Can anyone identify the wood in this gunstock?
Forum topic by Sam Allred posted 12-29-2017 05:11 AM 2482 views 0 times favorited 15 replies Add to Favorites Watch
View Sam Allred's profile
Sam Allred
5 posts in 458 days
12-29-2017 05:11 AM
Topic tags/keywords: wood display case gunstock knife identify
A friend would like to make a matching knife out of the same wood with a display case out of the same wood as well for both the gun and knife. I’m struggling to identify what wood this is. Thanks!
-- "I have never let schooling interfere with my education." -Mark Twain
15 replies so far
View TheTurtleCarpenter's profile
TheTurtleCarpenter
1052 posts in 1264 days
#1 posted 12-29-2017 05:35 AM
Claro Walnut
-- "Tying shoelaces was way harder than learning to Whistle"
View robscastle's profile
robscastle
5444 posts in 2402 days
#2 posted 12-29-2017 05:53 AM
Sam, strugle no more
I wood have to agree with Turtle but to be sure as I am no expert, check with the maufacturer as they will be able to tell from the serial No what the build specificatons were.
-- Regards Rob
View TheFridge's profile
TheFridge
10705 posts in 1684 days
#3 posted 12-29-2017 06:28 AM
I’d have to agree. Walnut is heavily favored for gunstocks. Good luck find something close. A gunstock blank that pretty is gonna be expensive.
Finding something in the neighborhood of similar might be doable but in quantities to make even a small display case will be tough. Unless you’re thinking veneer. That would make things easier for you.
5171 posts in 2691 days
#4 posted 12-29-2017 11:56 AM
My guess is claro walnut as well. that one is so nice (wonderful checkering as well) it’s may well be custom made.
View Tony_S's profile
Tony_S
955 posts in 3281 days
#5 posted 12-29-2017 12:28 PM
In the gun stock world, it’s most often called ‘Turkish Walnut’ or ‘Circassian Walnut’....Truth be told though, it’s actually Juglans Regia, or ‘English Walnut’.
I’m not sure that the excess black streaking is more pronounced due to certain regional soil/mineral types? I’m guessing it is though….almost all off these gun stock blanks come from the root ball of the tree as well.
Highly doubtful that you’ll be able to easily find Turkish Walnut lumber though….Most of it is typically milled and sold as gun stock material.
Fridge is right….$$$
A gun stock ‘blank’ of the grade in the pic above(which is probably a mid grade) would probably start at $1000.00?
https://www.google.ca/search?client=firefox-b&dcr=0&biw=1088&bih=503&ei=DStGWrHeFdC8jwPRxJPABg&q=turkish+walnut&oq=turwalnut&gs_l=psy-ab.1.1.0i7i30k1l10.5950.10705.0.13322.4.4.0.0.0.0.150.548.0j4.4.0....0...1c..64.psy-ab..0.4.545...0j0i67k1j0i131k1.0.C6zso2gGsMQ
-- It is the mark of an educated mind to be able to entertain a thought without accepting it. Aristotle
View JayT's profile
JayT
5957 posts in 2409 days
#6 posted 12-29-2017 01:52 PM
Lumber or a full blank of figured walnut like that is definitely a lot of $$$. What you might do, however is contact a custom stock maker or gunsmith that does custom work and see if they would sell you the offcuts of a high end blank for knife scales.
Not long ago, I picked up a bunch of smaller pieces of 3in thick walnut from a local stock maker that recently retired. The pieces range from 3-6in wide by 12-18 in long. Not enough for the smith to do anything with, but more than enough for turning blanks, knife scales or, in my case, hand plane blanks. For him, they were scrap and taking up space. For me, they were an inexpensive source of high quality small blanks.
Since, according to your profile, you are in Utah, you might try Bullberry Barrel Works They do a lot of stock work in better grades of figured walnut, clear up to exhibition grade.
View d38's profile
d38
108 posts in 460 days
#7 posted 12-29-2017 02:14 PM
Agree that in the gun world its called Turkish walnut, and a stock maker is a good place to procure some small pieces.
Looks like a Winchester model 70 with engraving on the receiver. I’d guess a full custom rifle and stock, and done very well.
View splintergroup's profile
splintergroup
2422 posts in 1420 days
#8 posted 12-29-2017 03:46 PM
You can find nicely figured walnut by buying turning blanks, basically a chunk of figured wood in a block form, sealed in wax (only partially dried).
View Kazooman's profile
Kazooman
1237 posts in 2150 days
#9 posted 12-29-2017 04:02 PM
You will need larger pieces for the case. I have found Northwest Timber to be a very reliable source for claro walnut. You can browse their pictures online to try to find something that would work well with the gun stock.
https://nwtimber.net/shop-all-wood-types.html
View RRBOU's profile
RRBOU
176 posts in 2490 days
#10 posted 12-29-2017 04:09 PM
My guess is claro walnut as well. that one is so nice (wonderful checkering as well) it s may well be custom made.
- Fred Hargis
Guaranteed it is a custom made stock.
-- If guns cause crime all of mine are defective Randy
TheFridge
#11 posted 12-29-2017 04:28 PM
- Fred Hargis
- RRBOU
Ditto.
A case large enough for just the gun might be doable. If they’re willing to spend as much on the case as they are on the gun.
Sam Allred
5 posts in 458 days
#12 posted 12-30-2017 01:51 AM
Thanks for all your responses. I am trying to find a good source for the wood. I will report back. Looks like claro walnut is premium.
View Dark_Lightning's profile
Dark_Lightning
3340 posts in 3307 days
#13 posted 12-30-2017 03:00 AM
How thick do you need your stock to be? I have a piece of 8/4 black walnut with a huge amount of figure that I could possibly part with.
-- Random Orbital Nailer
View msinc's profile
msinc
569 posts in 701 days
#14 posted 12-30-2017 03:10 AM
In the gun stock world, it s most often called Turkish Walnut or Circassian Walnut ….Truth be told though, it s actually Juglans Regia, or English Walnut .
I m not sure that the excess black streaking is more pronounced due to certain regional soil/mineral types? I m guessing it is though….almost all off these gun stock blanks come from the root ball of the tree as well.
Highly doubtful that you ll be able to easily find Turkish Walnut lumber though….Most of it is typically milled and sold as gun stock material.
A gun stock blank of the grade in the pic above(which is probably a mid grade) would probably start at $1000.00?
- Tony_S
This is pretty much spot on….Juglans Regia {royal walnut}, also known as “English” walnut, but the funny thing is it is not, nor has it ever been from England. One other interesting fact…the particular grade or piece pictured is actually taken from the stump, not the log and yes, it has long been written about and passed down that the black streaks are from minerals in the soil where the tree grew. There are two principal properties that make this wood the most desirable for gunstocks, besides the obvious beauty…one is that it has a lot more “spring” or tenacity than other walnut woods, like black walnut for example. Black walnut is very hard and also somewhat brittle. “English” walnut takes checkering very well, in fact it is a joy to checker by hand.
It is really found primarily in Europe, but two world wars have all but decimated the supply. Being referred to as “English” probably stems from the fact that all of the fine turn of the century British made double guns, both rifle and shotguns invariably had stocks made with the finest walnut.
splintergroup
#15 posted 12-30-2017 03:46 PM
Cook Woods sells it, occasionally they have a sale for a good percentage off but it still is very $$$.
