how to calculate?
« back to Joinery forum
Forum topic by kennyjoy posted 12-30-2017 10:03 PM 736 views 1 time favorited 14 replies Add to Favorites Watch
View kennyjoy's profile
kennyjoy
5 posts in 386 days
12-30-2017 10:03 PM
Topic tags/keywords: question tip
How to calculate the above angle? Thanks!
14 replies so far
View Luthierman's profile
Luthierman
222 posts in 1323 days
#1 posted 12-30-2017 10:18 PM
I think we need a little more info.
-- Jesse, West Lafayette, Indiana
View John Smith's profile
John Smith
1544 posts in 399 days
#2 posted 12-30-2017 10:23 PM
are those table legs ??
I am terrible with math, geometry, algebra and anything else that contains numbers.
I just get me some cardboard and make templates – then cut from the pattern (when possible).
I just bought a new angle finder at Lowe’s, and if I read it correctly,
the outside line is 103 degrees and the inside line is 113 degrees and the joint line is 62 degrees.
if your drawing is drawn to scale, you could try those numbers on a template and see if the work for you.
-- I started out with nothing in life ~ and still have most of it left.
Luthierman
#3 posted 12-30-2017 10:45 PM
Am I missing something? There is no picture, nothing. Weird.
All I see is a post asking this question with zero reference to anything.
John Smith
#4 posted 12-30-2017 10:50 PM
I guess my 10 year old laptop is Blessed – I see a simple hand drawing.
View ChuckV's profile
ChuckV
3183 posts in 3763 days
#5 posted 12-30-2017 10:58 PM
- Luthierman
As Sgt. Schultz would say, “I see nothing!”
-- “Big man, pig man, ha ha, charade you are.” ― R. Waters
John Smith
#6 posted 12-30-2017 11:07 PM
this is Kenny’s drawing.
View MrUnix's profile
MrUnix
7106 posts in 2435 days
#7 posted 12-30-2017 11:31 PM
It’s a WebP image – a relatively new Google kitchen sink image format they are trying to push on the Internet that isn’t widely supported. Chrome and Opera will (should) display them, but not many others.
View pontic's profile
pontic
663 posts in 845 days
#8 posted 12-31-2017 12:41 AM
I look at it this way; The circumsribed angle is 113. You want to cut a miter so it will make a table leg giving a flat surface. This means that you must adjust the miter so that 90 is to 45 as 113 is to X.
solving for x you get 90-45 =45 as 113-X=45 or 68 degrees
-- Illigitimii non carburundum sum
View jerryminer's profile
jerryminer
944 posts in 1678 days
#9 posted 12-31-2017 01:24 AM
It’s not clear exactly what angle you are trying to calculate.
Trigonometry is the mathematical way to calculate angles from known lengths. In your case, there is not enough information to give a “calculated” angle.
Measuring with a protractor is a way to derive angles from a drawing or object.
I often let SketchUp do my calculating for me. In the case of the drawing you posted, I imported that into SketchUp and got these results:
John Smith
#10 posted 12-31-2017 01:30 AM
you lost me at “then you adjust the miter”.
that is why I make cardboard templates and cut from patterns.
jerryminer
#11 posted 12-31-2017 01:41 AM
If you are trying to miter two pieces of the same dimension (at the miter), then—as I see your drawing, (which I have cleaned up a little below)—you want to be about 12 degrees off of square, or 102 degrees (90 + 12). The miter angle for each piece would then be 51 degrees.
In order to cut a 51 degree miter, you would set your miter saw or tilt your table saw to 39 degrees (because miter gauges read 90 degrees off from their actual angles—-don’t ask me why).
If you are trying to miter pieces of different dimensions, than the angles will change and will depend upon the dimensions of the pieces.
View tomsteve's profile
tomsteve
896 posts in 1455 days
#12 posted 01-01-2018 02:55 PM
- John Smith
keepin it simple sure takes out the complicated stuff and makes it,welp, simple!
i might be mistaken, but with the 62 degrees at the joint, i think the bottom cut on the leg( if its a leg) should be 28 degrees?
View ArtMann's profile
ArtMann
1215 posts in 1052 days
#13 posted 01-01-2018 03:17 PM
The image has no dimensions so you can’t calculate anything. If I were you, I would make a 1:1 model out of cardboard and then measure the angles and dimensions you want.
pontic
#14 posted 01-01-2018 03:28 PM
- John Smith
I’m with you make it out of card board first.
