easy (safe) way to split logs into usable halves or quarters for turning
Forum topic by TDW posted 03-18-2011 03:21 AM 3240 views 0 times favorited 7 replies Add to Favorites Watch
View TDW's profile
34 posts in 2917 days
03-18-2011 03:21 AM
Topic tags/keywords: preparing wood green wood turning
I am new to turning but have done a few projects I have been given some nice (green) logs of pecan that I would like to split up into halves for bowls and then smaller for other turnings. I am trying to figure out the safest way to attemp this. the logs vary from 6 inches to 10 inches in diameter. I know this is a newbe guestion but I’m a newbe
-- Tom, Ky.,
7 replies so far
View Barbara Gill's profile
Barbara Gill
153 posts in 2592 days
#1 posted 03-18-2011 03:32 AM
Build a rack to hold the logs and cut them with a chainsaw. Cut out the pith to help avoid having them split.
-- Barbara
View Roper's profile
1387 posts in 3645 days
#2 posted 03-18-2011 03:54 AM
At that size you could also build a cradle sled for the band saw and cut them in half that way and even cut off the corners at the same time.
-- Roper - Master of sawdust-
View hObOmOnk's profile
1381 posts in 4060 days
#3 posted 03-18-2011 02:45 PM
Try Kentucky style splitting – wedges and a maul.
Very easy, besides riving reveals the grain direction.
-- 温故知新
View Nomad62's profile
726 posts in 2890 days
#4 posted 03-19-2011 01:32 AM
The 10” log will only allow you to turn a maximum size block of 10” (at the wide side), so take the chainsaw (or what you have) and cut the log into 10” lengths; then take your axe and whack it thru the pith to halve it, then halve the half-piece for a quarter if you like. Trim them as needed to fit your lathe and start making shavings! Same thing with the 6” log, but at 6” lengths instead. Have fun!
View Edziu's profile
151 posts in 2983 days
#5 posted 03-19-2011 04:38 AM
Another vote for wedges and a maul. It’s all I’ve ever used.
View TopamaxSurvivor's profile (online now)
18225 posts in 3608 days
#6 posted 03-19-2011 04:49 AM
I split maple logs that are over 2 feet in diameter and 10 feet long with a maul and 3 or 4 wedges. Those little guys should be easy. Watch the end grain, It will tell you where it wants to be halved. That is one of the reasons I start my logs that way. I don’t want to be cutting against the natural checks. I had one that made a full quarter twist in about 8 feet :-))
View John's profile
190 posts in 3516 days
#7 posted 03-19-2011 11:11 PM
8# splitting maul and an 8# sledge. I’ve split all types of hardwood as large as 30’ in diameter and locust posts up to about 12” diameter and 8’ long with a splitting maul.
-- John, Long Island, NY
