Grease to use on Reeves drive
« back to Woodturning forum
Forum topic by Bobholmes33 posted 01-04-2018 09:19 PM 724 views 0 times favorited 7 replies Add to Favorites Watch
View Bobholmes33's profile
Bobholmes33
22 posts in 403 days
01-04-2018 09:19 PM
What kind of lube would you use on a reeves drive lathe?
-- Bob, Helena, Montana
7 replies so far
View Madrona's profile
Madrona
121 posts in 1136 days
#1 posted 01-05-2018 03:09 AM
When I had one, I would just apply a few drops of very light oil onto the shaft about once per year. It was a 1970’s Delta lathe that I owned for twenty years. Never had an issue.
-- Living In The Woods Of Beautiful Bonney Lake, Washington
View MrUnix's profile
MrUnix
7114 posts in 2440 days
#2 posted 01-05-2018 03:20 AM
I just use wax.
View lew's profile (online now)
lew
12513 posts in 3996 days
#3 posted 01-05-2018 04:55 AM
Lithium spray grease from WD-40
View JRsgarage's profile
JRsgarage
337 posts in 750 days
#4 posted 01-05-2018 03:38 PM
i called General when i was tuning up a 160 lathe and was told to use any high quality bearing grease.
-- Two is One, One is None
View rwe2156's profile (online now)
rwe2156
3237 posts in 1722 days
#5 posted 01-05-2018 04:32 PM
I was told by tech for my lathe not to use oil or grease.
They said use a graphite lubricant.
MrUnix
#6 posted 01-05-2018 05:09 PM
Pretty much any good lube will work. If the mechanism is exposed to sawdust and other gunk, anything that isn’t ‘wet’ is best, like wax, dry lube, graphite, etc… otherwise, light machine oil is a good choice. I’d stay away from greases, as they are just dust magnets, even in environments where there shouldn’t be. Here is a snippet from a Powermatic manual with their recommendation:
View OSU55's profile
OSU55
2034 posts in 2230 days
#7 posted 01-05-2018 05:21 PM
I use a dab of grease on the sliding pulley area only. Wax just didnt provide enough friction reduction. Wax is used on all other areas. Over 5 years of use that small amount of grease hasnt been an issue with dust or dirt – the mechanism works great.
