No joiner, would a hand-held power planer do?
Forum topic by kwblack posted 03-17-2011 11:13 PM 5442 views 0 times favorited 6 replies Add to Favorites Watch
View kwblack's profile
kwblack
31 posts in 2837 days
03-17-2011 11:13 PM
I want to straighten the edges of some reclaimed pine flooring after ripping off the tongue and groove. I used my circular saw, since I don’t have a table saw in my small shop. I don’t have a joiner, could I use a hand-held power planer to clean up the edges? I plan to use biscuits and glue up the pine to make panels for a wall unit.
View GregD's profile
GregD
788 posts in 3103 days
#1 posted 03-17-2011 11:43 PM
How about a router table? That can work for edge jointing.
The other challenge I think you will face is cutting the 2nd edge parallel to the 1st edge.
-- Greg D.
View Jim Finn's profile
Jim Finn
2647 posts in 2889 days
#2 posted 03-17-2011 11:49 PM
NO! The hand held power planer will not work. Not enough control on debth of cut to make a steight edge. A table saw cut would be a LOT better.
-- Website is https://craftingcouple.com/
View chrisstef's profile
chrisstef
17310 posts in 2973 days
#3 posted 03-18-2011 12:50 AM
id say it would be awfully tough to get a straight edge using a power planer, a hand plane would be better and a router even better than that
View Luke's profile
Luke
290 posts in 2654 days
#4 posted 03-18-2011 01:10 AM
I have a power planer, and I know its mostly because of my inexperience, but I seem to do more bad with that thing than good, and have to grab my hand planer to fix the snipe I caused by using the power planer.
View jeepturner's profile
jeepturner
939 posts in 2760 days
#5 posted 03-18-2011 01:21 AM
You may have missed this. Check it out, it may answer your question.
-- Mel,
View richgreer's profile
richgreer
4541 posts in 3042 days
#6 posted 03-18-2011 01:29 AM
I have a power hand held planer and I think of it strictly as a carpenter’s tool. I use it to trim doors and door frames. I would never use it for a woodworking application. It’s too hard to control.
