Bevel-Up in a Bevel-Down Plane?
Forum topic by HorizontalMike posted 03-17-2011 04:08 PM 2107 views 0 times favorited 10 replies Add to Favorites Watch
View HorizontalMike's profile
HorizontalMike
7757 posts in 2913 days
03-17-2011 04:08 PM
Topic tags/keywords: bevel up bevel down scraper smoother fore plane
I have two old #418 Fore planes and am considering setting one of them up as a scraper/smoother. I was looking at the Veritas® Scraping Plane Insert but had a brain fart and began thinking about just reversing the blade’s bevel on my #418 (45 + 25 = 70 degrees) and using THAT as a scraper/smoother.
Has anyone done this with success?
10 replies so far
View Bill White's profile
Bill White
4930 posts in 3960 days
#1 posted 03-17-2011 04:30 PM
It doesn’t work like that. The scraper plane doesn’t have an edge like a plane. It is a flat surface that has been honed and burnished to form a “curl” that scrapes the surface.
Bill
-- bill@magraphics.us
View richgreer's profile
richgreer
4541 posts in 3074 days
#2 posted 03-17-2011 04:36 PM
I scraper blade really needs to be tilted forward to work properly. The cutting action with a scraper comes from the burr. I could be wrong, but I don’t think taking your bevel up to 70 degrees will work very well.
In my personal experience, I prefer using a card scraper. I though I would like a scraping plane and I bought one but I have never gotten the feel for it and I have never gotten favorable results.
For me, scraping is a “feel thing”. When you have the scraper in the right position it just feels right. That’s why I like card scrapers (except they do get hot).
HorizontalMike
#3 posted 03-17-2011 05:07 PM
So the Veritas® Scraping Plane Insert would be the way to go then? Here are the instructions from Lee Valley that show the scraper blade cut with a 45-degree angle, quite interesting.
It sure seems like you could grind a blade with a 45-50degree angle, reverse it, and then hook it to get a ~95degree angle like a typical scraper. I guess it would not flex like the Veritas version though…
View TheWoodNerd's profile
TheWoodNerd
291 posts in 3191 days
#4 posted 03-17-2011 05:51 PM
At that price, it’s hard to beat
-- The Wood Nerd -- http://www.thewoodnerd.com
16274 posts in 4217 days
#5 posted 03-17-2011 06:24 PM
I think I understand where you are going with approximating the proper angle. The big difference I see is the thickness of the blade (only .016 for the scraper blade as opposed to a much thicker plane iron).
To me, it’s sort of like comparing apples and oranges. Your idea might yield something useful. If you’ve got a blade you don’t mind experimenting with, give it a try. I just suspect it will behave differently from the scraper attachment would. I wonder about steel hardness, and whether or not you can actually burnish a hook on a plane blade as you can on a scraper blade.
View Dan's profile
Dan
3630 posts in 2879 days
#6 posted 03-17-2011 06:31 PM
wow, I never knew they made a insert that you can use in an old plane. I cant answer your question but thanks for the link. I may get one of these.
-- Dan - "Collector of Hand Planes"
HorizontalMike
#7 posted 03-17-2011 07:05 PM
Charlie,
The hardness of the blade might be an issue and I hadn’t thought of that. BTW, Veritas also sells a thicker 0.024” blade for this insert as well. And yeah, dedicating a blade is also a question. Not sure I want to re-bevel either of my old Sargent or Stanley Sweetheart blades and I sure don’t want to mess with my new Hock blade! And besides, it looks like buying the Veritas insert will cost no more than a replacement blade costs anyways. And the insert has the benefit of flexing under pressure so that you don’t dig in and tear out. I think I am going to like having a long scraper, the more I think about it. Thanks…
#8 posted 03-17-2011 07:58 PM
If you buy it, let us know how you like it. It’s a pretty small investment if it works as advertised.
View Gofor's profile
Gofor
470 posts in 3786 days
#9 posted 03-18-2011 02:51 AM
Don’t know, but thought it interesting that Lie-Nielsen sells a “90 degree” blade for their Low-angle jack that is called a “scraper blade”. With a 12 degree bed, I do not know if the 90 degree blade is the composite angle (90) or just a square bevel (102). To get the same angle, you may be able to just raise the bevel on yours from 25 degrees to more like 50.
I would be concerned about a 25 degree bevel chipping out on the back side as there is no supporting metal after the edge like with a bevel down configuration.
Just a thought
Go
-- Go http://ncwoodworker.net/pp/showgallery.php?cat=500&ppuser=730
HorizontalMike
#10 posted 03-18-2011 06:19 PM
Hey Charlie, Dan, and others,
Just ordered the Scraper Insert from Lee Valley and got their free shipping (free shipping on >$40 purchases from 4/18-28/2011) since I also ordered the thicker blade. Total came to $40.40 so if you are considering buying one of these to convert one of your old hand plane restorations into a dedicated scraper, then now is the time to jump.
That free shipping is like getting that second scraper blade for free, IMO.
