bowl gouge question
« back to Woodturning forum
Forum topic by Karda posted 01-02-2018 07:03 PM 480 views 0 times favorited 2 replies Add to Favorites Watch
View Karda's profile
Karda
1328 posts in 758 days
01-02-2018 07:03 PM
Hi, i noticed that when I am cutting from right to left on the bowl blank the gouge is cutting good and smooth. I am exerting little pressure if any the tool is just doing it job. what is happening is the gouge will cut less and less until it slides right of the wood. its almost like it is a scoop cut. i have tried re adjusting the tool and that works but leaves a lumpy surface. Any idea what I am doing wrong
2 replies so far
View LeeMills's profile
LeeMills
619 posts in 1505 days
#1 posted 01-02-2018 09:26 PM
- Karda
slide out of the wood? off of the wood?
Only a guess but it seems you are changing the direction of the cut too swiftly. The red line in the pic shows what direction the tool will cut in. For example you want a platter with a flat bottom. To cut a straight line do not move the angle where it meets the wood and simply slide the tool along the rest.
For the outside of a curved bowl you have to slowly change the direction. For the outside of curved bowl the line may start at the base perpendicular to the bed and and finish be parallel with the bed at the rim. It sounds like you are changing the direction too quickly if you are going off the bowl.
Sorta like diving a car around a curve. Cut the wheel to follow it and all is fine, cut the wheel too much and off you go into the ditch.
I assume you are trying to cut with body movement and not just arm movement.
Someone, I believe Lyle Jamieson, had a good youtube segment to show it. I will try to find it.
Karda
#2 posted 01-02-2018 10:43 PM
ok thanks
