Is this design I made worth trying out?l
Forum topic by Tightanium posted 01-04-2018 01:38 AM 595 views 0 times favorited 6 replies Add to Favorites Watch
View Tightanium's profile
Tightanium
4 posts in 385 days
01-04-2018 01:38 AM
Hello guys! I’m a new guy here, I will introduce myself later as it is currently 2AM and my bed is calling for me. I drew this out on a piece of paper this morning during school and thought it would look like a nice piece on the wall, you can call it a shelf. I drew it out digitally, here it is:
I can’t really tell if it would look great as a shelf. Also I was first planning on using 3mm dowels however it looks like it would be pretty tricky. What joinery techniques would you recommend? Thank you very much!
View Loren's profile
10477 posts in 3889 days
#1 posted 01-04-2018 02:04 AM
It will be tricky to cut all the joint angles
accurately but it can be done.
I suggest a biscuit joiner with a fence for
variable angles. Similar dowel joiners are
available but the cheap ones have issues
and the good ones are very pricey.
With rigorous precision I suppose dowel
holes could be drilled with a drill press.
Tightanium
4 posts in 385 days
#2 posted 01-04-2018 02:19 AM
Hey Loren, thanks for the reply!
The bed could wait till morning, so I created this quick sketchup plan:
I’m starting to have hope in this. I changed the design a tad. What do you think?
EDIT: P.S, I know some of the cuts would be inefficient, as I said this is a quick plan :D
#3 posted 01-04-2018 02:45 AM
Assembly may be like a puzzle with only
one path to success. It can be done. You
just have to think it through.
Tightanium
4 posts in 385 days
#4 posted 01-04-2018 02:48 AM
Thanks. I’ll try it tomorrow with scrap wood. Cutting the angles right with my mitre saw is going to be fun…
View bbasiaga's profile
bbasiaga
1242 posts in 2237 days
#5 posted 01-04-2018 03:34 AM
Everything is worth a try. How else would we come up with new stuff?
Brian
Tightanium
4 posts in 385 days
#6 posted 01-04-2018 04:44 AM
Final design and dimensions:
I need 3 boards that are 20×115mm, 2 metres long each.
Total cost for me will be 25 euros ( $30 )
Tomorrow I’ll make a prototype using some uniform scrap wood, if it looks right, I’ll buy the boards and build it.
Thank you all!
