Burial Grave Marker - what material would you use and how to install it ?
Forum topic by John Smith posted 12-30-2017 08:31 PM 2330 views 0 times favorited 6 replies Add to Favorites Watch
View John Smith's profile
John Smith
1491 posts in 368 days
12-30-2017 08:31 PM
Topic tags/keywords: grave cemetery marker headstone tombstone head stone tomb stone
I would use either redwood or teak. 3” thick and one solid piece, no laminations
with stainless steel pipe legs anchored into the ground and the wood marker itself above ground.
this works for private cemeteries and pet grave markers as well.
In my very personal opinion and experience, some woods such as cypress, cedar, pine, etc.
will rot if they are in the ground. I would prefer for the marker to be above ground firmly
anchored below for stability and deter theft.
-- I started out with nothing in life ~ and still have most of it left.
View patcollins's profile
patcollins
1687 posts in 3071 days
#1 posted 12-30-2017 09:59 PM
I would use Ipe or Cumaru, the stainless pipe is a good idea but where the heck do you get stainless pipe?
I don’t think the cement is needed, have you ever tried to pull out a pipe that is 2ft into the ground?
View Luthierman's profile
Luthierman
221 posts in 1293 days
#2 posted 12-30-2017 10:04 PM
I would go with hedge. I have pulled out 60+ year old corner posts that are still good. That shiz is crazy resilient against rot.
-- Jesse, West Lafayette, Indiana
John Smith
#3 posted 12-30-2017 10:17 PM
yes – I have pulled pipe out of the ground. if it has smooth sides it will pop right out.
I just removed 150 feet of chain link fence that had every other pipe post cemented and every other without.
the ones with no cement came right out, the ones with cement had to be dug out.
now – rebar is different. when it rusts in the ground, it cements itself into the surrounding dirt
and is a real bugger to pull up.
Central Florida uses a LOT of stainless pipe on boat rails. very common to find. same as aluminum.
of course the builder can use whatever is available to him/her (even PVC pipe filled with cement). its their project.
I am just illustrating how I would do it if I had the job.
and I agree that Ipe and Black Locust are very good candidates.
just hard to find in big 3”x18”x24” chunks that I would use myself.
I have made a lot of bronze plaques during the 40 years that I was a sign maker.
quite a few were personal markers to be attached to an existing stone monument.
so I know my way around plaques, markers, etc. (and some of the regulations).
patcollins
#4 posted 12-30-2017 10:44 PM
Suppose that the type of dirt needs to be taken into account, I am thinking about the clay heavy dirt in West Virginia where I could not pull a pipe out of the ground without mechanical help.
John Smith
#5 posted 12-30-2017 11:03 PM
I lived in Summersville, Nicholas County County for 3 years.
you can not even dig a hole there – much less pull anything up.
as I mentioned – this is what I would do if I had the job…. I am now back in FLORIDA.
our sand is 500 or more feet before you hit bedrock. we do not have clay like you do.
again – each person will determine what method of install suits them best.
Pat – if you are talking about iron gas and water pipe,
yes, once a pipe rusts in the dirt and rocks, it can be very hard to pull up after 20 years.
View marc_rosen's profile
marc_rosen
146 posts in 3386 days
#6 posted 12-30-2017 11:24 PM
I was asked to make a 9-11 memorial for some family members of one of our doctors and I used some leftover Ipe from a contractors job elsewhere on our campus (which I was fortunate enough to score several dozen board feet of 12×1 inch boards). It is sitting on the soil and I made some anchors from “All Thread” and set some nuts on the end to hold it in concrete. Some years later our ground’s crew hit the memorial clearing snow. It only budged a few inches but it stayed in the ground. The Ipe is weathered gray but it still looks very intact.
Hope you all have a safe New Year’s Eve celebration and several healthy New Years ahead. Marc
-- Windsurfing, Woodworking, Weaving, and Woodducks. "Most woodworkers are usually boring holes"
