Hard Maple American Flat Bow (Long Bow)
Forum topic by JohnAjluni posted 03-18-2011 08:39 AM 19736 views 3 times favorited 14 replies Add to Favorites Watch
View JohnAjluni's profile
JohnAjluni
102 posts in 2599 days
03-18-2011 08:39 AM
Topic tags/keywords: maple pine blade sander traditional
So I decided I am gonna make an American Flat Bow for my next youtube video(s). It is going to be a series of videos.
So the Bow I am making was brought to america by the Europeans. The Americans used it to show up the Indian’s and take away there land. The Flat Bow was most powerful for its time capable of a 200 yd shot with a full 28in draw.
I decided to make my bow out of Maple it is going to be 68 inches long with a 6 inch handle in the center i hope for it to be a 50lbs bow maybe 45 if i have to. I need this to be a very nice Bow because I am in contest with a teacher of mine for lots of extra credit. He is to build a bow and I am to build a bow and we are going to test them and see who’s shoots better stronger and farther. Here is the link to the designs I am gonna use.
So you guys got any tips on bow buildin?!
^^^Not my bow^^^
Materials I have purchased:
6ft board of maple 3/4 in thick and 4in wide
6ft board of pine for handle 3/4 in thick 2 in wide
wipe on poly
Tightbond II
Tools going to be used: Jig Saw
Belt sander
detail sander
Knife
HOPE YOU GUYS ENJOY!!! AND MAKE SURE TO WATCH FOR MY VIDEOS!:)
*and feel free to give me some tips if you know how to build a bow correctly
-- John
14 replies so far
View wseand's profile
wseand
2796 posts in 3006 days
#1 posted 03-18-2011 09:13 AM
Never built a bow before but looks like a fun project. Looking forward to seeing it finished and the video.
JohnAjluni
#2 posted 03-18-2011 09:18 AM
Thanks!!!
-- John
TopamaxSurvivor
18246 posts in 3640 days
#3 posted 03-18-2011 09:46 AM
I haven’t built a bow since I was a kid and they weren’t much ;-)) I have read a lot about it. A straight grained wood will most likely be beter than maple. Unless you are going to reinforce the back, it needs to be what is called a self-bow where the wood itself makes up the bow’s strength. Unless the back side follows the grain perfectly, it will break unless it is reinforced with seniew or fiberglass. Hopefully a real bow maker will show up on here. I just wanted to warn you about the maple.
View Greedo's profile
Greedo
473 posts in 2925 days
#4 posted 03-18-2011 02:08 PM
will you need to make the arrows aswell?
thos actually look more complicated to make than the bow!
View AUBrian's profile
AUBrian
86 posts in 2635 days
#5 posted 03-18-2011 02:29 PM
I’ll second what Topomax said.
I’ve built several bows, and to get the power you’re talking about with just wood, it will have to be exceptionally straight grained, and you’re going to have to be very careful about leaving any sort of nicks, especially on the underside (Inner part of the curve). The most important thing, especially if you’re trying to get your draw weight that high, is the wood grain, and how it runs. If you have access to straight grained hickory, I’d choose that over maple.
If you want real strength, go for fiberglass on the outside of the curve, and make sure you get a very good lamination. Sinew will also work, but I didn’t have access to much of that at the time.
Also, make sure you have/make a decent tiller, because nothing is more dissapointing that taking a couple of scraping and finding out you just dropped your new bow 5lbs, and it’s no longer legal to hunt with. It’s also really frustrating to find out that the whole reason you can’t shoot straight is that the two halves of your bow are bending completely differently.
For a good reference, I’d recommend “The Traditional Bowyers Bible” or a site like Stickbows ( http://www.stickbow.com/FEATURES/SELFBOWS/beginnings.CFM ) This explains in a bit more detail making a self bow.
Also, if you have access to a shaving horse, it’s a great asset when doing a lot of your shaping. If not, a vise will work, a shaving horse just allows a lot of quick adjustments.
Hope this helps!
