What did the previous owner do to this Beisemeyer Fence Clamp?
Forum topic by C_PLUS_Woodworker posted 03-16-2011 04:39 AM 1829 views 0 times favorited 17 replies Add to Favorites Watch
View C_PLUS_Woodworker's profile
C_PLUS_Woodworker
601 posts in 2903 days
03-16-2011 04:39 AM
Topic tags/keywords: beisemeyer fence question
Just bought a 5-year-old Unisaw with a Beisemeyer fence. Haven’t used this fence system before. The fence clamp handle has glued to it a small pieces of wood and on top of this is glued a small piece of sandpaper.
What’s up with this? Good? Bad?
Suggestions would be really appreciated, as I am new to this fence system. Thanks in advance.
17 replies so far
View ajosephg's profile
ajosephg
1880 posts in 3557 days
#1 posted 03-16-2011 04:44 AM
Just off the top of my head, I’d say he clamped the fence down too hard and bent the thingy in there, after which it would not lock down. Then, he glued a stick and some sandpaper in there to make it kind-of work again.
Tomorrow when I get into my shop again, I’ll look and see if I still agree with what I just said.
-- Joe
C_PLUS_Woodworker
#2 posted 03-16-2011 05:29 AM
Thanks Joe, that would be really great. I just looked again and there is a gentle curve all the way along the “thingy” ......... from where it comes out of the bolt all the way through to the end. Doesn’t look like it would be too hard to straighten out, if that is the way it is supposed to be. Thanks again.
View mrg's profile
mrg
823 posts in 2995 days
#3 posted 03-16-2011 05:41 AM
You can order that part from Delta or anyone that sells the Beise fence.
-- mrg
C_PLUS_Woodworker
#4 posted 03-16-2011 06:12 AM
Thanks, guys.
This looks like the part to me. Agreed?
http://www.mikestools.com/B1350056-Biesemeyer-Cam-Foot-White.aspx
View MarcusM's profile
MarcusM
57 posts in 2976 days
#5 posted 03-16-2011 01:29 PM
C_Plus; I don’t think the cam foot is the part to worry about here but rather the glide pad on the foot. You can get just the pad; I’d also check the two inner glide pads on the T-bar for wear. Might be a good idea to replace all three glide pads if you’re planning on placing an order anyway.
Cheers, Mark
-- Tilbilly Mark
C_PLUS_Woodworker
#6 posted 03-16-2011 02:37 PM
Mark….....thx.. I already ordered the cam foot (not expensive) but I will take your advice and also swap out all of the pads. I might as well get the ones that go onto the middle bottom of the fence as well while I am at it.
Sure like this forum and the folks on it.
View Eagle1's profile
Eagle1
2066 posts in 3060 days
#7 posted 03-16-2011 03:25 PM
OUCH!!!
-- Tim, Missouri ....Inside every older person is a younger person wondering what the heck happened
View jusfine's profile
jusfine
2422 posts in 2921 days
#8 posted 03-16-2011 04:55 PM
I had purchased a General tablesaw with a Bies fence a few years ago but can’t get used to it after so many years using the Unifence on the Unisaw.
Doesn’t seem to lock as well, maybe has the same bent problem but mine is new…
Good Luck with yours C+!
-- Randy "You are judged as much by the questions you ask as the answers you give..."
View dpjeansonne's profile
dpjeansonne
72 posts in 3209 days
#9 posted 03-16-2011 05:39 PM
I say it is the pad. I had one that the pad came un-glued and had a hard time getting it to stay in place. I used some reinforced fiberglass tape to wrap the pad to the cam bar. This worked well but is not a permenate fix but re-doing it is not much of a problem.
-- Cajun Don, Louisiana
MarcusM
#10 posted 03-16-2011 05:50 PM
Ha! C_plus; I was going to suggest you get that glide pad too but I didn’t want to spend any more of your money :)
Cheers, Mark.
-- Tilbilly Mark
ajosephg
#11 posted 03-17-2011 03:38 AM
Looked at mine today, and don’t have anything to add. Looks like you have it covered.
-- Joe
C_PLUS_Woodworker
#12 posted 03-17-2011 04:39 AM
Thanks for all the help guys. Really appreciate it. Got all the pads and a new cam foot coming. That ought to take care of it…..........no matter what it was.
C_PLUS_Woodworker
#13 posted 03-22-2011 03:31 AM
Just thought I would do a follow-up on that foot cam issue. The new foot cam is now installed and it works perfectly. That was exactly the problem…............ the missing pad. The old and new cams both had the same curve to them.
Thanks a lot guys. Really appreciate the help.
p.s. Strange thing happened today. Made several cuts….....and they were all straight. No measuring and re-measuring from the blade to the fence (and then prayer). Wonderful.
MarcusM
#14 posted 03-22-2011 03:46 PM
That’s great C-Plus. Soon enough you’ll have to change your name to at least B-Plus :)
Mark
-- Tilbilly Mark
View Lee Barker's profile
Lee Barker
2170 posts in 2846 days
#15 posted 03-22-2011 04:05 PM
General info: On my older Biesmeyer, the tension is adjusted with two Allen set screws on the fence part that runs inside the rail. They adjust for squareness as well.
Second, those pads—and I called Biesmeyer for this info when I bought mine used—are just laminate samples. Wilsonart, Micarta, whatever. I use the marbley ones for the surface that rides on the table and the regular finish ones for the lever that operates off the cam.
Kindly,
