Finishing Cutting Boards
« back to LumberJocks.com Site Feedback forum
Forum topic by jasoncarpentry posted 03-16-2011 05:56 PM 2004 views 0 times favorited 6 replies Add to Favorites Watch
View jasoncarpentry's profile
jasoncarpentry
142 posts in 2654 days
03-16-2011 05:56 PM
OK, I’m finishing the end-grain cutting board I asked about a few days ago. My attempts at sanding & planing the board resulted in one good side and one terrible side. I’ve covered the terrible side with two pieces of 1/4” thick, book-matched, solid maple. Needless to say, this’ll be the bottom and will never be used as a cutting surface. I’ll add “feet” just to make this clear.
I know that the finish for the working surface should be mineral oil, plus a mixture of beeswax & mineral oil for good measure. And I read some time ago that, when you apply a finish to one side of a piece of wood, you should do the same to the other side to avoid differences in moisture penetration, etc. HOWEVER, I’d really like to apply a tough, permanent, waterproof finish to the solid bottom. I’m thinking of satin polyurethane.
Any thoughts?
-- Jim in Tennessee
View kpo101's profile
kpo101
32 posts in 2628 days
#1 posted 03-16-2011 06:36 PM
You said (My attempts at sanding & planing the board resulted in one good side and one terrible side.) Just how terrible is the bad side? How thick is the board? There are ways to straighten rough sides especially if you have a good side with a simple router and jig. I also build end grain boards, one type is in the picture by my name.
-- When the problem becomes just too much, There is always the directions!! Karl O. of Louisiana
jasoncarpentry
#2 posted 03-16-2011 06:50 PM
The bad side is VERY bad! it’s gouged and chipped out from my clumsy attempts at planing and sanding (using a hand-held belt sander). I finally took it to my local cabinet shop, and he did a terrific job on the “good” side using his thickness sander.
I’ve already glued on the 1/4” maple, so it’s too late to resurrect the bad side. Just chalk it up to experience. As it stands now, the board is a little thicker than 1”.
BTW, your board is beautiful! What’s your secret?
-- Jim in Tennessee
jasoncarpentry
#3 posted 03-16-2011 06:55 PM
Hey Karl O-
You may have missed my original post about the board. The replies were very helpful:
http://lumberjocks.com/topics/25074
-- Jim in Tennessee
kpo101
#4 posted 03-16-2011 09:07 PM
I do a lot of AutoCad work , When i first designed this board on paper, it had me scratching my head about all the pieces, but after I looked at it close its not that difficult. You just have to use 1-1/8 inch thick stock or you will have a lot of waste using 1x materials. The small pieces each measure 1-1/2” x 1/2”, now there is and additional 2 glue steps to it. About 3 years ago i made a double leaf kitchen island and had this pattern on the top. When completed the top was 24” wide x 7’ long x 2-1/4” thick (48” center stationary section with the 2-18” leafs).
kpo101
#5 posted 03-16-2011 09:16 PM
I went and checked out the topic at http://lumberjocks.com/projects/25275 and that sled is exactly like mine with the exception of the Ryobi router I use Porta-cable, just have better luck with them.
View Canadian Woodworks's profile
Canadian Woodworks
702 posts in 3069 days
#6 posted 03-16-2011 09:46 PM
I think that you should just use mineral oil for this first coat apply it to top end grain surface keep it wet re apply when you get “dry” spots do this for like an hour or more. I would think it would be sucked all the way through to where the bottom maple was added. End grain is like a bunch of straws the mineral oil will be drawn all the way through I’ve had it easily go through 2’’ of end grain and I usually use RAW linseed oil, in comparison it’s thicker than mineral oil.
-- Paul Lemiski, Ontario Canada, Custom Wooden Rocking chairs and tables http://www.canadianwoodworks.com
