Old lathe head stock
« back to Woodturning forum
Forum topic by Mervyn posted 01-02-2018 04:43 AM 409 views 0 times favorited 5 replies Add to Favorites Watch
View Mervyn's profile
Mervyn
2 posts in 259 days
01-02-2018 04:43 AM
Topic tags/keywords: lathe
Hi. I’m new here. I have an old montgomery wood lathe.
My head stock has a 0.495” diameter shaft. It currently I was hoping to add a pen mandrel (with a #2 or #1 morse taper) and wondered if there is any adaptors that can be used.
Thank you in advance!
5 replies so far
View bobasaurus's profile
bobasaurus
3529 posts in 3298 days
#1 posted 01-02-2018 06:42 AM
Does the end of the shaft have a threaded hole, or is it solid? That might be a tricky part to find, most lathes have an outside threaded shaft with a morse taper inside.
-- Allen, Colorado (Instagram @bobasaurus_woodworking)
bobasaurus
#2 posted 01-02-2018 06:48 AM
You might be able to combine this:
https://www.mscdirect.com/product/details/00185041
with a coupler:
https://www.grainger.com/category/rigid-couplings/couplings-collars-and-adapters/power-transmission/ecatalog/N-i88#nav=%2Fcategory%2Frigid-couplings%2Fcouplings-collars-and-adapters%2Fpower-transmission%2Fecatalog%2FN-i88Z1z0hjdy
And then find a 1” to 0.5” shaft reducer. A lot of work and fittings, though.
View MrUnix's profile
MrUnix
6882 posts in 2313 days
#3 posted 01-02-2018 07:01 AM
There is an adapter for the shopsmith that attaches via a set screw, although their spindle is 5/8”, not 1/2”... but you might be able to use one with a reducing bushing if you can find one. The shopsmith one will give you a pretty standard 1”x8tpi spindle. Either way, it doesn’t seem like it would run very true attached like that.
Alternatively, is the spindle hollow… have a taper or threaded hole? One last ditch thought – if you have any machine shops in your area (or have a metal lathe), you could take the spindle and have the end threaded.
View Woodknack's profile
Woodknack
12329 posts in 2494 days
#4 posted 01-02-2018 09:19 AM
I don’t know of a 1/2” adapter. You could have one made but unless you really love that lathe, I wouldn’t spend any money on it.
This won’t solve your problem but might be useful if you go lathe shopping
http://thewoodknack.blogspot.com/p/how-to-buy-vintage-lathe.html
Mervyn
2 posts in 259 days
#5 posted 01-03-2018 02:07 AM
Thank you all. Yes the spindle is solid. I was hoping to get into pen turning and bought this one. As per many people’s advise, I’ll look into getting another lathe.
