| Forum topic by MsDebbieP | posted 797 days ago | 914 views | 0 times favorited | 17 replies | ![]() |
797 days ago |
Topic tags/keywords: safety router Safety in the shop tips for the router. What are some tips to work safely on and around a router? (See all SAFETY TIP GATEWAYS here)
-- ~ Debbie, Canada (http://www.execulink.com/~yohan) |
17 replies so far
#1 posted 797 days ago |
The obvious that applies to all tools. Unplug it when doing anything other than cutting something with it. -- If all you have is a hammer, everything looks like a nail! |
#2 posted 797 days ago |
Never go between the fence and the bit… with the work piece. Never go anywhare near the bit with your fingers. duhhh ;) -- If all you have is a hammer, everything looks like a nail! |
#3 posted 797 days ago |
Don’t remove too much material with one pass. Light cuts are cleanest and safe. -- If all you have is a hammer, everything looks like a nail! |
#4 posted 797 days ago |
Hearing & eye protection! -- Randy-- I may not be good...but I am slow! |
#5 posted 797 days ago |
always ‘climb cut’ when possible don’t cut ‘down hill’ unless absolutely necessary -- david - only thru kindness can this world be whole . If we don't succeed we run the risk of failure. Dan Quayle |
#6 posted 797 days ago |
If something “seems” wrong, there probably “is” something wrong. Stop, unplug and look everything over. In other words, if it doesn’t feel right, don’t do it. |
#7 posted 797 days ago |
Keep the collet clean, the work area clean, and your mind on what you are doing. Listen to the router if it sounds a little different, stop and find out why. Remember the router is one of the fastest spinning tools you will work with and things happen fast. -- Measure twice, cut once, and hope for the best. |
#8 posted 796 days ago |
No offense to anyone, Im sure it was a typo, but I would not do any cliimb cutting untiil you have a good feel for the router. |
#9 posted 796 days ago |
Check bits for damage before each use. NEVER alter a bit in any way. I learned that one the hard way. I altered the bearing on a slot cutter and as soon as I turned it on out it came and put a nice divot in my knee. Bent the bit too. -- Darrell, making more sawdust than I know what to do with |
#10 posted 796 days ago |
follow the max rpm instructions written on the bits, or use the diagram from the router manual! |
#11 posted 796 days ago |
Never pull your router out of your table without turning off the power FIRST! -- Folly ever comes cloaked in opportunity! |
#12 posted 796 days ago |
someone, here, posted once that they had used some cheap router bits and they shattered – very dangerous. “You get what you pay for” applies. -- ~ Debbie, Canada (http://www.execulink.com/~yohan) |
#13 posted 796 days ago |
I agree w/everyone that said to take small passes, don’t take the whole depth of a cut all at once. -- Roger from KY. Work/Play/Travel Safe. Kentuk55@bellsouth.net |
#14 posted 796 days ago |
Never go between the fence and the bit… with the work piece. -- Rick |
#15 posted 796 days ago |
Use wooden clamps[not fingers]to hold small parts on the router table.Take very shallow cots when routing end grain as the bit really wants to grab end grain.Routing end grain on a small piece is really the time to get out your wooden clamps.MY scars remind me daily ! -- " I'll try to be nicer, if you'll try to be smarter" gfadvm |
| Forum | Topics |
Woodworking Skill Share
8793 |
Woodturning
222 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
80 |
Finishing
1532 |
3550 |
15784 |
Hand Tools
2036 |
Jigs & Fixtures
495 |
Wood & Lumber
2841 |
809 |
Focus on the Workspace
902 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6159 |
