How to make a long, very thin tapered cut?
Forum topic by toddhd posted 01-04-2018 03:43 AM 1565 views 0 times favorited 21 replies Add to Favorites Watch
View toddhd's profile
toddhd
6 posts in 3025 days
01-04-2018 03:43 AM
Topic tags/keywords: question
I have a 12 foot piece of molding I need to cut to fit. The floor is uneven, so when I place the molding, one end fits the adjoining piece of molding perfectly, but the other side is 5/16” too high due to the floor. So I need to taper cut the bottom edge of the molding, from 5/16” on one end to 0” on the other end. I do have a good tablesaw, but not much experience.
Can anyone give me advice on how to make such a slender tapered cut over a 12’ length?
Thank you
-- -Todd
21 replies so far
View Nubsnstubs's profile
Nubsnstubs
1336 posts in 1816 days
#1 posted 01-04-2018 03:52 AM
Are you sure it’s the floor. The molding could be warped. In either case, nail at the good fitting end, and go to the other end. Make it fit, then nail it. 5/16” on a 12 foot run is nothing to fret over. ............ Jerry (in Tucson)
toddhd
#2 posted 01-04-2018 04:01 AM
Thanks nubsntubs, but I’m not sure what you mean by “make it fit then nail it down”. It’s not gonna fit unless I cut it. I added a photo above that might help better explain what I’m seeing. This is the end that’s off because of the poorly laid tile floor. The other end fits flush as it should.
https://photos.app.goo.gl/E8cnMMRsfuYqD8D03
-- -Todd
toddhd
#3 posted 01-04-2018 04:03 AM
Just to be clear, it is not just the one tile at the end that is off, the entire floor gradually rises from 0” to 5/16” over a 12 foot span.
-- -Todd
View Loren's profile
10477 posts in 3734 days
#4 posted 01-04-2018 04:07 AM
Snap a chalk line cut with a jig saw. Hand
planes are useful too for this sort of thing.
A pencil line can be plotted out using 1/32”
increments spaced at whatever intervals would
make for a 5/16” rise over 12’. Probably straighter
that way than a chalk line, assuming the molding
is straight.
View Rayne's profile
Rayne
976 posts in 1626 days
#5 posted 01-04-2018 04:08 AM
bandsaw? might need some help holding a 12’ long piece, but it’ll let you trim that little bit free-hand.
View GR8HUNTER's profile
GR8HUNTER
4364 posts in 799 days
#6 posted 01-04-2018 04:08 AM
i would snap a chalk line and use my circular saw :<))
View John Smith's profile
John Smith
1256 posts in 249 days
#7 posted 01-04-2018 04:11 AM
I see the photo now.
all the above suggestions will work…... just depends on your skill and tools available.
I have run into this situation several times before renovating older homes.
nothing to be afraid of – it is only baseboard…... if you mess it up, get another board.
experience is the best teacher.
I just purchased a 1957 home and ALL the baseboards are messed up and will be replaced.
and with sagging uneven floors, I will be addressing the same issues that you have.
-- Graduated Valedictorian from the University of HardKnocks --
toddhd
#8 posted 01-04-2018 04:14 AM
Thank you guys, that’s a great idea! Maybe I can clamp another board to the top of that molding as a guide, and then use the circular saw as you said. Seems a lot easier than trying to cut with the tablesaw. Or the chalk line and just freehand it as suggested. Doesn’t have to be perfect.
-- -Todd
Nubsnstubs
#9 posted 01-04-2018 04:17 AM
A picture is always worth a thousand words, but I’m gonna make it less than that. If you have a jointer, taper cut the board. in this case, start your board about 3-4 feet on the out feed table. If you don’t have a jointer, scribe a line on the board, and free cut it on your table saw, starting somewhere about midway. My above comment was thinking the floor rose some causing the board to lift.
“Make it fit” meant, if the floor was high in the middle causing the board to be lifted, a nail or two and some downward pressure would have worked. This is not the case, because the tile floor is tile thickness higher than the floor that already has the baseboard nailed. ................ Jerry (in Tucson)
View Brian Ahern's profile
Brian Ahern
12 posts in 233 days
#10 posted 01-04-2018 04:42 AM
Todd, I do this all the time I have a hard time explaining in words but this is what I do to get a perfect taper on the table saw,looks like you need to remove right side so flip flop my drawing
-- Brian Ahern
View Walker's profile
Walker
142 posts in 558 days
#11 posted 01-04-2018 05:20 AM
Hand planes are useful too for this sort of thing.
- Loren
I make long tapered pieces with my hand planes all of the time….by accident! : ) I bet if I was intentionally trying to make it tapered it would come out straight.
-- ~Walker
View jerryminer's profile
jerryminer
937 posts in 1528 days
#12 posted 01-04-2018 07:55 AM
With 40 years in finish carpentry behind me, I’ve installed miles of baseboard.
SOP is to scribe the baseboard to the floor. A straight cut is almost never a good fit to the floor.
Shim up the low end (if there is one)—temporarily—and set a scribing tool (I use a cheap compass) to the amount of desired “drop” and mark along the bottom edge.
Cut with jigsaw, circular saw, grinder, belt sander, block plane, or whatever you like. For large amounts, I use a jig saw. Once I’m close to the line I switch to an angle grinder with a sanding disc. A back-bevel is also helpful.
View Steve's profile
Steve
553 posts in 669 days
#13 posted 01-04-2018 02:08 PM
I enjoyed watching this video on installing baseboard from Matthias Wandal
https://www.youtube.com/watch?v=hbao8AWruq0
View JayCee123's profile
JayCee123
200 posts in 851 days
#14 posted 01-04-2018 02:11 PM
i use to scribe the molding as described by Jerryminer and use an electric hand plane to approach the scribe line. If i needed to fine tune it further, I’d hit with a hand plane. Secure the molding at your bench or saw horses. I found it easier and safer to use the tool against such a long work peice, rather then trying to send the work peice through a sationary tool. Another suggestion is to back bevel the cut slightly. That makes it easier to “tap” down the moulding to fit the floor, if needed.
View DS's profile
DS
2967 posts in 2507 days
#15 posted 01-04-2018 02:21 PM
+1 to jerryminer.
Scribing is the way to go.
For me, I would jig saw close to the line and then fine tune with my portable belt sander with a 40 grit belt.
Makes short work of something like this.