JohnAjluni
#6 posted 03-18-2011 07:19 PM
I chose maple because of my last experience of bow building. The last Bow i made was made of maple and i had great results. I got a board with a fairly straight grain purposefuly and I never backed it. It shot at around 40lbs and shot with great accuracy. So was I just lucky with the board I purchased? haha
This time I was planning on backing it with fiberglass and I have mad my own tillering rod and mounted it on my wall. I will plane the bow with a hand planner to the correct thickness. anything else i am missing?
-- John
View Broglea's profile
Broglea
684 posts in 3055 days
#7 posted 03-18-2011 09:47 PM
Good luck John. I hope you post it here when you are finished with it.
AUBrian
#8 posted 03-19-2011 12:07 AM
Sounds like you’ve got a good plan in place. Remember fine tuning can be done well with a card scraper..or sandpaper.
I usually do a leather wrap on the hand grip, but that’s just personal preference. And I find a flemish string feels better on my fingers. I get mine from https://rudderbowsarchery.com . I tried to get a local bow shop to make one, and they tend to wrap the middle of the string, which makes it hard and painful.
As long as you do a good job balancing the limbs, and getting a nice smooth curve, you should be able to shoot quite accurately, as the Native americans proved for years :o)
If you’re happy with Maple, go for it. Backing it will help with not having perfect grain, although it can also fix so much. work up to a full tension draw. Speaking as someone who has nailed his head when the upper limb snapped at full draw, it’s better to go slow than go to the hospital.
And lastly, possibly most importantly…post pictures! We’d all like to see your progress :o)
View Jim Finn's profile
Jim Finn
2647 posts in 2886 days
#9 posted 03-19-2011 12:49 AM
about 8 years ago I found a forum similar to this one to get advice on bow making. I made a couple of them of streight grained Oak. Fun project for sure.
-- Website is https://craftingcouple.com/
JohnAjluni
#10 posted 03-19-2011 07:33 AM
Notches made with a small round wood file.
Handle is made of pine glued on with tightbond II and clamped.
side view
So far I have cut the bow out of my maple with my Jig Saw then I planed it down with my 61/2in planer to the correct mesurments and then glued on the handle with tightbond II. My next step is to shape the handle and tiller my bow.
I will keep updating this project.Also as you can see I got alot of work to do!
Any ideas of what else I may do to my bow?
-- John
View Rick's profile
Rick
9432 posts in 2997 days
#11 posted 03-19-2011 12:06 PM
I’ve never made a Bow, but if I was to do so, I’d Certainly do what AUBrian Said in his 2 Posts. Did you Read the 2 Links he gave you? I did. There is MORE than enough Info there.
Seems like you have a LOT of info to comlete your Bow. What other info would you like? Is there a Specific Question you have that requires an answer.
Is that a misprint in your lead In, or did you actually buy a 6 Foot length of Pine for the 6 Inch Handle? It’s also “TiteBond”.
Look forward to seing your Finished Bow.
-- LIFE is what happens when you're planning on doing Other Things!
View Dennisgrosen's profile
Dennisgrosen
10880 posts in 3079 days
#12 posted 03-19-2011 01:40 PM
I havn´t made one
but I have read you shuold do a brake in on the bow when its finished so it want crack
at the first full try
so you have to make a stand where you can pull 1/4 , ½ , 3/4 and 4/4 to let the bow
acumolate to be used with a full pull and gain the best strength
I can´t remember if its on L J I have seen it or on a site for longbow building
its isn´t as easy as it looks like to build a longbow
good luck
Dennis
View mcshaker's profile
mcshaker
29 posts in 3503 days
#13 posted 03-19-2011 03:24 PM
I made a Maple flat bow several years ago. The project worked out great. You will probably want to add a backing to increase the pull strength, mine is to weak for hunting. I guess my advice is not to remove to much material in order to maintain the strength. Also, very very thin coats of shellac in order to prevent the finish cracking. Here’s a link to the free plans I used. Pop Mech Flatbow plans
JohnAjluni
#14 posted 03-20-2011 09:14 PM
Ive backed my bow with one sheet of fiberglass
-- John
