How to fix a void in a floor...
Forum topic by Bob Areddy posted 03-16-2011 07:04 PM 1214 views 0 times favorited 11 replies Add to Favorites Watch
View Bob Areddy's profile
Bob Areddy
192 posts in 3398 days
03-16-2011 07:04 PM
Hey all. My girlfriend would like to expand her closet in her bedroom. The floors are hardwood that run perpendicular to the closet opening.
The closet is wide but shallow. However the opening is much more narrow than the width of the interior of the closet. So I suggested that we might be able to open it up…
The question came up as to what to do with the floor that will be newly exposed? The hardwood just butts up to the “wings” of the closet that we plan to tear out.
WWLD (what would Lumberjocks do?)
-- --Bob http://www.areddy.net/wood
11 replies so far
16274 posts in 4215 days
#1 posted 03-16-2011 07:44 PM
I see these options:
1. Fill in the gaps with plywood and the carpet the whole room. :-)
2. “Patch” the newly exposed floor with matching hardwood. It will be obvious no matter what you do.
3. Re-do the entire floor.
I’m interested to see if anyone comes up with an idea I’m missing.
View Jeff's profile
Jeff
433 posts in 3191 days
#2 posted 03-16-2011 07:50 PM
If the “patch” runs perpidicular to the orginal hardwood it’ll look like a frame around the closet. Try using a contrasting color hardwood to make it stand out.
TopamaxSurvivor
18268 posts in 3672 days
#3 posted 03-16-2011 10:52 PM
Charlie, you could pour a thin layer of concrete with an aggregate finsish. It would be in the back and not necessaily have to match & not be that noticable. If you wanted to take the high road, torquoise colored epoxy would be an option.
View Sawkerf's profile
Sawkerf
1730 posts in 3065 days
#4 posted 03-17-2011 12:38 AM
If any of the flooring is “hidden” (i.e. in a place where the closet is wider than the door opening), you could scavage a couple of pieces to use as fillers where the walls have been cut back. You can fill the holes with almost anything since they’ll almost certainly stay covered with shoes, or whatever.
Have you checked to see if you will be messing with a load bearing wall? It’s rare, but sometimes the “front” of the closet is load bearing. If it is, you’ll also need to put in a new (longer) header.
View saddletramp's profile
saddletramp
1180 posts in 2635 days
#5 posted 03-17-2011 12:47 AM
If I am reading your question correctly, you are going to expand the closet into the room so the area in question he floor inside will end up inside the closet. If so, I would just patch it and then carpet the floor in the closet.
-- ♫♪♪♫♫ Saddletramp, saddletramp, I'm as free as the breeze and I ride where I please, saddletramp ♪♪♪♫♪ ...... Bob W....NW Michigan (Traverse City area)
View Tomoose's profile
Tomoose
422 posts in 3370 days
#6 posted 03-17-2011 01:04 AM
I’m sort of with Sawkerf – I would scavenge from the inside of the closet to match the hole in the new opening and then re-do the whole closet floor (or maybe just a border around the back 3 walls in the closet) with some aromatic cedar – keep moths at bay (or is that superstition?) – at least it smells nice
Tom
-- “I am always doing that which I cannot do, in order that I may learn how to do it.” Pablo Picasso
Bob Areddy
#7 posted 03-17-2011 02:16 AM
Lots of good ideas I can present to her. Keep the suggestions coming!
Sawkerf, how do I know if it’s load bearing?
View Mark Shymanski's profile
Mark Shymanski
5621 posts in 3709 days
#8 posted 03-26-2011 05:40 PM
I like the idea of relocating pieces from inside the closet to ‘match’ the original floor in the room, it will still be a different colour than that exposed to more light, but it should be a fairly close match. The accent wood to deliberately make the patch a ‘design’ element appeals to me also as it is a easier thing to do than refinish the entire floor (and ‘gasp’ Charlie! cover a wood floor with vector laden carpet!..;-) and could really add to the look of the room.
View canadianchips's profile
canadianchips
2600 posts in 2993 days
#9 posted 03-26-2011 10:15 PM
If you really want to make her happy. Build her a new house !
Seriously though.
I would try to find more flooring that matches the hardwood you have. Blending it in will look much nicer than any PATCH. You might have to re-finish the rest of the floor as well.
View Ritty's profile
Ritty
63 posts in 2793 days
#10 posted 03-26-2011 10:33 PM
depending on how big the gap is you might be able to use molding to do it i suggest a little more than your ordenary quarter round.
Sawkerf
#11 posted 03-27-2011 01:11 AM
If you have to ask, you probably need some help to figure it out. If you know a General Contractor, offer to pay him/her a couple of bucks to help you make the decision.
Of course, you could also start ripping things out and see if the ceiling tries to collapse. – lol
