Conveyor Motor and Controls for Shop-Made Drum Sander
Forum topic by woodpick posted 03-18-2011 12:15 AM 5118 views 2 times favorited 8 replies Add to Favorites Watch
View woodpick's profile
woodpick
13 posts in 3704 days
03-18-2011 12:15 AM
Topic tags/keywords: drum sander
I’m building a shop-drum sander. Does anyone know where to buy a motor/controls for the conveyor belt?
Thanks for your help.
-- Dave, Golf...Woodworking...more Golf, www.woodshopics.com
8 replies so far
View tenontim's profile
tenontim
2131 posts in 3738 days
#1 posted 03-18-2011 12:24 AM
Try http://www.surpluscenter.com The have a good selection of motor, reversing switches, etc.
View benjiman's profile
benjiman
6 posts in 2628 days
#2 posted 03-22-2011 02:42 AM
I built one using a discarded treadmill works great
View johnzo's profile
johnzo
84 posts in 2790 days
#3 posted 03-24-2011 02:07 AM
Why not keep it simple and just use an AC gear motor from the Surplus Center. I built a DS using item #
5-1183 ($40.) for the transport belt. This motor runs on 115VAC and puts out 57 RPM which is an ideal speed. You don’t need speed controls because the depth of cut is your adjustment variable. Look at my DS in my project list. Works great! Even had a buddy offer to trade his Jet cantilevered model for my 16” shop built. No thank you!
John Z
-- 70 is the new 50!
woodpick
#4 posted 03-24-2011 05:21 PM
Thanks for the input on my thickness sander. If you want to take a look at it you can find it at www.woodshopics.com. I only have pics, no descriptions yet. I would like to put a speed controller on the conveyor belt thus I’m thinking I need a DC motor. Any input on this? I tried the surplus center for the motor you suggested, johnzo, and they are out of that particular item. Where can I buy a 115v ac to 12 or 24v dc converter and also a speed controller?
View Ripthorn's profile
Ripthorn
1458 posts in 2979 days
#5 posted 03-24-2011 05:45 PM
Harbor freight has AC motor speed controllers, usually used for routers, but don’t see why it couldn’t work with any other AC motor. They are about $15, if I recall correctly.
View Stormin's profile
Stormin
193 posts in 2783 days
#6 posted 03-24-2011 06:06 PM
Most single phase motors do not work on a speed control because they have a centrifical switch that operates at a certain RPM to switch from start to run mode. You can however get a 3 phase motor and a VFD inverter to control the speed. You can wire the VFD to produce 3 phase voltage from a single phase source ( 240 volt ) The cost depends on motor size
-- I started off with nothing I have most of it left
johnzo
#7 posted 05-30-2011 04:22 PM
Dave,
For a variable speed motor and controls, look for a used treadmill on Craigslist. You should be able to pick one up for about $50 bucks. Make sure everything works and that it comes with all the speed controls.
John Z
View rance's profile
rance
4258 posts in 3154 days
#8 posted 05-30-2011 04:54 PM
Try your local Grill supplier. A Rotissouri motor might do well.
