Need source for hardware......Please assist if you can
Forum topic by becikeja posted 01-03-2018 01:25 AM 1524 views 0 times favorited 10 replies Add to Favorites Watch
View becikeja's profile
becikeja
952 posts in 3018 days
01-03-2018 01:25 AM
I have searched and cannot find what I need. I am hoping some of you can point me to a reliable on-line hardware source.
I am looking for: #4-40 black threaded rod – lengths 3.25” and 1.75” but can cut to length if I can find the rod. #4-40 black machine screw – lengths 0.5” and 0.75” #4-40 black wing nuts
Thanks for the guidance.
10 replies so far
View Mike_in_STL's profile
Mike_in_STL
730 posts in 739 days
#1 posted 01-03-2018 01:27 AM
I would look at McMaster – Carr or Fastenal.
https://www.mcmaster.com/
https://www.fastenal.com/
-- Sawdust makes me whole --Mike in STL
View Loren's profile
10477 posts in 3853 days
#2 posted 01-03-2018 01:32 AM
Steel can be blackened with oil and a torch.
View bondogaposis's profile (online now)
bondogaposis
5098 posts in 2557 days
#3 posted 01-03-2018 01:40 AM
Yes it quite easy to do.
- Loren
-- Bondo Gaposis
View Kelly's profile
Kelly
2134 posts in 3149 days
#4 posted 01-03-2018 01:42 AM
becikeja
#5 posted 01-04-2018 01:30 AM
I checked with Mcmaster-carr good call but they didn’t have a black option in the size I need.
The Oil and Torch option is interesting, but I have no idea how to pull it off. What type of oil? how do you do it?
bondogaposis
#6 posted 01-04-2018 02:12 AM
I use BLO. I like to remove the zinc coating first it if it has one. I prefer to soak it in citric acid to remove the zinc, or you can just heat it with a torch to remove it. Then gently heat it with a torch and apply oil with a natural bristle brush. This will ruin the brush, so use a cheapo. You do not want to get the parts glowing red hot, that will take the temper out. Just light heat until the color changes, you can even do it with a heat gun, but it takes longer.
-- Bondo Gaposis
becikeja
#7 posted 01-05-2018 01:26 AM
Appreciate the input, I will give it a try this weekend, and see what happens.
View Radu's profile
Radu
330 posts in 3249 days
#8 posted 01-05-2018 02:31 AM
Try “Super Blue” or gun blue
Here is a video: https://www.youtube.com/watch?v=ACpKCYTvgWw;
I’m sure there are tons more
Let us know how it works; if you do the acid thing it’s probably better outside
View lew's profile
lew
12446 posts in 3961 days
#9 posted 01-05-2018 04:58 AM
becikeja
#10 posted 01-08-2018 12:50 AM
I found the screws I needed on Mcmaster-Carr. Thanks for the recommendation. Unfortunately still no luck on the black threaded rod.
I tested the BLO and torch suggestion and above on some old screws. Seemed to work well enough. I’ll order a std. threaded rod, and torch it.
Appreciate everyone’s help.
