flush-ness of the surface with the table saw.
- The router will be supported by a woodpecker router insert plate.
- A multi-track will be imbedded into the table in front of the plate for clamping feather boards and running a miter gauge.
- Two short t-tracks will run perpendicular to the multi-track to support the fence.
See image below for details.
-- Jeff, Deltona Florida
Joe Lyddon
#6 posted 03-18-2011 09:57 PM
Jeff,
That looks like a COOL plan for a very functional outfeed / router / assembly table!
View Glen Peterson's profile
Glen Peterson
556 posts in 3055 days
#7 posted 03-18-2011 11:45 PM
Hi,
Here’s the link to one the outfeed/router table I posted as a project recently. Like you I planned for a long while and checked out many variations. I looked long and hard at the Wood Whisperer’s outfeed table, but then I decided to make it similar to many of the router tables we see. Mainly for the storage. Good luck.
http://lumberjocks.com/projects/45882
Cheers
-- Glen
Maveric777
#8 posted 03-18-2011 11:49 PM
lol Mike…. I did in fact forget the cup holder. Thanks for the reminder….lol
@ Jeff… Looks like you are well on your way to having yours figured out. I like!
@ Barry… I mean Bob… No Barry….lol… Your suggestion is definitely noted…lol
Well, I got a few minutes to play real quick with a very quick sketch up idea. After done I realized many things I want to change. Here is a what I came up with earlier as a reference….
View Domer's profile
Domer
252 posts in 3365 days
#9 posted 03-19-2011 03:43 AM
My guess is that a free standing out feed table would get in the way in a small shop especially if your floor is not perfectly flat and you have to move your table saw frequently.
I attached my out feed table to my saw with hinges to get it out of the way when not in use. There are a number of ideas if you just look on the internet.
Domer
View Loren's profile
10396 posts in 3647 days
#10 posted 03-19-2011 05:12 AM
I hate big tables like that because I pile them up with junk. Maybe
you do not suffer from my tendency to pile stuff on whatever
table is available.
I had a roller table at one time on the back of my cabinet saw and
it was my favorite arrangement because it folded down out of the
way and the rollers made it impossible for me to think of it as a storage
area.
Now I prefer a vertical panel saw for panel work. The big table saw
setups eat up so much space.
View Madtapper's profile
Madtapper
10 posts in 2640 days
#11 posted 03-19-2011 06:17 AM
Dan:
I signed on tonight to ask a very similar question about outfeed tables. I, too, have a small 20’ x 20’ garage workshop, and I am looking to change things around a bit. I currently have a torsion box assembly table (on saw horses) behind my table saw. I am planning on building a cabinet under the assembly table top and putting the whole thing on wheels. I look forward to the advice that comes with this thread! I do have a question for everyone. Do you put your outfeed tables level with the top of the table saw, or do you leave the top of the table saw a bit proud? Thanks again.
Good luck on your outfeed table Dan. Looks great.
Jerry
-- -- Jerry, Gig Harbor, Washington
View emart's profile
emart
445 posts in 2627 days
#12 posted 03-19-2011 06:51 AM
honestly i think you would be best suited by building some smaller tables on casters that are all the same height because as you said space is at a premium. i have an even smaller shop (10×10) and the solution i found best for me was having everything be modular so i can reconfigure my shop as needed. i would also suggest building just the basic table and using it that way you can decide if you really do like it that size. just a thought
e-mart
-- tools are only as good as the hands that hold them https://www.custommade.com/by/emeraldcrafts/
View Resurrected's profile
Resurrected
671 posts in 2691 days
#13 posted 03-19-2011 07:00 AM
I make all things at 36 inch(?) same heigth of the table saw. I use the planer table as my out fedd. I am really steering towards putting a 36 inch wide board hinge at the back side to be my extension table. Just seems more usable. I hate picking the 100 pound planer up.
Word of advice unless you have a big shop stay clear of the big unmovable table.
-- Who can I block now???????????????????????
View devann's profile
devann
2246 posts in 2691 days
#14 posted 03-19-2011 07:41 AM
HI Dan, On #3 consider that compressors are air cooled. Closed up in a cabinet the compressor is not going to last has long.
I’ve seen several tables on the site just in the last week. Some simmilar to what you are desrcibing, go back and check the projects page. One sat on a bed frame so the owner had wheels.
Like you I have to work in about the same space. I just built an outfeed table for my tablesaw last week and made a good portion of it fold down out of the way where I can get around. I went for cheap and simple. Pictures posted.
I have to put my two cents with emart.
Maveric777
#15 posted 03-19-2011 04:20 PM
Thanks for all the feedback yall! That’s one of the things I love about this site is how helpful everyone is with ideas and opinions. I have had a chance to look through a few more projects simular to what I am thinking and snagged a few more ideas…
@ Darrell… Outstanding point about the compressor needing to breath. I wonder if there could be a way to have air ported in and still help control noise (honestly that thing scares the crap out of me from time to time when it fires up…lol). I am thinking some sort of muffler like passages built into the cabinet that lets it breath but helps cut down on the noise.
@ Loren.. I never been a fan of large tables in the past either honestly. I am a bit particular on my shop and keeping it clean so clutter isn’t really going to be much of an issue in that sense. My big concern is how much room it will take up in my shop more than anything else. The only saving grace I think I have will be the fact I do not plan on doing large projects (entertainment centers, kitchen tables, etc). Most my work is boxes or small projects like that. Also on that note I decided to make it in 3 sections that will basically bolt together. This way if I need to move it or what not it will be much easier.
@ Resurrected.. I am right there with you on picking up a heavy planer. I plan on building a flip stand for mine that will incorporate my plainer and possibly my miter saw. My goal will be to have it the exact same height of my outfeed table and it will in some way lock on the the table so it will be solid and not roll around on me in use.
Thanks again on all the feedback everyone… Keep the ideas coming…. Yall have been a huge help so far…
Thanks!
showing 1 through 15 of 37 replies
