| Forum topic by Safetyboy | posted 259 days ago | 136 views | 0 times favorited | 8 replies | ![]() |
259 days ago |
Got my boards all jointed & paned… glued up a ~15” wide panel out of 3 boards… used homemade cauls top & bottom to keep it flat…. Still the joints are not perfectly smooth – less than a 1/32 off, but it’s there. How do I clean it up now to make it perfectly flat? Do I just go nuts with the ROS? Should I attempt to use my #4 smoother plane (still learning what that should feel like…)? My power planer is only 13”, so I can’t send it back through that… And another question for next time – should I expect the joints to be perfectly smooth if I’m doing everything right, or do even you experts need to clean them up a bit? - Thanks, Kevin -- -- Kevin in Mentor, Ohio |
