Joining a 45 degree angle with kreg jig
Forum topic by WoodSailor posted 01-05-2018 03:14 AM 4550 views 0 times favorited 13 replies Add to Favorites Watch
View WoodSailor's profile
WoodSailor
10 posts in 380 days
01-05-2018 03:14 AM
Topic tags/keywords: kreg jig pocket holes table end table couch question joining
Hello,
I am currently making couch end tables and am trying to find a secure way to join a 1×2 that is cut on a 45degree angle to a 2×2. I have tried using my kreg jig but I am having problems getting it to work as I need to put one of the hole on the short end of angle so that the pocket is on the bottom (so its not visible). I would like something more secure than just wood glue. Does anyone have any ideas about sturdy but simple ways to join them?
13 replies so far
View jerryminer's profile
jerryminer
944 posts in 1679 days
#1 posted 01-05-2018 08:31 AM
I’m not a big pocket-screw guy, but I do use them for face frames.
Are you trying to do something like this? :
Do you have the little Kreg mini jig?
If so, clamp this to the work piece on the short side of the miter—- and use a long (1 3/4 – 2”) screw. Clamp it up to immobilize it before driving the screws.
Alternatives to pocket screws would include dowels, biscuits, Dominoes, and loose tenon.
WoodSailor
#2 posted 01-05-2018 01:46 PM
That is exactly what I am trying to do.
I don’t have the mini but I have the R3 (the two holed jig), I was playing around with some scraps and one of the problems I kept having is the screw wouldn’t bite into the 2×2. It would just ride up it a ways, would I prevent this by drilling a starter hole through the pocket hole I drill in the 1×2?
19614 posts in 2095 days
#3 posted 01-05-2018 01:54 PM
I don’t think you’ll have any success doing that. I think even if you predrill, with a very long bit, when you tighten the screw it will slide your brace out of place.
If you want to use pocket screws, you may consider cutting the 1×2 square and make an angled notch in the 2×2 for
1×2 to land in. Then pockets screws can hold it in the notch.
View builtinbkyn's profile
builtinbkyn
2686 posts in 1179 days
#4 posted 01-05-2018 02:31 PM
There are a few ways to deal with this. One is to cut a shallow dado allowing the 1×2 to seat into it. No need to make an angled notch as your 1×2 is already at the proper angle. You obviously would have to account for that in the length of the 1×2 member. If you want to attach it to the face as is shown in the drawing, you have a few options. One is to clamp a pice of scrap across the 2×2 to prevent the 1×2 from riding down the 2×2 as it’s screwed into place. You could also first glue and clamp it and allow it to dry. Then screw it for reinforcement. However you could screw it from the opposite side and that would solve your problem. Glue is necessary for that joint to stay tight.
-- Bill, Yo!......in Brooklyn & Steel City :)
View bbasiaga's profile
bbasiaga
1242 posts in 2233 days
#5 posted 01-05-2018 03:39 PM
Do you have a way to cut dowel holes? They would be stronger and potentially easier to execute here.
Brian
WoodSailor
#6 posted 01-05-2018 03:54 PM
I don’t have a way to cut dowel holes. I am pretty new to all this and have limited equipment.
It is looking like I am just gonna have to screw them from the outside. I was hoping to avoid that because I didn’t want to see the screw heads. The braces are just for decoration so wood glue should hold them in place I suppose.
View John Smith's profile
John Smith
1551 posts in 401 days
#7 posted 01-05-2018 04:05 PM
Sailor – does one of the boards have a show side? or are both show sides.
can you make a sketch or drawing of what you are trying to do ??
copy of a photo from the interweb that resembles your plan ? do you have plans you are working from ?
there are still options that will work – if the gallery can fully understand your issues.
-- I started out with nothing in life ~ and still have most of it left.
View Loren's profile
10477 posts in 3886 days
#8 posted 01-05-2018 04:11 PM
You can glue it in place and then drill holes
for dowel rod from the outside. Spread glue
then hammer the dowels in. Cut the ends
off flush. Looks ok. Easy.
Brad point drill works best. Spade drill is
okay too.
For quickie decorative effect I would probably
just glue and use a couple of tiny air nails
to hold the parts in place.
WoodSailor
#9 posted 01-05-2018 04:22 PM
This is what I am trying to make, however mine is going to be all stained instead of painted and I am using 1×2s instead of 2×2s for the braces; so I didn’t want to screw in the braces from the outside like she did here.
View brtech's profile
brtech
1054 posts in 3161 days
#10 posted 01-05-2018 04:30 PM
I don t have a way to cut dowel holes. I am pretty new to all this and have limited equipment.
It is looking like I am just gonna have to screw them from the outside. I was hoping to avoid that because I didn t want to see the screw heads. The braces are just for decoration so wood glue should hold them in place I suppose.
- WoodSailor
There is your answer. If it’s not structural, you don’t need any reinforcement. Just glue it in place. Use a good wood glue (like Titebond). Take some time to figure out how you are going to clamp it in place. You want some reasonable pressure holding the joint together while the glue dries. One thing many of us would do is to cut a small block of wood out with the opposite angle and glue it to the top surface of the 1×2. Let that dry overnight. That block can then be clamped to the 2×2 because the face will be square to the 2×2 and hold the joint together. When the actual joint is dry, cut off the block and sand the glue line away.
John Smith
#11 posted 01-05-2018 04:36 PM
an option that I would probably use is the hardwood pre-cut dowel pins.
one hole will be the easy 90* and the angled one may take some effort
to get it drilled to the correct angle. I use a lot of 5 minute epoxy and this
project would be a good candidate for it.
I would drill the angled hole as much on center as I could then waller it out
larger so when the epoxy is applied, you can hold the pieces in place while it sets up.
keeping in mind that stains do not stick to epoxy. so you have to work neatly.
if you have many of these angles to fasten, I would fabricate a special drill jig
to get it as neatly as possible.
View alittleoff's profile
alittleoff
541 posts in 1515 days
#12 posted 01-05-2018 04:51 PM
I would just countersink 3 screws from the outside, glue and screw the joint, and then plug the holes with pine or oak raised rounded button type plugs. Even them out and use 4 plugs. I think it would look good and be sturdy.
Gerald
jerryminer
#13 posted 01-05-2018 08:50 PM
I think if you clamp on an angled block, and drill a small pilot hole, you’ll be able to get these screwed in.
But there are other options, as discussed above.
