MDF or Plywood for fireplace mantel and surround
Forum topic by kent_michaels posted 799 days ago 5181 views 0 times favorited 8 replies Add to Favorites Watch
View kent_michaels's profile
kent_michaels
34 posts in 862 days
799 days ago
Topic tags/keywords: question
I already have a design in mind for a fireplace mantel and surround but I’m not sure which material is best to use around a fireplace. i’d really appreciate any advice on this from more experienced wood workers. Thanks for any help.
8 replies so far
View Bertha's profile
Bertha
13111 posts in 864 days
#1 posted 799 days ago
Ply for me for sure. I’m not a homebuilder, so I’ll defer to the experts below. Good luck!
View Bill White's profile
Bill White
2607 posts in 2131 days
#2 posted 799 days ago
Just finished building my second surround from MDF. Have had no problems with either construction or heat from the FP. Would do it again. Both were paint grade, so finish was not an issue. Primed ‘em with shellac to seal before the paint.
Bill
-- bill@magraphics.us
View Luke's profile
Luke
202 posts in 858 days
#3 posted 797 days ago
I just did my fireplace with Frame and Panel Wainscoting and Mantel, I used Ply because I HATE MDF, but in hindsight, MDF might have given a more consistent coat of paint being that Plywood has some inconsistencies in texture. (Yes i did use Cabinet Grade Plywood)
So my next adventure for Wainscoting will probably be with MDF.
View drewnahant's profile
drewnahant
218 posts in 1260 days
#4 posted 797 days ago
if it is going to be painted, I’d go with MDF. as much as I dislike the stuff, if yuou want to go with a sheet product, mdf will allow you to construct without hiding endgrain on the corners, it mills up beautifully with saws and router bits, and it paints evenly. It does not do well with moisture, but stands up to heat very well. one caution, make clean cuts and router well, because it does not sand nearly as well as it mills, you end up with a fuzzy surface, the only solution I have found for this which works really well is to coat with thinned epoxy or shellac, depending on the finish applied over it, let that harden the surface, then sand it again.
plywood is stronger, more moisture resistant, and gives you a grain texture on the surface, but it is more expensive, has nasty edges, even if you get good stuff without any voids, and if you plan on doing any shaping, you will have to paint it many times to cover the alternating grain in those edges. that being said, you could always attatch solid edging to any areas you plan to shape or router, but that’s just more work
View Steve Donnelly's profile
Steve Donnelly
114 posts in 1040 days
#5 posted 797 days ago
Hands down MDF; and (not that it matters in this instance) we often use Medex MDF in wet areas without problems and Medite MDF when it’s specified to be fire retardant..
-- Steve, The Hill Country, TX; www.themillworkguys.com
View Jonathan's profile
Jonathan
2568 posts in 1221 days
#6 posted 797 days ago
I’m assuming you’re going to paint this since you mentioned MDF here? Or are you considering MDF/ply for the core, with veneers over the top, then putting a finish over that?
I am still trying to get together my mantel/fireplace surround and built-in bookcases. Hopefully it’ll happen sometime in the next couple of months. I’m going the plywood route, but that’s because I plan on staining everything, as I want to use oak for the grainy look. With that being said, if I were going to have it all painted, I’d go MDF.
-- Jonathan, Denver, CO "Constructive criticism is welcome and valued as it gives me new perspectives and helps me to advance as a woodworker."
View Torr's profile
Torr
18 posts in 817 days
#7 posted 797 days ago
I used MDF for the legs and facing, but ply for the mantel shelf, using the theory the shelf would get more wear and tear. The legs were 3-sided boxes with lock miters, nailed from the sides into cleats mounted to the wall. The shelf and facing were similar, then trimmed with molding and painted. Surround and hearth were tiled first, then mantel built in place. Here is the result….
P.S. The manual for my gas fireplace had clearly defined clearances to combustibles including the allowable projection of the shelf at varying heights. You’d behoove yourself to check this for your application. For wood burning fireplaces I believe this is addressed in the various building codes. I definitely noticed the shelf getting warm when the blower was not turned on when the fireplace was running. I personally would absolutely respect any clearance requirements….
Tim
View wood4me's profile
wood4me
5 posts in 1964 days
#8 posted 795 days ago
Mdf is perfect for projects which will be painted, and where moisture will not be a problem.
I love the look of woodgrain, and for that reason choose to build mine from Tasmanian Oak.
https://picasaweb.google.com/ausiewood/LandsdaleFireplace#
-- wood4me
