How to cure burl slabs?
Forum topic by peterrum posted 03-16-2011 03:47 PM 2500 views 0 times favorited 1 reply Add to Favorites Watch
View peterrum's profile
peterrum
153 posts in 2885 days
03-16-2011 03:47 PM
Topic tags/keywords: burl big leaf maple milling chainsaw air dry
I have some Big Leaf Maple burl that I slabbed up a month ago and they are about 2” thick. I have them stickered and air drying. On the majority of the burls I will want to remove the bark to expose the wild edge on it. Is it best to remove the bark now or after it has dried. What is the best method for removing the bark without damaging the wild edge. The majority of the bark will be quite difficult to remove and is tightly attached to the slab.
Thanks
-- Carpe Diem
1 reply so far
View Nomad62's profile
Nomad62
726 posts in 3164 days
#1 posted 03-16-2011 05:27 PM
I do that same thing; I use a 2400 psi pressure washer to get the big chunks off, picking with an awl along the way. Nothing but elbow grease will remove the tightly packed stuff in the holes. Some people use a 4k psi machine, they clean the wood much better but will damage the surface if done too closely. It is much, much easier to get the bark off when it is wet.
