Need advice for 22" wood jointer
Forum topic by KK1 posted 03-17-2011 09:27 PM 2198 views 0 times favorited 17 replies Add to Favorites Watch
View KK1's profile
KK1
5 posts in 2655 days
03-17-2011 09:27 PM
Hello I’m new to the forum, but have been woodworking since I was a child, I use power tools some, but really like using old hand tools the most and just recently found this site and forum.
I’ve been using wood molding planes for a while (I currently have 30, mostly all Chapin’s), but just obtained a new (new to me) 1820-1850 Chapin 22” wood joining plane in great shape.
Typically with my molding planes a light tap on the back and the irons slip right out, but the iron in this plane is stuck so bad that I have not been able to remove it so I can sharpen it and flatten the sole.
I’m curious if anyone has any idea’s to gently persuade the iron out of the plane?
17 replies so far
View Dan's profile
Dan
3630 posts in 2908 days
#1 posted 03-17-2011 10:52 PM
I would lube the blade with something and try and wiggle it out with a vise grip plier. Thats my only guess.
-- Dan - "Collector of Hand Planes"
View lwllms's profile
lwllms
555 posts in 3309 days
#2 posted 03-18-2011 01:49 AM
A more humid environment will help. Wrap it over night in a damp cloth? I’m not sure how that would work because I’ve never done it. I have clamped a smooth plane, toe on one jaw and heel on the other, in a vise to free up an iron. A clamp might work on a longer plane. I’d try increasing the moisture content of the wood first, though.
View poopiekat's profile
poopiekat
4356 posts in 3762 days
#3 posted 03-18-2011 01:59 AM
I would try DECREASING the moisture content of the wood. A tight container filled with dessicant maybe, or perhaps to leave it out in a solar kiln or other method of lowering the moisture content. Got a moisture meter? You’d want the wood to shrink, not swell up. Nice plane, I have a few Chapin’s myself but they are molding planes.
lwllms
#4 posted 03-18-2011 02:04 AM
poopiekat,
The problem is that the wood HAS shrunk around the iron. This needs to be reversed. The top and sole of the plane are the flat sawn surfaces and increasing the moisture content will cause the plane to swell in width. Because there’s far more wood in the overall width of the plane than in the combined width of the cheeks, increasing the moisture content of the plane’s body will make the escapement a little wider. This is what is needed to release the iron.
poopiekat
#5 posted 03-18-2011 02:26 AM
lwwlms: I’ve noticed that the wooden planes I’ve had shipped to my house sometimes have irons that are stuck. Once acclimated to my rather dry shop, ,the problem goes away by itself. This after being outside in transit for a week or 2. I’m just presenting my observations of fact, but KK1 is certainly free to choose. I clued in to his statement that ‘he just obtained…’which suggests that the plane either may have been in transit, or perhaps came from a different environment.
lwllms
#6 posted 03-18-2011 05:18 AM
“Why argue a point when you are wrong?”
Jonathan,
The plane has shrunk in width, the iron didn’t. That’s the problem. If the op can cause the wood to swell, it will release the iron. Perhaps you have more experience with wooden planes than me but I seriously doubt it.
Larry Williams
http://www.planemaker.com
lwllms
#7 posted 03-18-2011 07:01 AM
Jonathan,
If the moisture content of the wood goes down, the wood shrinks and points A and B will be closer together. So, if the plane drys more, the iron will be held more securely. If the moisture content increases, the wood will expand and points A and B will be further apart. The latter will release the iron.
View 747DRVR's profile
747DRVR
199 posts in 3384 days
#8 posted 03-18-2011 07:22 AM
At first I agreed with most of the people here that the plane needed to get dryer,but after the last post I think lwllms is right.
View KK1's profile
KK1
#9 posted 03-18-2011 03:13 PM
Thank you all for the quick responses,
poopiekat-you are correct I recieved it via usps on thursday, opened it and immediately jumped (kid in a candy store syndrome)
Dan- I don’t want to mark up the iron with the vise grip teeth
after trying to tap it, my first inclination was also that the wood needed to be dryer, but based on lwllms’s explanation I broke out the calipers and points A-B at the iron is 1 mm wider than points A-B at the front of the iron box, I also see a hairline crack in the corner just behind the iron, which also leads me to believe the wood is dry and shrank around the iron.
I think I’ll let is stabilize in the shop first, then try to increase moisture per Larry’s recommendation (unfortunately I don’t have a moisture meter, perhaps it’s time to get one)
View Bill White's profile
Bill White
4950 posts in 3988 days
#10 posted 03-18-2011 05:37 PM
Well, based on some of the “advise” I’ve read here, why not just set fire to the plane. The iron will come free.
Note to self: Remember! Vice grips are always a last resort after dynamite has been used.
Bill
-- bill@magraphics.us
View KK1's profile
KK1
#11 posted 03-18-2011 07:06 PM
Bill,
My first thought was to cut the plane in half, but your fire method would work.
Besides fire, dynamite and general destruction of the plane, do you have any constructive advice?
View KK1's profile
KK1
#12 posted 03-18-2011 07:09 PM
I appreciate everyone’s passion,
but I’m really looking for a “gentle” none destructive means of removing the iron without damage to the iron.
To that point I’m going to take it slow and start by allowing it to sit in my shop and stabilize to a known environment. After that I’ll carefully take the next steps.
View JBoss's profile
JBoss
37 posts in 3075 days
#13 posted 03-22-2011 11:59 PM
Ok, not a wood plane master here but lwllms idea seems to be on point. plus just as an aside, debating how a wooden plane works with one of of the founders of clark and williams is sorta like debating a Stanley no4 with leonard bailey
poopiekat
#14 posted 03-23-2011 07:32 PM
KK: As mentioned on a similar thread, I noticed that it looks like somebody retro-fitted a chipbreaker to the cutter of this plane, and forced the assembly into a slot broached for one cutter and nothing else. with this in mind, and wishing to preserve the integrity of the body and iron, I’d consider something like an ’s’-hook in the hole of the iron, affixing the plane body in a vise, and a slide hammer to yank the blade free. Then I’d use a ‘plane float’ to properly re-size the body to accommodate the chipbreaker, if you elect to keep it as you found it. Perhaps somebody was trying to contend with blade chatter, or too much digging in. This would have been remedied better by a cutter of correct thickness, and/or re-soling the plane with a narrower mouth opening. Funny how even plane-makers overlooked the presence of the nonstandard chipbreaker, eh?
View Jeff's profile
Jeff
439 posts in 3222 days
#15 posted 03-23-2011 07:39 PM
Could you put a spreader clamp in the body and ever so gently see if you can force the plane walls away from the iron?
